Old 02-07-2007, 10:54 PM
kjboyd's Avatar
kjboyd kjboyd is offline
Drink the koolaid or else
Mein Auto: 2015 X1 sDrive XLine
Infamous Sunroof Rattle
My sunroof rattle has finally gotten to me. Can those of you who have had it "fixed" tell us if it really has been fixed? and what the solutions were? I think in my case, the whole cassette needs to be changed out, and with less the 7 months of owning it and less than 5,000 miles, i hate to see it go thru major surgery like this...
Kevin
2015 X1 sDrive XLine - "Hamilton Maxwell"
2009 MINI Cooper Clubman - "Oxley"
2007 Volvo S60 2.5T
2007 X3.0si PlatBronze/Beige
2006 X3 3.0i, Flamenco Red/Beige
1997 528iA, Oxford/Tan
1994 318iS, Black/Gray
1979 528iA, RubyRed, Tan
1971 2002, Sahara, Saddle
Old 02-08-2007, 07:15 AM
crazybelgian's Avatar
crazybelgian crazybelgian is offline
Mein Auto: 2006 X3 3.0
15,000 miles and no rattle... I would definately get it fixed if it happened to me though
2006 X3, Jet Black/ Terracotta
1986 325es, Red/ Black
"The greatest tragedy in mankind's entire history may be the hijacking of morality by religion."
Arthur C. Clarke
Old 02-08-2007, 09:54 AM
AzNMpower32's Avatar
Tar Heel Faithful
It's clearly a known problem on X3s, and there is a service bulletin out on it (I cant find it anymore). If your dealer claims ignorance, then go somewhere else. I think the first fix is to replace the liner or something, not the whole cassette.
Old 02-08-2007, 10:27 AM
ub6ib9 ub6ib9 is offline
Mein Auto: '04 BMW X3
happened to me and got the cassette replaced... nothin big
Old 02-08-2007, 11:24 AM
brh_minn brh_minn is offline
Mein Auto: 2007 X3 3.0si
Can someone elaborate a little on this topic? I have a 2007 X3 with the Pana sunroof, adn there is a "creaking" sometimes towards the back right of the sunroof, but not very loud, and I wouldnt describe it much as a rattle, more a creak of sorts.
Just wondering if this could be the same thing. It disappears when the roof liner is closed.
Old 02-08-2007, 04:03 PM
MPBX3 MPBX3 is offline
Mein Auto: 2004 X3
Had it fixed on the 04 about 2 months ago. Not sure what they did, but it worked.
Old 02-09-2007, 08:18 AM
MTLX3 MTLX3 is offline
Mein Auto: 2007 X3 3.0si Step PP
As per my BMW salesman, this should not be an issue on 2007 X3's as it was a known issue that was part of the 2007 "improvements".
2007 X3 3.0si, Silver Gray with Tobacco leather, Premium Package, step.
Old 02-10-2007, 01:21 PM
White05X3's Avatar
White05X3 White05X3 is offline
Mein Auto: 12 328i ED & 11 328i ED
I had a rattle in my pano roof when closing the doors and a creaking towards the back over rough roads. My solution was simple and seems, so far to have worked...
Buy some self-adhesive weatherstrip foam at your local home improvement store. Tilt the roof up. There is a black plastic piece that runs across the car and separates the two roofs. Stick the foam inside there, toward the front. Then, on the back part of the rear glass, in the corners, put another small piece on each side. This seems to have cured mine.
Good luck!
Old 02-10-2007, 01:29 PM
kjboyd's Avatar
HI WhiteX... actually, i tried that but didn't work. this is on both sides front, and if you press the headliner up, it stops 'creaking'. so im guessing the whole cassette isn't screwed down tight enough.
i have an appt. on next monday, so ill let everyone know what is done. thanks!
Kevin
2007 Volvo S60 2.5T
Old 02-10-2007, 04:25 PM
White05X3's Avatar
Please do keep us informed. Sorry my easy solution did not work out for you!! Good luck!
Old 08-03-2007, 03:14 PM
wallyk525 wallyk525 is offline
Mein Auto: BMW X3
2005 X3. I took it to my dealer and they finally agreed with me and had the whole sunroof replaced with a newer version (2007) including the glass and track system.
Old 08-16-2007, 11:18 AM
Wolfie Wolfie is offline
Mein Auto: 2006 X3
I have a 2006 X3 for about a month now 15K miles. I just started to notice the sunroof rattle. It only happens when I'm doing 60 or more MPH. It rattles and goes away and only when the winds it a certain way. I can't tell if it is the big glass or the small one. Is this the IMFAMOUS RATTLE I have been hearing or is it normal?
Old 08-17-2007, 05:13 PM
sterfrydude sterfrydude is offline
Mein Auto: 2004 x3 3.0i 6sp
Ok, I'm not sure if I really have the same problem or what, but my roof doesn't seem to rattle. I just have a lot of wind noise at the front of the sunroof like it isn't sealing well. Can anyone tell me how I might resolve this as i'm out of warranty.
Old 08-17-2007, 07:33 PM
Mein Auto: 2006 X3
My opinion is if this a known recalled problem BMW should fix these problems for free!
I would take it in and demand they fix it! Can't hurt to try!
Good luck!
Similar Threads
Sunroof rattle kaptaingus E60 / E61 (2004 - 2010) 12 03-15-2010 12:55 AM
Infiniti G35 a reliabilty nightmare. Kayani_1 E90/E91/E92/E93 (2006 - 2013) 107 11-17-2007 12:33 PM
Sunroof Rattle - FIXED x3drive X3 E83 (2004 - 2010) 11 05-15-2007 07:47 PM
Sunroof Rattle 2005 X5 JoelF X5 E53 (1999 - 2006) 0 11-29-2006 08:41 PM
So what could this rattle be? llando88 3 Series & 4 Series 2 03-19-2004 07:22 PM
