Old 03-02-2009, 01:00 PM
JCz04Bimmer JCz04Bimmer is offline
Mein Auto: '04 330Ci & '06Z4MC
Quick random question.
Sway Bars. I understand you're using Ground Control's E46 M3 bars. Rears bolt up without modification. Cool. If I will be installing the fronts with adjustable endlinks, what kind of modifications will be necessary? I read that the stock endlinks required shortening on the Z4M to accommodate the E46 M3 sways but with adjustables I assume this won't be necessary (provided, of course, that their range of adjustment allows them to be shortened enough). How much shortening did you need to do?
I probably won't go with the GC bars but rather with the UUC bars but I assume their geometry is similar.
Thanks in advance.
Old 03-02-2009, 04:43 PM
Palantirion's Avatar
Palantirion Palantirion is offline
Z4 Mvangelist
Mein Auto: 2003 M5-S2, 2002 540iT-S2
Thanks in advance.
-I didn't perform the modifications, so I really don't know. Chris at BMS would be the one to ask. But don't assume that the answer would carry over to a UUC product.
Old 03-02-2009, 06:35 PM
Z4 Mvangelist
My Monday: http://www.bimmerfest.com/forums/sho...=1#post3967064
Old 03-05-2009, 03:26 PM
Z4 Mvangelist
I received a call from BMS today. My DME got back from ESS more quickly than I expected (24 hour turnaround). So I went down and reinstalled it and drove home. I was hitting the beginning of rush hour, so I didn't have much of a chance to rev it out on the surface streets. But something is certainly different! I found myself a little nauseous after a second gear pull to 7500rpm
At the risk of jumping the gun I think I need to call Eloy at RPI again and schedule a dyno run...
Old 03-05-2009, 03:28 PM
pal's Avatar
pal pal is offline
S54=Living on the Edge
Mein Auto: 2007 M Coupe, 2004 Audi T
Congrats!! We need to see you smiling like blau335 ... good luck on the dyno!
Old 03-05-2009, 04:21 PM
blau335 blau335 is offline
Mein Auto: 335
Mines faster... therefore I have a much better smile curve.
http://www.youtube.com/watch?v=OqX7IIaXtkg Is it on a dyno? No.
TCK d/a coilovers, Stoptech 6/4 piston BBK, OEM CSL headers
Old 03-05-2009, 05:20 PM
Z4 Mvangelist
Mine has better wheels
Old 03-05-2009, 05:42 PM
Burt Reynolds Burt Reynolds is offline
Mein Auto: 2007 Z4 M Coupe
That is fantastic news! Glad it is running strong now. Lets see a dyno!
Old 03-05-2009, 05:59 PM
CalRick CalRick is offline
Mein Auto: 2007 Z4MC & 95M3 Tracktoy
Good to hear she's running better now. Can I borrow her to run Infineon this weekend if BMW is still playing with mine? I promise I won't -urp- Bob in it!
There's something contagious goin on here with our coupes and track days.
Old 03-05-2009, 06:08 PM
Mein Auto: 335
True...
Where do you live again?
Old 03-05-2009, 06:35 PM
ROM3N's Avatar
ROM3N ROM3N is offline
Mein Auto: Z4M coupe
Glad it feels better hopefully all is well...
Old 03-05-2009, 07:00 PM
imz4n's Avatar
imz4n imz4n is offline
Z ENTHUSIAST
Mein Auto: 06 3.0 si Z4R
Way to stick with it Earl.
I'm going to go meet CalRick this weelend. He is going to give me a ride in his coupe.
Old 03-05-2009, 08:09 PM
summereskimo's Avatar
summereskimo summereskimo is offline
Mein Auto: Modded E36/7&Stock E36/8M
Bob, what is up with you and ?
Can't wait for the next Dyno result.
Old 03-06-2009, 09:36 AM
Dammmittt's Avatar
Dammmittt Dammmittt is offline
///M
Mein Auto: 07 M Coupe
Can't wait to see the dyno.
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website in the History of the Internet!
Old 03-06-2009, 11:49 AM
Z4 Mvangelist
Pics and vids from Streets with the CFR500: http://www.bimmerfest.com/forums/sho...d.php?t=350848
Old 03-06-2009, 04:26 PM
Z4 Mvangelist
*Update*
I was able to take the car out for a drive today and confirm that the car DEFINITELY pulls all the way to redline now. I don't know what AJ changed, but it seems to have worked. Gonna schedule another dyno run with Eloy.
