E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
#1676
"New" pics of the Z4 and my buddy's 325/S52 from a Malibu shoot for Bimmer and Performance BMW earlier this year:
http://www.bimmerfest.com/forums/sho...=1#post5580767 |
#1677
Day one at OCRC went well. I learned that the heat shield I made does reduce oil temps for a little while, but starves the radiator and raises oil temps drastically soon after. The peak oil temp was the same as before the diverter valve was installed, but it got there more quickly overall, and water temp got up to 247! So that was a fantastic failure.
I pulled the heat shield after two quick sessions and went back out. Oil and water temps were a lot lower (oil by about 20F), so it would seem that the diverter valve is indeed beneficial. The track configuration this time around is all 3rd gear with only one turn at part throttle. So it's very hard on the car's cooling system (lots of load and limited speed) compared to Willow or Streets, etc. if driven as hard as possible. Still, my oil usually peaks at about 285F there, and I don't think it passed 265F today once the heat shield was removed. HOWEVER...something strange did happen and I'd like some input if anyone can answer my question. During a couple of sessions today the yellow oil light would turn on at only 245F instead of the usual 260F, and the red oil light which usually comes on at 280F would come on at 265F instead. Nothing was changed on the car or how it was driven, there was only 3F change in air temp today, and the runs during which the lights would turn on "early" were not consecutive! What is causing this??? p.s. I noticed that my oil is a little overfilled (reached the top of the red part of the dipstick), would this matter? Last edited by Palantirion; 11-06-2010 at 08:39 PM. |
#1678
Day 2 at OCRC went well. Had a lot of fun right-seating for new students and being a ring taxi. Scatha did pretty well too. I got one session that was fully uninterrupted with regard to catching slower cars and I could flog Scatha as hard as possible. This basically means running in 3rd gear WOT up to redline 5 times per lap in addition to being WOT to about 7k RPM 3 times as well - all this in about 1:40, for 20 minutes!
With the diverter valve and no heat shield my oil temps climbed steadily to about 260, then creeped to 265 and pretty much stayed there. One time during that session the oil touched 270, and a few times it dipped to 260, so I think it's safe to say that I found the point at which it will not climb further. This is a 20F improvement over the previous 285 that I would see at OCRC and Cal Speedway, so the diverter valve swap works! Unfortunately my water temps were just as high as when my oil would hit 285, so the hot air coming out of the oil cooler is still superheating the radiator. This might explain why the yellow and red oil temp warning lights sometimes come on much earlier than usual (although I'm still waiting for an expert to chime in on that, hint, hint) relative to oil temps. The limp mode, as far as I can tell, is gone. It didn't happen at all on Sunday, even with the highest temperatures Scatha is likely to see from here on. The context of the two instances on Saturday have convinced me that said limp mode isn't related to ESS or their programming, but is a residual BMW code that triggers when the car thinks it's in danger (heat+throttle load+RPM). Which means it's a good thing, since I shouldn't be running the car that hard that hot. I made the mistake of not checking my track pads before I went to swap them prior to the weekend, and they only had about 3mm of pad left. Oops! So this time out I put a spare set of HT-10s on the front and left the street pads on the back. From a safety standpoint it was fine, but I wouldn't do it again. The rear pads warmed up to operating temperature more quickly than the HT-10s, and this affected the brake balance for a time. Then I discovered that the HT-10s are just not quite enough pad (at least without HT-10s on the rear too) for that track and my driving, as I encountered pad fade at two points on the circuit per lap once temps were up. Of course if I had proper race-style brake ducts that would be a different story. And that may happen at some point. Until then I'm going back to my HT-14 front/HT-10 rear setup. One last comment: The StopTech 1mm Ti brake pad shields work AWESOMELY! This marks two events in a row with ZERO fluid fade, on a track where I would routinely get fade at one, if not two, braking sections. For the money they are a fantastic improvement and you can get them (or another brand's) for any BMW caliper. I'll post pics and vids as soon as I can process everything. You're not going to believe one of the cars that showed up (but didn't track). It's a one-of-one. Last edited by Palantirion; 11-08-2010 at 11:12 AM. |
#1679
Subscribed. VERY interested in the sidemarker upgrade.
#1680
-I won't be producing the side marker. The one I have is hand-built and they are only functionally relevant to a supercharged M that sees a LOT of hard track duty. To mold the piece would be very expensive and the market doesn't exist in sufficient quantity.
