Old 09-01-2007, 06:30 PM
AutopiaDR AutopiaDR is offline
Detailing Revolution
Mein Auto: 335i Alpine White, SB Int
Originally Posted by sixspeed View Post
I had it clear-coated - that was all
If you get one you may or may not need it done. The roof was already finished for install straight away (and TCK didn't mention any need for further treatment etc before fitting).
However, when I inspected mine, there were light scratches in the resin/clear-coat that was already on there. So I asked a friend of mine who runs a bodyshop to add another clear-coat layer. Not only will this help protect the carbon from UV damage (as there is a UV inhibiter in the clear, and carbon can discolour over time from sun exposure), but it also meant they could safely flatten the new coat back until it looked like glass Which it sure does now!
Alpine White Z4M Coupe
19" CSLs w/ PS2s -- TCK Carbon Roof -- Gruppe-M Intake -- H&S Cat-Back -- H&R Springs -- Tints -- Storm V1 -- CDV -- DICE -- +more
Have you noticed better or worse sound insulation now that you changed the roof to CF? Also have you gone to a high preassure Car Wash and noticed if the roof leaks? Not doubting your workmanship just curious how close in quality to the OEM roof this is.
Thanx in advance
Old 09-01-2007, 06:44 PM
Dammmittt's Avatar
Dammmittt Dammmittt is offline
///M
Mein Auto: 07 M Coupe
Thanx in advance
I dunno how else it would leak unless the seal was bad. There aren't going to be any holes in the roof itself!!!
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website in the History of the Internet!
Old 09-02-2007, 05:19 PM
Dammmittt's Avatar
///M
Originally Posted by Palantirion View Post
Update
Two more pics of the exhaust:
Mod 34
6-29-07
I removed my visor airbag decals. Contrary to what was posted in another bimmerfest thread, I did NOT use the blow dryer and spatula method. On the advice of my doctor (the master Tyrone) I tryied Goof Off. This stuff is the BOMB! It quickly disolved the binding agent of the sticker and then it simply peeled/fell of the visors. Best of all Good Off, being a liquid, gets into the cracks in the vinyl visor and wipes out the residue the sticker leaves behind. So far I've removed the stickers from my M5 (leather), Z4 MC (vinyl) and our 540iT (fabric) visors. I tried the heat/spatula/blade method on my M5's passenger-side visor and after 30 minutes of heating and scraping I was left with less than ideal results. I tried Goof Off on the driver's side visor and was done in less than 5 minutes with perfectly clean leather. I should mention that after Goof Off I moisturized the visors with their repsective treatment products. For leather I use Lexol Leather Conditioner, for vinyl I use Lexol Vinyl Treatment, for the fabric (or carpet) I use Lifter 1.
Z4 visor, before:
After:
p.s. I took some in-car video today. With luck I'll be able to edit and post it tonight...(still need exterior video)
Sorry to dig this one up, but I scraped away on my passenger visor for about 15 minutes with goof off before I got it to satisfactory level...what did you use to scrape at it while the goof off disolved the adhesive?
Old 09-03-2007, 05:09 AM
sixspeed sixspeed is offline
Mein Auto: Alpine White Z4MC
Thanx in advance
No difference at all. If you do a proper job it will fit and seal as perfectly as the OEM roof. There's no new rattles either, but how well you take the interior trim out and refit will determine that. If you break any clips (which is possible, as they're made of the thinnest plastic in the world!) then make sure you replace them...
I have my own pressure wash at home and have given it a good hosing down a few days after fitting (to let the sealant go off and dry thoroughly first) - we've also had some pretty bad weather this summer here in the UK, and through it all my interior has stayed as dry as it ever was.
I don't know ifall the pics were posted on here, but there's a load of photos we took of the work being carried out on my Flickr Page. Have a browse through and you'll see pretty much what was involved
For those that wondered if it was a true replacement panel, or just an overlay... this should answer your questions
Old 09-03-2007, 11:02 AM
Palantirion's Avatar
Palantirion Palantirion is offline
Z4 Mvangelist
Mein Auto: 2003 M5-S2, 2002 540iT-S2
-I didn't scrape at all. I applied the Goof Off with a rag, and moved it in little circles with light pressure. After a few seconds the sticker just started falling off in little pieces. Are you sure you have Goof Off?
Old 09-03-2007, 03:59 PM
Dammmittt's Avatar
///M
Yeah...hmmmm...maybe my stickers are on there better or you had a concentrated version? I got mine in a spray bottle at lowes...
Old 09-04-2007, 09:38 AM
Z4 Mvangelist
Weird. Maybe I got an extra strength version. Try HD and see if they carry a different version
p.s. I'd post a pic of my bottle, but I'm on the road right now...
Old 09-04-2007, 01:16 PM
Dammmittt's Avatar
///M
I used the bottle on the far right.
Old 09-04-2007, 07:12 PM
Z4 Mvangelist
Attachment 120033
Thanks for finding pics. I used the one that is second from the left. The one with the small red cap.
Old 09-05-2007, 07:35 AM
Artz 330 Artz 330 is offline
Mein Auto: 2006 JetBlack 330i
how much weight did you loose with the carbon roof. And did you leave the carbon or did you paint it?
Old 09-05-2007, 07:43 AM
Luminor's Avatar
Luminor Luminor is offline
My kine-a town.
