E36 (1991 - 1999)
Old 02-08-2007, 01:13 PM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Oil leak...but where???
I am getting oil spots on my drive and my parking space at work. Not much but is still a leak somewhere
I looked under my car just now and although most of it is bone dry, there is oil right down the centre of the engine underneath. it looks like to is coming from the front of the engine between the sump and the BIG pulley.
I checked my engine oil and that seems fine. i had a power steering leak about a month ago, but my mechanic said it was sorted. there seems to be quite a bit of oil on the underside of the car...but where is it coming from?
The oil seems to be quite clean and not black like engine oil (that has been used of course)
I attach pics to show what i mean
Any ideas??
ID:	97829   Click image for larger version
ID:	97832   Click image for larger version
330i M-Sport in Topaz Blue
Edirty6 for life
Old 02-08-2007, 04:16 PM
Conehead Conehead is offline
Go you Good Thing
Mein Auto: e36 316I M
Hmmm...Pirate.
Nasly leak....almost as bad as the leak in my wallet after my wife and kids get hold of it, but.....................
There only to things that come to mind,
1. Maybe a sump gasket has died and started to leak around the pully area. The air at the front of the engine would be enough to blast it over everything like it has.
2. The seal around the shaft of the pully itself has failed (I am asuming this as I cant see all of the pully and if its attached or connected by a shaft to maybe the crank)
Hope this helps.
The best predictor for future behaviour, is past behaviour. ALSO, IT SHOULD BE NOTED:......AMATURES BUILT THE ARK..AND PROFESSIONALS BUILT THE TITANIC..................QUOTE FOR THE DAY.. Good drivers know how to get out of trouble, and better drivers know how to avoid it.....The Cone 2006 & 2007
Old 02-08-2007, 04:40 PM
mpowerrcr mpowerrcr is offline
Send a message via AIM to mpowerrcr
Mein Auto: 1994 325i, 2006 mcs
you should steam clean the bottom of the car put in engine dye drive it for 100 miles and look again with a black light that should tell you whats the problem
Old 02-08-2007, 05:31 PM
PJBIMMER's Avatar
PJBIMMER PJBIMMER is offline
<<<Buddy
Mein Auto: 97' 328I
Is there a front seal? can you replace it from just taking off pulley?
PJ
Old 02-09-2007, 01:16 AM
Still here
Mein Auto: M3
Thanks for the suggestions guys
Will put her up on the ramps tomorrow and have a look
Odd thing is that i really dont seem to be losing engine oil. at least not that much, i would say maybe 1cm off the dipstick
Edirty6 for life
Old 02-09-2007, 02:40 AM
DominguesE30's Avatar
DominguesE30 DominguesE30 is offline
BMW FETISH!!!
Send a message via MSN to DominguesE30
Mein Auto: `97 BMW 318is
LOL pirate my e36 suffered this too. We took it back and the guy rekons its notorious for them to leak. Apparently its a 2 dollar gasket on the timing belt or someplace near.
Hope this helps u man. I would check it
MADEINDEUTSCHLAND
`00 BMW e46 330i
`97 BMW e36 318is
Beeeeeeeee Eeeeem Double-YOU!!!!
Old 02-09-2007, 02:51 AM
Still here
Mein Auto: M3
Cheers buddy, will check it tomorrow.
Know it cant be too serious as there is no loss of performance or MPG and the engine oil seems to be pretty constant
Edirty6 for life
Old 02-09-2007, 03:20 AM
BMW FETISH!!!
yeah but oil leak isnt to pretty man. And if ur mates find out they will bag the ****s outtah ur bimmer. Mine is oil leak free now
MADEINDEUTSCHLAND
`00 BMW e46 330i
`97 BMW e36 318is
Old 02-09-2007, 03:24 AM
Still here
Mein Auto: M3
LOL, my mates all drive bimmers or know better than to say anything derogatory against it!!
Will be fixed within 24 hours anyway
Edirty6 for life
Old 02-09-2007, 03:26 AM
BMW FETISH!!!
nice, see my mates hate bimmers. And if they find anything they will hang it on me for months!
MADEINDEUTSCHLAND
`00 BMW e46 330i
`97 BMW e36 318is
Old 02-09-2007, 03:27 AM
Still here
Mein Auto: M3
that sucks!!!
Edirty6 for life
Old 02-09-2007, 03:32 AM
BMW FETISH!!!
yeap, sure does. They used to hang it on my e30 big time! But ever since i got the e36 they have shut up
MADEINDEUTSCHLAND
`00 BMW e46 330i
`97 BMW e36 318is
Old 12-26-2007, 03:26 PM
E36youngster's Avatar
E36youngster E36youngster is offline
blank
Mein Auto: 07 e92 335i
hey pirate, what exactly was the part that needed to be replaced? sorry to bump this back up to the top, but i'm having the same problem
Old 12-26-2007, 05:24 PM
PJBIMMER's Avatar
<<<Buddy
Mein Auto: 97' 328I
It was the seal behind the crank pulley.
PJ
Old 12-27-2007, 02:12 PM
Still here
Mein Auto: M3
I had to replace the hub too
Number 6 - http://www.realoem.com/bmw/showparts...35&hg=11&fg=18
Edirty6 for life
Old 12-27-2007, 08:35 PM
blank
thanks!!
Old 12-31-2007, 08:17 PM
ajestavillo ajestavillo is offline
Mein Auto: e36 325i
sorry, but i have to ask. what particular seal did you guys replace, aside from the hub. thanks.
Jerome
Similar Threads
06' 330i first oil change....yeah... yzandrl E90/E91/E92/E93 (2006 - 2013) 49 08-01-2008 10:47 AM
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
330ci convertible oil leak rear passenger side topless330 E46 (1999 - 2006) 1 03-05-2006 06:40 PM
Oil change Guest84 Off-Topic 1 04-30-2002 06:15 AM