#1681
Pics and vids from the OCRC event: http://www.bimmerfest.com/forums/sho...d.php?t=499822
Scatha will be at Auto Club Speedway with Speed Ventures this Saturday. |
#1682
Are you going to be running Fontana Friday or Sunday, now that SpeedVentures cancelled Saturday? |
#1683
I don't know when Nathan's next event will be, but OCRC holds events roughly quarterly. To answer your other question, I went to Sunday, and saw you, so you knew that already. Thought I'd type it anyway :P |
#1684
Well, the holiday season has be VERY busy for me. Took a 9-day trip to Tahiti (I may post pics later) and am working on a new race car livery (details to come). I also relocated the ESS-supplied oil cooler from in front of the radiator to in place of the driver's side bract duct. I expect this will drastically reduce my water temps and still effectively keep oil temps under control. The only question in my mind is what, if any, effect there might be having different front brake cooling rates. I'll find out on the 15th, OCRC's next track event:
http://www.bimmerfest.com/forums/sho...81#post5758681 http://www.ocracecraft.com/ FYI: The same weekend Speed Ventures is running a two-day HPDE at Auto Club Speedway. http://speedventures.com/ A pic of the oil cooler in it's new position: |
#1685
You would not believe the changes in temperatures in high horsepower cars before and after removing cats. It's so easy to swap the headers at least just TRY it once, takes less then an hour to swap headers if you're good. Buy a set of ebays (normally I wouldn't suggest this), even paying for install you might be out 500$ if it doesn't work. I'm sure thats a fraction of the time and cost you have in the problem already. If that doesn't work nothing else but capacity is going to stop your car from overheating as much as it is.
http://www.youtube.com/watch?v=OqX7IIaXtkg Is it on a dyno? No. ![]() TCK d/a coilovers, Stoptech 6/4 piston BBK, OEM CSL headers Last edited by blau335; 01-10-2011 at 01:37 PM. |
#1686
DONE!
It's fixed, problem solved, mission accomplished, etc. Same track, hotter than the previous two events (ambient = 85F vs. 70F), driving as hard as ever. Previous oil temp (after diverter valve swap): 265 Highest oil temp today: 230! Previous water temp peak: 243 Today: 209! I also noted a significant reduction in AIT, from an average of 3-5F over ambient to 8-10F below. |
#1687
Good news on the engine cooling; I am guessing you did not feel much difference in the brake feel/ability with the differential cooling?
Euro headers w/relocated sensors|RPI scoop|K&N panel filter|KW V3s|OEM Strut Brace|RE RSMs|Zeckhausen CDV|SpeedBleeders|Stoptech Brake Lines|StopTech 4-pot BBK all around|SSR GT2-H 19x8.5/19x10|Potenza RE-11s Texas Mile (March, 2010): 155.4 mph |
#1688
Pal - biggest concern over FI is now a non-issue. If Nismo gets too fast I am pulling the trigger on the VT-1 system...
2008 ///M Coupe ================================================== ================================================== === CDV Delete | CSL Wheels | Super Sprint Exhaust | Strong Strut | RE-11's | Cosmetic Blackout | Super Sprint Stepped Headers 3.91 diff | Ground-Control Sway Bars | RRT Rear Control Arms | UUC Short Shifter | KW Club Sport | StopTech BBK | |
#1689
-The good news for VT-Series owners is that the versions that come with replacement oil coolers mount them in the brake duct. So no one should have any temp problems at all. |
#1690
Thanks Palantirion. That's great news that your issue is resolved and that VT owners may not have to go through the process you went through. Most of us don't have the resources you do/did to even get through issues over time.
Nismo is getting a racing limited slip diff this winter so he will def give us a run at the track. 2011 should be great - cannot wait for track season. Wish I was in California.
#1691
Got new tires mounted this morning. I'm switching, at least for now, to Kuhmo V710s. Even though they have less tread depth than the NT-01 they are supposed to physically wear better. They also come in sizes that slightly reduce the overall diameter, and I would like to see if I can keep my current ride height without shaving down part of my front fender liners. The V710s are also VERY light, 24.3lbs for the 285/30R18 and 22.3lbs for the 245/35R18. So mounted they are around 40-43lbs/corner. Not sure what my next event will be, probably Cal Speedway with Speed Ventures.
If anyone has tracked these tires before I'm interested in feedback and pressure suggestions. Last edited by Palantirion; 01-22-2011 at 10:06 AM. |
#1692
Hey if you don't mind me asking how much does you splitter stick out on the sides from the bumper? crfine88 is putting together a group buy with APR for a splitter very similar to yours and I really love the way yours looks.
![]() 07 Z4 M Coupe AW/IR |
#1693
In your post about the tires so you mean Hankook V710s? I can't find a Falken V710. I have been toying with the idea of giving the V710 a go so I am very interested to hear your review of them.
#1695
'03 Ford Explorer "the big girl" '6 330i "the Major" '06 Z4M Coupe "Strider" '07 Dinan 3 "little blackie" |
#1697
Btw, Scatha is now on Car & Driver's Backfires. Think of it as Facebook for car guys, kind cool. http://backfires.caranddriver.com/ph...ums/272/photos I'm on there as Earl Shepherd. |
#1698
The photos look really good!
2008 Z4M Roadster BMWCCA/ZSCCA Member |
#1699
-LOL, a C5 Vette is no match for an M Coupe, even N/A.
#1700
Do they run the same class as you do?
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Z4 M Coupe at NHIS | brave1heart | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 9 | 11-11-2006 09:52 AM |
| 335 news release today => 535 next year | klu123 | E60 (2004 - 2010) | 34 | 04-26-2006 03:35 PM |
| Z4 coupe wheel styles | Don L | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 6 | 03-28-2006 06:55 AM |
| Z4 Coupe design | Axcu | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 0 | 12-10-2005 02:17 PM |
| NEW BMW Z4 Coupe Video | OC-Z4 | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 9 | 10-07-2005 05:13 PM |
