Old 05-29-2016, 10:46 AM
Clearancediver's Avatar
Clearancediver Clearancediver is online now
Mein Auto: 2004 Z4, 2009 Nomad mc
SRS light and BST cable issue
I just had the SRS (airbag) light on my dash come on last week after 2 1/2 years ... Since it had been fixed by BMW tech so I was pretty sure it was the same issue back again.
Diagnostics code indicated increased resistance in the right pillar system.. But despite cleaning the under seat connection and the SRS BST connection clipped to the battery main power terminal in the battery compartment that was the cause last time it refused to clear.
Short story is that after a few days of screwing around/research I checked continuity on the BST cable and confirmed that it was good... Spread the pins slightly on the connection to ensure that the connector was making good connection and cleared the code once again.
Error cleared and has stayed clear....
ID:	565089Click image for larger version
ID:	565090Click image for larger version
The BST Is the blacked sheathed twisted pair wire leading to the battery terminal. It fires a squib to electrically disconnect the battery cable from the battery cable terminal in case of accident. Not all cars have this but if your battery is in trunk it's more than likely.....
I zap strapped the connector and where it mounts to the side of the power terminal to ensure it doesn't move.
Old 05-29-2016, 11:25 AM
f you don't know what a squib is... It's a small explosive charge ... It blows the battery cable back some 20-30mm in the battery cable terminal to physically disconnect the battery from the electrical system. It's an expensive piece of wire/labour to replace so if you don't know what you are doing with a meter don't check the continuity...
Old 05-31-2016, 04:57 PM
shipkiller's Avatar
shipkiller shipkiller is offline
Underway on Nuclear Power
Mein Auto: Me
This might help with your troubleshooting.
File Type: pdf Battery Safety Terminal and Monitoring.pdf (16.2 KB, 118 views)
How does something immoral, when done privately, become moral when it is done collectively?
Furthermore, does legality establish morality?
Slavery was legal; apartheid was legal; Stalinist, Nazi, and Maoist purges were legal. Clearly, the fact of legality does not justify these crimes. Legality, alone, cannot be the talisman of morel people. - Walter E. Williams
Old 05-31-2016, 06:30 PM
Thank you... Added to my treasure trove of pdf's on the car.
Old 05-31-2016, 06:38 PM
Derekz4 Derekz4 is offline
Mein Auto: Z4
Originally Posted by clearancediver View Post
thank you... Added to my treasure trove of pdf's on the car.
+1
