E30 (1982 - 1993)
Old 03-12-2011, 12:49 AM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Originally Posted by ForcedFirebird View Post
3 out of 4 locals, two of which were done by me (one leaks, the other doesn't). Tons of threads on r3v and e30tech about it after I had the issue and searched.
Head off my car came off a running car, didn't machine it, but will see how flat it is when it comes back off.
Front passenger corners on all 3 that are leaking.
Houston we have a problem.
You of all members I would have had more confidence you would have milled your head or at LEAST straight edged it with a feeler gauge for trueness.
The VR Gasket is fine, the problem most people have is they don't follow the service guidelines.
You MUST have the head cleaned,milled and tested for proper seal and inspected for defects.
You MUST chase your threads with a tap until they come out CLEAN.
You MUST use a NEW gasket and NEW torx type bolts and use an angle gauge or similar tool to ensure exact tightening procedure is followed.
Do these and you won't have an oil leak on the front corner next to cyl #1
Old 05-14-2011, 04:12 PM
ForcedFirebird's Avatar
ForcedFirebird ForcedFirebird is offline
Mein Auto: 1986 327is
Had a spare head milled .010" and got the .051" custom gasket, so parts are here and ready to go once there's time to set aside for it.
So, we sent the white Camaro over to paint a couple weeks ago and will be back Monday and they are picking my car up to go back in the booth
Spent a couple hours on it today, got the side skirts permanently mounted so they can be molded properly, new pass side bumper filler, and got her just about stripped down of trim to go to the booth. My painter wants to change up the color scheme a bit, let's see what he comes up with. He said since he is painting the F/R valences and skirts, will block the whole car down, skim where needed and spray the whole thing again. Love having good friends! I want to stay with Delphin, he wants to go to gun metal, but there's nothing uglier than a non-matching engine bay, even thought the jambs and all will be re-painted this time.
Anyways, gonna shave the antenna hole tomorrow and use the rear defroster as the antenna, live in FL and don't need the rear def much lol.
Anyways, here how she sits now...
Old 05-15-2011, 06:15 PM
Now you see it...
Metal welded in...
Now you don't (just primer for rust protection, not a body man haha)...
Old 05-15-2011, 06:43 PM
Kamakazi21 Kamakazi21 is offline
Cool Story, Bro.
Mein Auto: '87 325i, '68 Nova
Now you see it...
Poof. It's gone . . .
1991 318is (Daily Driver)
1983 E21 320i (Chumper)
1968 Chevy Nova/Chevy ll (383 stroker)
Old 05-15-2011, 09:48 PM
Antenna got Hadouken!
Old 05-22-2011, 02:47 PM
I happen to like the aluminum bumpers on the early cars, the polisher sent me some cell pics of how they are coming out
Old 05-25-2011, 12:49 PM
e^2 e^2 is offline
Mein Auto: '84 325e, '00 323i
Clean. Going to re-clear those bumpers?
Old 05-25-2011, 05:42 PM
Probably not. I would rather deal with keeping them waxed, instead of worrying about the clear sticking to a polished surface. The polisher already complained about having to remove it lol.
Went by the paint shop today, the manager there is one of my best friends and their cut off switch went on the main compressor - compressor repair guy quoted $500 to repair it and they about flipped a lid, went and checked it out, told them what to buy and will go back tomorrow to hook it back up, the shop owner said now I don't have to pay for the materials even, lol.
Entire car has been blocked, all nicks and bruises taken care of, going in the booth tomorrow! Can't wait
Old 05-26-2011, 10:07 AM
e^2 e^2 is offline
Good karma
Done anything to the bird recently? I discovered I make 260/360 HP/ft.lbs to the wheels with a smog cam in my 454. Lol. 330 lift and -40 overlap.
Old 05-27-2011, 01:26 PM
lol. A friend of ours made more horsepower from an N/A 3.5l v6 that was in his Cavi Z24, ran 13 flat, now he just put ITB's on it and transferred it to a Camaro.
No, bird has been sitting. Sold the TT motor, don't have anything planed ATM
Forgot about this cell pic when they started blocking the car, should be painted by now.
Old 06-07-2011, 11:37 AM
Painter got slammed with work, so the "free-bee" job got set aside
In the meantime, made the 3rd collector for my headers and sent a file over to the water jet for the header flange I designed...
Old 06-08-2011, 09:10 AM
e^2 e^2 is offline
Looking good. How did you make the angles on the collectors? Dye and water trick?
1984 325e
2000 323i
Old 06-08-2011, 10:10 AM
Laid one 18 degree bend on top of the other and got a tick mark of where the merges would meet. Next, put them on the band saw and ripped them down. Then welded the two halves solid, finally cut the end off and added a piece of straight pipe to the ends.
There's a youtube video that shows how a merge collector is made, I used the same process.
Old 06-08-2011, 06:48 PM
Had to order materials to make an m50 turbo manifold for a local, so added the few more pipes needed to the order...
Old 06-17-2011, 06:36 PM
The body guy has been blocking and priming the car for two days.
Also the flange is done for the header...
Tried making the 3-1 merge, but it was more difficult than I though with the band saw, it's a 14" Jet - too small really for the task, so I nabbed a metal cut off saw and will be making a jig to cut the pipes properly.
Hopefully will have some more updates soon...
Old 06-18-2011, 11:25 AM
Well was at the shop till 2am working on a jig for the new saw. Got all the angles figured out, but have to finish this 2.7i before I can work on the last collector. My car just got the first base-coat at the paint shop, he's gonna sand it again, apply 2nd base and clear early next week so - then the actual tubing can be mocked up - FINALLY!
Old 06-18-2011, 04:45 PM
Well, I got the collector tacked and couldn't wait to show it. Stupid 10hrs engineering this stupid thing, I'll let the pics do the talking. Have to weld it solid, trim both ends and weld the expansion pipe on, but whatever, $280 saved on Burns in favor of 10hrs, ftl, but now I know how to make them FTMFW!...
Old 06-18-2011, 05:48 PM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
thats alot of work my friend...
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 06-18-2011, 05:58 PM
6-3-1 collector...
Old 06-18-2011, 07:00 PM
mdarosa54's Avatar
mdarosa54 mdarosa54 is offline
Mein Auto: 1987 325e
nice work, bad luck huh ? lol aye but at least u didnt give up nice find good luck with everything
Old 06-18-2011, 08:02 PM
eieio4tn's Avatar
eieio4tn eieio4tn is offline
BMW...riceless
Mein Auto: 1987 325is
good work. nice to have skillz, ain't it.
Old 06-20-2011, 09:11 AM
lol. Got something, don't know if it's called skills or persistence.
Pleased with the final result, though...
Old 06-22-2011, 12:57 PM
Car is painted, time to put her back together
Old 06-22-2011, 01:10 PM
mdarosa54's Avatar
nice color
Old 06-23-2011, 11:26 AM
e^2 e^2 is offline
Delphin ftw! Your 6-3-1 looks good but a bit large. Where are you going to fit that?
1984 325e
2000 323i
Similar Threads
Wall Street Journal Article on BMW's Past, Present and Future Salvator General BMW Questions 65 12-25-2010 08:22 PM
BMW's Embarassment Malibubimmer General BMW Questions 27 11-20-2005 09:35 PM
More Goodies from BMW's Telematics mojosaan General BMW Questions 1 10-14-2005 01:52 PM
new bmw's sucks? fricas 5 Series 16 12-16-2004 11:55 AM
of all european cars, why do BMW's seem to attract the cheesiest modders? bmw325 Off-Topic 23 01-03-2003 10:15 PM
