Old 06-02-2012, 04:37 PM
Palantirion's Avatar
Palantirion Palantirion is offline
Z4 Mvangelist
Mein Auto: 2003 M5-S2, 2002 540iT-S2
I posted a separate thread about bushings here: http://www.bimmerfest.com/forums/sho...48#post6872448 but we can discuss my options in this thread too.
Old 06-03-2012, 09:04 AM
pal's Avatar
pal pal is offline
S54=Living on the Edge
Mein Auto: 2007 M Coupe, 2004 Audi T
Replied there as well - I switched rears to Rogue black poly RTABs last year and have been happy with them. Rear seems more solid under load - esp corner exits e.g., downhill right/left handers that really load up the outside rear.
Used new OE FCABs for the front as I could not find an offset bushing insert for our cars.
Euro headers w/relocated sensors|RPI scoop|K&N panel filter|KW Clubsports w/400lb Linear Rear Springs|RE RSMs|Zeckhausen CDV|SpeedBleeders|Stoptech Brake Lines|StopTech 4-pot BBK all around|BBS RGR 18x8.5/18x10|Potenza RE-11s
Texas Mile (March, 2010): 155.4 mph
Old 06-15-2012, 04:30 PM
Z4 Mvangelist
Scatha, at Coast MotorWerk's Huntington Beach location:
Because...
According to Jay at Ground Control, who examined full-res pics I sent him, this was not a sudden failure. He told me it looks like the bar cracked slightly, that this crack lengthened over time and then finally split quickly. The latter I can confirm noticing at the last OCRC event. As to the slow decay of spring resistance over time, I believe this was responsible for for the lag in rear end set response over the past year or so that I had thought due to failing RTABs. Jay was great to work with and sent me out a new bar free of charge, with a UPS return label so they can examine the failed bar to see how it happened.
So I had already ordered Rogue Engineering (blue) RTABs. I will disclaim now that they did not recommend the blues for a street driven vehicle, because the blacks are a little softer and don't transmit as much road noise or vibration. Scatha is not at all quiet, between the noisy TCK shocks, monoball sway bar end links and r-comp tires, so I saw no harm in going for the stiffer bushing.
New sway bar installed:
Note sway bar clearance with RTAB removed:
This is beyond "Duke's of Hazard" travel range. Note the rubbing marks on the axle shafts. This was from several years ago at BMS when we tried to set the bar to it's stiffest setting. It looked like it barely cleared on the rack, but rubbed slightly during test driving. So we set it back to the middle. In that pic you can also see the paint scratched off the lower arm from the broken sway bar's dangling end link.
Any idea whose product these are??? I don't. And they aren't marked. I wasn't at BMS when these were installed. I know BMS was making their own at the time, but the finished version of those was green. Anyway, these seem to have done their job ok. Still in good condition.
Removing the old RTABs. The technician Brandon (who was great btw) told me these were replaced from original, as they are a BMW part used for replacement not during factory installation. No doubt changed during the installation of the limiter bushings.
Bushings seem fine.
Rogue bushings installed:
Collar back on:
Back on the ground:
Alignment:
The car feels tight as hell now, which should surprise no one. I haven't had a chance to drive it hard on an interesting road yet, but expect to this weekend.
The next update will involve using commercial floor polish on the paint. Stay tuned for craziness.
Old 06-16-2012, 07:58 AM
tnsbruce's Avatar
tnsbruce tnsbruce is offline
///M Coupe Pilot
Mein Auto: '08 Z4M and '03 530i
I will need to inspect my sway bars. I am also toying with the idea of having RRT fabricate a bar for me that would allow full adjustment and clear the half shafts. Are you still using the original heim joints on the sway bar links? I had to replace mine front and rear due to pre-mature failure.
2008 ///M Coupe
CDV Delete | CSL Wheels | Super Sprint Exhaust | Strong Strut | RE-11's | Cosmetic Blackout | Super Sprint Stepped Headers
3.91 diff | Ground-Control Sway Bars | RRT Rear Control Arms | UUC Short Shifter | KW Club Sport | StopTech BBK |
Old 06-16-2012, 02:46 PM
Z4 Mvangelist
-Ground Control supplied new end links/heim joints with the new bar. The old ones seem to have no noticeable play in them. The end links are adjustable and it seems fairly straightforward to make the bar arms clear the half shafts.
p.s. There seems to be a slight increase in rear noise over bots dots and expansion joints from the blue RTABs. On my car it's barely noticeable, on a totally stock Z4 with OEM tires the blues would probably be quite bothersome.
Old 06-17-2012, 07:15 AM
pal's Avatar
pal pal is offline
I have the black RTABs on my Z4MC and can confirm that they are quiet even after about a year in there. Nice OEM+ improvement IMHO.
Old 09-07-2012, 06:24 PM
Spreadsheet Spreadsheet is offline
Mein Auto: Z4MC
Those white bushings look like Rogue Engineering's RTAB Limiting bushings, also sold at Vorshlag too. I had looked into them and once I have to replace the RTAB, then I plan on adding them. Seemed better application than Turner Motorsports aluminum version.
Hope this helps.
Old 01-20-2013, 02:07 PM
Andy1GP Andy1GP is offline
Mein Auto: '08 Z4MC '04 E46 330d
Very impressive and detailed thread! Well done and hats off for taking the time and effort. I applaud you.
I'm still reading through your extremely lengthy and entertaining thread. Just wanted to subscribe for future reference. Will introduce myself soon
Old 01-30-2013, 12:27 PM
Z4 Mvangelist
-Thanks Andy, nice to meet you.
