E46 (1999 - 2006)
Old 02-07-2007, 01:51 PM
BeanerManWheels BeanerManWheels is offline
Mein Auto: 1999 323i sport
Codes p1250 p0304 on a 1999 E46 323i Help please
Hi All,
Initially I was gettin p1250 and p0304 and p0303 and p0305,
So I replaced the Injectors for Number 3 4 and 5 cleared the codes and it ran for about 2 hours then P0303 came back, I swap the coils as well, (that was last week)
Today I am getting p1250 and p0304, Now the check engine light comes on for a while and then it goes off,
I noticed the following: (I keep a pocket odbII in the globecmpt) If I erase the codes, the car runs Great for about an hour or less, then the moment the light comes back on, it runs like ($%#t)... I know the problem is not the Injectors or the pistons since I also checked the Chamber Preassure.
Has anyone experience this?? BTW ( I am not a professional mechanic but I know my way around my cars) I have heard rummors that this bmw model has this glich, (that it could be the gas cap, or the Fuel filter, or a Vacum leak, promting the code of misfire therefore the computer cuts off the power to that plug, I guess to avoid greater damage to the block)
Also someone told me that there is a sensor located between the flywheel and the transmition, and that because of its magnetic nature, they go bad? (what sensor do you think he was talking about?
Please share with me if you have had this experience or if you might know what else to check??
Old 02-07-2007, 02:33 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
P1250 is Manufacturer Controlled Fuel And Air Mixture..... My wild-ass-guess would be the MAF.
Old 02-07-2007, 04:03 PM
Is there a way to test the MAF?
Old 02-07-2007, 06:37 PM
oxford oxford is offline
Mein Auto: '01 Z3, '03 330i
Originally Posted by BeanerManWheels View Post
...Also someone told me that there is a sensor located between the flywheel and the transmition, and that because of its magnetic nature, they go bad? (what sensor do you think he was talking about?
Someone probably was talking about the crankshaft position sensor. It will set its own code if it goes bad.
Old 02-07-2007, 06:42 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
... I believe you can try cleaning it... google 'clean MAF'.
Old 11-01-2008, 02:05 PM
dtbmw dtbmw is offline
Mein Auto: 99 323i
Question P1250 and P03030 codes
Anyone got it fixed. May car's check engine light comes on with shaking. I switch off and switch on the everything goes normal. Any clue??
I got it scanned at Autozone and they told me P1250 and P0303 codes. I had recently relplaced spark plugs (NGK OEM)
Old 05-21-2010, 03:07 PM
mrthomas mrthomas is offline
Mein Auto: bmw 323i
me too... in my 323i 1999 I have been hunting down this p300 and now the p1250. changed spark plugs, coils,fuel filter, evr and cleaned intake manifold adjuster. the p1250 points specifically to fuel pressure regulator and at this point that is the only component that could cause both the p1250 and the p0300 random misfire. anyone think different?
mr thomas
Old 05-22-2010, 02:52 AM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
mr thomas
check your mass air flow meter... remove it and then clean it.
mujjuman
Old 03-12-2015, 08:39 AM
Meghanleah Meghanleah is offline
Mein Auto: 328i BMW 1997
I had the same problem, did you ever find out how to fix it?
Similar Threads
Help with 1999 323i E46 SEL problem lovemy99323i E46 (1999 - 2006) 2 12-12-2010 06:16 PM
My E36 v. E46 thoughts (very long) JST 1M & M2 49 12-18-2006 12:45 PM
post all the typical 1999 E46 quirks! cyclone221 E46 (1999 - 2006) 15 12-09-2006 10:24 AM
1999 E46 323i ZSP manual AW stressdoc Cars - Private Party 1 10-09-2006 04:19 PM
How to Reset Service Indicator for 1999 E46 Bimmer4life E46 (1999 - 2006) 9 06-05-2006 04:20 PM