Old 03-06-2009, 09:39 PM
imz4n's Avatar
Z ENTHUSIAST
Holy sheep dip. Just glad when we went to Willow Streets the car was down on HP. Went for a wicked ride tonight. The old butt dyno says the car has emproved. Much different than when the car first ran. More of a linear pull all the way through the band. None of this 6.5K and going flat now. Very quick and much smoother. I get to have a special treat tomorrow. Earl is heading north to party down and I will be taking his MC to the pre///MFEST event. So, I will actually get a chance to try it out for myself. Sounds like fun to me, I won't get much sleep tonight.
Old 03-07-2009, 12:30 AM
Z4 Mvangelist
I got some pics emailed to me from btotoro. He let me borrow his Dynolicious today and after calibrating it I did a few runs. Apparently it also paid attention when I ran out 4th gear too (on a closed course of course!). As you can tell from the different peaks in different gears, I didn't input Scatha's weight correctly to calculate HP. But the time to speed seems about right.
In run #1 I didn't launch well and got wheelspin (see my notes). I also took a full 1/2 second to shift from 1st to 2nd. Other factors that increased my 0-60mph time are: no hard clutch drop, no slam shift (can grind 2nd gear as you other Z4 M owners know) and no power shifting. I'm not interested enough in a statistic to abnormally damage my car. It seems to me that with optimized launch procedures the car should do 0-60mph in about 4 seconds flat, maybe high-3s.
Run #2 was spontaneous. I was in 2nd gear, short shifted to 3rd and went WOT, shifted a little early to 4th and ran it up close to redline. This run would seem to corroborate blau335's assertion that a CFR500-equipped Z4 M will do 0-100mph in 9 seconds or less.
I'm not totally sold on the Dynolicious, but it's interesting and I may play more with it next time btotoro is around.
Old 03-07-2009, 09:40 AM
Mein Auto: 335
I need to find a nice LONGER quiet road and do some more tests. Dynolicous uses g forces right? I'm more comfortable with say OBDII log of speed or something.
Old 03-07-2009, 09:42 PM
imz4n's Avatar
Z ENTHUSIAST
Baby sat Scatha today. Took her to the Pre///mfest event. What a wicked ride. Very,very smooth and quite the lady, NOT. She is a blood thirsty, curb huggin, throttle lovin , HO. You know, stiletto wearing, skirt hickin, mind blowin, air suckin HO. Scatha a HO, not really, however, she did leave me wanting and tore my heart right out of my chest. Now all I need to figure what I need to sell just to get one of these. Sweet ride Earl and thanks for the chance.
Old 03-07-2009, 09:47 PM
Z4 Mvangelist
-I'm just trying to figure out how you went through almost 1/2 a tank in only 80 miles Glad you didn't get arrested
Old 03-08-2009, 04:48 AM
MC28REPSOL MC28REPSOL is offline
USN Black Hole
Mein Auto: S54 M-Coupe
80 Miles on a 1/2 a tank! ... lol ... i'd be empty!
Old 03-08-2009, 06:38 AM
imz4n's Avatar
Z ENTHUSIAST
Per your instruction, Don't have the doors open without the car running, and I got lost.
Old 03-08-2009, 10:35 AM
Pics from Scatha's adventure yesterday:
The Architecture of the building really compliments Scatha's aggressive body lines. That wasn't the case for my MC.
Earl, gotta play more with the Dynoliciousm and learn all the functions, just found out the option for the system start recording as soon as you roll and stops when you decelerate(auto mode). The airport would be a good testing ground to produce consistent data.
Old 03-09-2009, 10:29 AM
HotDogWater HotDogWater is offline
Mein Auto: 07 Z4MC
Where is that? Looks like a cool building
For sale:
Similar Threads
Z4 M Coupe at NHIS brave1heart E85 / E86 Z4 (2003-2008) 9 11-11-2006 09:52 AM
335 news release today => 535 next year klu123 E60 / E61 (2004 - 2010) 34 04-26-2006 03:35 PM
Z4 coupe wheel styles Don L E85 / E86 Z4 (2003-2008) 6 03-28-2006 06:55 AM
Z4 Coupe design Axcu E85 / E86 Z4 (2003-2008) 0 12-10-2005 02:17 PM
NEW BMW Z4 Coupe Video OC-Z4 E85 / E86 Z4 (2003-2008) 9 10-07-2005 05:13 PM