Old 02-10-2013, 07:52 AM
Machinereplica Machinereplica is offline
Mein Auto: 09 Challenger SRT8 6M
I've only read through to page 37, but this thread has definitely helped me make up my mind. When I return home from Afghanistan I'm selling my Challenger SRT8 6m and getting a Z4M Roadster.
Old 04-16-2013, 08:50 AM
Z4 Mvangelist
Some pics from her Art Car thread, showing the hail that Scatha endured back in February.
And she got her picture in Car&Driver Magazine, due to a letter I wrote about the Blastolene guys and their take on art cars:
A few more weeks until Bimmerfest 2013! I'll be doing another casual painting demo on Scatha, changing some midtone colors on the driver's side. Hope to see some of you there.
And some light reading, as pertaining to future Scatha mods (no, she isn't done yet):
Old 05-29-2013, 02:03 PM
Z4 Mvangelist
My Bimmerfest writeup: http://www.bimmerfest.com/forums/sho...28#post7617328
Old 06-11-2013, 10:46 PM
Hoops432 Hoops432 is offline
Forever Fast
Mein Auto: '06 M Coupe, '08 K12S
Hey Earl. What's your current status on heat issues/limp mode on track days? A few of us throwing round radiator upgrade ideas here:
http://www.zpost.com/forums/showthre...=847633&page=3
2006 IBlue BMW Z4 MC (OZ spec) - ESS VT2-525 Supercharged, JRZ RS1 suspension (500#F, 600#R) with Vorshlag plates, ST Trophy BBK with CL R6E pads, KKS gated exhaust, TMS sway bars, RE rear camber arms, VT engine mounts, Recaro Pole Position (driver), APR GT wing, Street: Volk G2s and Potenza, Track: Volk TE37SLs and BFG R1s.
Old 11-21-2013, 09:45 PM
Z4 Mvangelist
-I haven't tracked it in a while, due to scheduling limitations, but back when I was tracking her a lot I would say that heat issues depended mostly on the track layout. Much more than ambient air temperature. That said I found that in all three situations I am thinking of I ended up "driving around" the problem by short shifting slightly or taking a couple turns 1 gear up. This not only fixed the problem in those situations, but also didn't lose me time due to the strong midrange torque of my ESS CFR500. The most vivid example I have is Cal Speedway, where I switched from using 3rd in the last three turns (near top RPM, steady throttle) to using 4th. In either case I hit 120mph exactly on the start/finish line so no time was lost and it was easier on the drivetrain.
In more recent news I had a car cover made. Not sure if that counts as a "mod". Details here: http://www.bimmerfest.com/forums/sho...01#post7971601
Old 10-13-2015, 12:23 AM
Z4 Mvangelist
Scatha will be getting a new battery, suspension and tires in the next couple of weeks. Unfortunately I will not be able to update Scatha's website mymcoupe.com because the domain company failed to notify me that my autopay didn't go work as my CC had changed. So it lapsed and now a Japanese domain company is squatting on it and trying to extort me to get it back. So doubtful mymcoupe will be returning.
As to the new mods...
First, I will be replacing the Oddessey 680 battery with a 16 cell Antigravity battery. While lighter and smaller than the 680 it also has much, much better memory so I won't lose cranking amps over time like the 680.
Second, Brett at Bullet Performance (actually now it's Bullet Motorsports as BP will be just for service) will be installing and setting up triple-adjustable MCS shocks and struts to work with my existing GC bars and TCK camber plates.
Third, I will be replacing my worn-out NT-01s with Hankook RS-3s.
I expect to have Scatha out at Willow toward the end of the fall with all the new kit.
Old 10-13-2015, 10:39 AM
dkl's Avatar
dkl dkl is offline
Mein Auto: E53 X5, E86 Z4MC
Sorry to see the website disappeared. It has been a great resource for mods ideas. Glad to see this thread is still around and getting updated, though
Old 05-31-2016, 06:07 PM
Z4 Mvangelist
-I may resurrect it under myz4mcoupe.com after I finish revamping myartcar.com. Just a matter of time, but time is increasingly hard to come by.
Old 05-31-2016, 06:13 PM
Z4 Mvangelist
I decided something at Bimmerfest, the morning of 5-28-16. In short it would go along with the time honored phrase: "The King is dead. Long live the King."
More specifically, I will say that in the as-near-as-I-can-make-it future Scatha will become Scatha Mk.2. If you saw me working at Bimmerfest then you already know what I'm talking about.
First I will need to test alternative clearcoat methods to ensure maximum long-term durability of the paint. So in the near term Scatha will get uglier before she gets prettier.
More to come...
p.s. Some new exhaust mods are a week or two away. After which I hope to be able to track her with the new suspension and tires.
Similar Threads
Z4 M Coupe at NHIS brave1heart E85 / E86 Z4 (2003-2008) 9 11-11-2006 10:52 AM
335 news release today => 535 next year klu123 E60 / E61 (2004 - 2010) 34 04-26-2006 04:35 PM
Z4 coupe wheel styles Don L E85 / E86 Z4 (2003-2008) 6 03-28-2006 07:55 AM
Z4 Coupe design Axcu E85 / E86 Z4 (2003-2008) 0 12-10-2005 03:17 PM
NEW BMW Z4 Coupe Video OC-Z4 E85 / E86 Z4 (2003-2008) 9 10-07-2005 06:13 PM
