Old 02-02-2007, 06:48 AM
jelliotlevy jelliotlevy is offline
Mein Auto: 2011BMW 335i, Honda S2000
How do our E90/E92 thermostats work?
I am on another tear to figure out how the sophisticated subsystems in our Bimmers work. I first checked out How Stuff Works:
http://auto.howstuffworks.com/question248.htm
That link describes the conventional wax thermostat, which has appeared in most of the cars I have owned, including my original, and much beloved (for sentimental reasons only) 1953 DeSoto. I am not sure how many 2006/7 model cars still use that old approach, but I seem to recall reading somewhere that our thermostats are electrically controlled. I can certainly imagine a combination of temperature sensor, actuator motor or solenoid and movable valve working in concert. To be candid, that is merely a guess, and Idon't really know how our Bimmers do it - and How Stuff Works seems to have let me down.
Surely, someone in this august and supremely knowledgable Bimmerfest group knows the real answer, and will lead us to it. Please do not respond in this thread unless you are august and supremely knowledgeable.
Old 02-03-2007, 03:57 AM
killcrap killcrap is offline
Mein Auto: BMW
i am only modestly knowledgeable.
the n52 thermostat and water pump are 1 unit. the water pump is fully electronic and not driven by a belt. the thermostat is conventional mechanical. when the coolant temp is high enough, the dme will activate the electrial porition of the thermostat to open the thermostat further.
Old 02-03-2007, 06:28 AM
And I am old enough to remember those days when you could, for a couple of bucks, buy a thermostat, a gasket and a small bottle of gasket goo, and change the thermostat yourself with about 10 minutes of labor. Of course I also remember my 1964 SAAB, which came with two thermostats: one red and one green. The thermostat went in line in a primary hose. You had to undo two clamps, insert the proper thermostat (165 degrees, green, in the summer; 180 degrees, red, in the winter) and re-fasten the clamps.
Having the water pump in a non rotating mode during warmup must certainly speed up that process. Changing an E90/E92 thermostat is most likely a job for those high priced auto surgeons in their white coats.
Old 02-03-2007, 07:24 AM
move.over's Avatar
move.over move.over is offline
Mein Auto: 325cic
Here is interesting thread http://forums.vwvortex.com/zerothread?id=2993477 on how to change a electronically controlled thermostat.
2014 Mazda 6 GT Liquid Silver
2007 335I, " Gray", Black Leather, Step, Comfort, ZCW, ZPP, ED - Oct 5, 2006. Gone but not forgotten.
2004 325Cic Titanium Silver, Gray Leather, ZPP, ZSP, ZCW, HK Sound, BiXeon, Al Column Trim. aka "Slvr Sun"
Old 02-03-2007, 08:23 AM
jmonier jmonier is offline
Mein Auto: 07 335i E92, 02 325i
The electric coolant pump is actually controlled to adjust the engine temperature. It doesn't even run until the engine is warmed up. Under these conditions I'm not even sure that there is need for a thermostat.
Old 02-03-2007, 10:19 AM
spots's Avatar
spots spots is offline
kid hater
Mein Auto: '07 328
That would be my view on it as I believe they would duty cycle the pump to achieve the desired thermostatic effect.
'07 328 Alpine white, ED Oct 10-18/06 Redelivered Dec 12/06.
Old 02-03-2007, 12:16 PM
That thread makes scary reading. I am sure everybody knows that the VW Phaeton and its incredibly expensive and complicated W12 engine no longer can be bought in the USA. Quite an operation to change that thermostat, and the part apparently costs about $400. That Phaeton was VW's notoriously unsuccessful attempt to compete with Mercedes high end.
Old 02-03-2007, 01:39 PM
There's a lot of info in the documents in this thread:
http://www.e90post.com/forums/showthread.php?t=38856
They actually adjust the head temperature in four different increments according to how hard you're driving.
Similar Threads
The X3 goes to work...yard work mguhler X3 E83 (2004 - 2010) 7 06-09-2005 09:01 PM
Ever work with a co-worker thatís not worth a f..k? Alamo Off-Topic 28 04-03-2005 07:23 AM
ED and US Work Visa gsko European Delivery 7 03-01-2005 11:04 PM
dealership work allaboutme E46 (1999 - 2006) 1 02-25-2005 03:01 AM
t Nick T. The Test Board 5 07-05-2003 09:25 AM