Mein Auto: 335i, E350 Estate, F430
If you're asking about the TCK carbon roof, its 8lbs lighter then stock...
Old 09-06-2007, 05:27 AM
Luminor's Avatar
My kine-a town.
Pal, I noticed on another forum you mentioned that you might look into the EvoTech software...any chance you came up with anything?
http://www.dynocomp.com/bmw.php?view=bmw
Old 09-06-2007, 01:16 PM
Z4 Mvangelist
-No, I haven't had time these last few weeks. I did take some more pics of my modified side markers though.
(Please excuse the crappy stock exhaust, my BMS exhaust was in the shop for final jigging)
Old 09-07-2007, 08:59 PM
has anyone got the evo tech software, and is it any good?
Old 09-08-2007, 06:24 AM
Dammmittt's Avatar
///M
Old 09-08-2007, 07:15 AM
ROM3N's Avatar
ROM3N ROM3N is offline
Mein Auto: Z4M coupe
I do here is my dyno, BTW it was 110+ deg when we ran it.
Old 09-08-2007, 11:52 AM
Luminor's Avatar
My kine-a town.
Originally Posted by ROM3N View Post
I do here is my dyno...
Is that corrected. What does that represent in crack HP?
...and do they have software that allows us to take advantage of intake and/or exhaust mods?
Old 09-08-2007, 01:21 PM
DaveZ's Avatar
DaveZ DaveZ is offline
The knights who say Ni!
Mein Auto: 2006 Z4 M Roadster
Can't help myself just have to say that everything goes twice as fast when measured in crack HP
DaveZ - http://www.zeleznik-klein.com/z4
2006 MZ4 Roadster, Interlagos Blue, Light Sepang, CF Trim
CDV delete, OEM Strut Bar, Homelink, smartTop Controller
Old 09-08-2007, 04:36 PM
Z4 Mvangelist
Good numbers ROM3N, were those both done on the same day/conditions? What was the software install like?
Btw guys, I had a chance to drive my Coupe with only the BMS Stage 1 (mufflers) and it is quieter than the Stage 2 (mufflers and x-pipe). I prefer the Stage 2, but the Stage 1 still sounded very good. The tone is the same, the volume just increases more with the throttle with the Stage 2. If you want a good performance sound, pick the Stage 1. If you want good performance sound AND a nice loud bark at higher revs (and a little more weight loss and air flow), pick the Stage 2. Neither drone.
Old 09-08-2007, 07:55 PM
ROM3N's Avatar
That was the same day before and after the flash. Install was easy I went to lunch while they did it took about an hour once they got the file from Evotech. I think it took a few hours to send the file and get it back.
Old 09-08-2007, 10:05 PM
Z4 Mvangelist
-Cool! To elaborate on "to send the file and get it back" means? Did your shop scan your ECU and then send it to Evotech and they sent you back new software?
Old 09-08-2007, 10:12 PM
ROM3N's Avatar
Yah they scanned my file Emailed it to Evotech and received the new file back.
BTW your cars looking good the CF roof would be hot any updates from TCK on the suspension or is it still the same since bimmerfest ?
Old 09-09-2007, 05:58 AM
Luminor's Avatar
My kine-a town.
Yeah, thanks for that one...sorry about that ...of course I meant "crank"
Old 09-10-2007, 03:46 PM
z3speed4me z3speed4me is offline
Mein Auto: 99 M coupe
i am quite interested in the ecu upgrade...
interesting that no other company has one yet, i would really like to see AA or someone else through out a program as well
i dont wanna just throw out 800 plus prob another 200 to a shop for something I cant really guarantee is getting me anything...
i would probably like to see one other car with a before and after, but thats just me, because their site just says + so and so tq + so and so hp
Old 09-10-2007, 03:54 PM
i was just thinking...
they dont show the actual before and after #'s and the graph is so small so its hard to see if their baseline SUCKED, and we cant tell if their after is bumped up or anything of the sort...
and even rom3n's isnt really that impressive, and doesnt seem to reflect the gains they claim, 280 at the wheel, some stock cars are dynoing at that, their claims should throw him into the 290's... hmmmm
~Ken~ {'99 M coupe : 1 of 35} - Built by Maximum PSI 623 whp 516 wtq @ 21psi 93pump; PTE6466; RIP 3.24.13 ()
{'01 M coupe : 1 of 16} - Nick G Tune, CPI Headers, maxpsi sec1, SS X-Pipe, Vibrant Res' and Black Muffs, TCK S/A, RF dual ear, 3.64, 8200RPM ~294 whp 237 wtq
{'13 Golf R} - GIAC stg 1, VWR intake, magnaflow catback; LED Tails
Similar Threads
Z4 M Coupe at NHIS brave1heart E85 / E86 Z4 (2003-2008) 9 11-11-2006 09:52 AM
335 news release today => 535 next year klu123 E60 / E61 (2004 - 2010) 34 04-26-2006 03:35 PM
Z4 coupe wheel styles Don L E85 / E86 Z4 (2003-2008) 6 03-28-2006 06:55 AM
Z4 Coupe design Axcu E85 / E86 Z4 (2003-2008) 0 12-10-2005 02:17 PM
NEW BMW Z4 Coupe Video OC-Z4 E85 / E86 Z4 (2003-2008) 9 10-07-2005 05:13 PM
