Old 02-12-2007, 01:40 PM
roadie's Avatar
roadie roadie is offline
Mein Auto: X5 3.5i, 911C4, C230
Has ANYONE had problems with Autozone Duralast battery with only 850cca
I am about to buy a Duralast battery from Autozone for my 2001 530i.
It only has 850cca vs OEM spec of 875cca.
Has ANYONE ever had problems with this battery - especially with cold starts?
Should I worry about the extra 25 cca?
I live in frigid boston area...
______________________________
2012 X5 3.5i
Porsche 911 Carrera 4
Retired but not forgotten:
2007 530xi
2002 530i
1999 ML320
1999 728i
1998 318ic
1997 520i
1997 C230
1996 325i
Old 02-12-2007, 02:07 PM
Asharus's Avatar
Asharus Asharus is offline
Send a message via ICQ to Asharus Send a message via AIM to Asharus Send a message via MSN to Asharus Send a message via Yahoo to Asharus
Mein Auto: 2011 WRX
Nope
Old 02-12-2007, 03:21 PM
e3niner's Avatar
e3niner e3niner is offline
oOO (|||) (|||) OOo
Mein Auto: 1991 318is, 1998 528i
Good battery for the price. No issues to report.
Old 02-12-2007, 05:41 PM
chivas's Avatar
chivas chivas is offline
You Lick It, You Own It
Send a message via ICQ to chivas Send a message via AIM to chivas
Mein Auto: 98 540i/6
i'm having problems right now but i think it's because i didn't install it properly. going to get mine exchanged and do a reinstall to see how it goes.
americandan.com
It takes a lot of work to be lazy.
Old 02-12-2007, 06:02 PM
flyboyy's Avatar
flyboyy flyboyy is offline
I glow in the dark
Mein Auto: 2003 BMW 530i
make sure you tighten it real well, cuz I had issues...first time around ...if its a little loose sometimes it wont crank up the car, scared the shiet out of me, I thought i had other problems, but I went to re-check the connections and boom...i found out that my connections was looose on the positive and negative bolts. now its working flawless.
Old 02-12-2007, 07:11 PM
Hotswimmer Hotswimmer is offline
Mein Auto: '98 BMW 540iA
From what I've read elswhere on the web, Duralast batteries are made by Johnson Controls, and are among the best out there right now. No, you needn't worry about the slightly lower CCA's.
Old 02-12-2007, 07:24 PM
chivas's Avatar
wish that was it... i had my portable jump box and it didn't start the car. kinda pissed. going to get a new one tomorrow.
americandan.com
Old 02-12-2007, 09:11 PM
roadie's Avatar
hmmmm....not confidence inspiring....
Am thinking I should just go OEM?
is it a cold weather thingy?
2012 X5 3.5i
2007 530xi
2002 530i
1999 ML320
1999 728i
1998 318ic
1997 520i
1997 C230
1996 325i
Old 02-12-2007, 10:02 PM
RiDE's Avatar
RiDE RiDE is offline
ZOMGHI2U
Mein Auto: 2003 525i
I have the same batery, except badged as Bosch. No problems so far.
For what its worth, it's almost 4lbs lighter than the Douglas one.
Old 02-13-2007, 11:11 AM
roadie's Avatar
chivas - do you have an update?
2012 X5 3.5i
2007 530xi
2002 530i
1999 ML320
1999 728i
1998 318ic
1997 520i
1997 C230
1996 325i
Old 02-13-2007, 12:35 PM
chivas's Avatar
went in.. gave them my phone # and the old battery and they gave me a new one. no questions asked.
installed it in the parking lot and BAM... not a single problem. i might have gotten a defective one, not sure since i was doing some testing and the OBC was registering 12.1V when the car is turned off (with radio and V1 on) and when the car is running, the alternator is pumping out 13.9V. *scratches head*... yeah... me confused too.
americandan.com
Old 02-13-2007, 01:50 PM
Asharus's Avatar
Mein Auto: 2011 WRX
My brother had a problem with it too (99 740i). He said that he just went there and swapped it out, and no problems since. However he did trade his car in for a Jeep since then.
Old 02-13-2007, 02:28 PM
flyboyy's Avatar
I glow in the dark
since these battery has a warranty on it , all we have to do is bring in our reciept and say that the battery def ? and they will replace us with a new one ?withn the warranty time frame ?
Old 02-13-2007, 04:48 PM
chivas's Avatar
2 year warrenty and when you buy the battery, you give them your phone #... it's recorded and they'll pull up their records when you bought it to offer you the warrenty.
americandan.com
Old 02-13-2007, 05:19 PM
KeithS KeithS is offline
Mein Auto: '11 335d, '17 340iGT
Works fine for a V8, no problems for a 6er
I have the exact same battery installed in my 540iT, and it's plenty cold here in NJ. Works fine for a V8, certainly no problems for a 6er. Had it installed for 18 months now. With all of these Autozones installed it's not unusual to have a few go bad. I'm sure just as high if not higher percentage of the real expensive OEM batterys go bad early as well
Old 02-13-2007, 06:09 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
I'm sure the Autozone battery is fine, but if you are sweating the 25CCA's...you can get an oem equivalent battery made by East Penn. They are sold at Batteries Plus stores under their private label brand. Batteries Plus has a store in Woburn and Marlborough, I just checked. I paid $93.99 for mine. I bought the standard "flooded" design, but they also make a Absorbed Glass Mat battery at 900 CCA that is claimed to have a longer life, but costs another $25 or so at Batteries Plus.
Here are some links:
http://www.eastpenn-deka.com/assets/base/0379.pdf
http://www.batteriesplus.com/t-storeloc.aspx
Old 02-13-2007, 08:33 PM
roadie's Avatar
Thanks everyone....
I will try the autozone...
2012 X5 3.5i
2007 530xi
2002 530i
1999 ML320
1999 728i
1998 318ic
1997 520i
1997 C230
1996 325i
Old 02-13-2007, 09:00 PM
matt24 matt24 is offline
Mein Auto: '99 528i Sport
I'll pile on here. I'm on about 4 weeks with my $60 Duralast 49-DL. No problems that I can tell...knock on wood...A couple of 20 degree nights put an end to the OEM Bimmer-battery in my 528.
Old 11-20-2010, 10:58 AM
Mopar Mopar is offline
Mein Auto: BMW,MERCEDES,MOPAR,CHEVY,
Duralast
Well......it appears that im a bit late replying to this (only 3 years,Ha) But i have had very good luck with duralasts,on my 69 superbee, i have a 14 yearold duralast, still going strong, a 16 yearold on my 67 chevelle a 13yearold on my buick,and alot more that i dont fell like listing......I dont have any BMW's at the moment, but i plan to....
Old 11-20-2010, 07:13 PM
Unfortunately if they are that old, it is unlikely Autozone uses the same vendor for their batteries, and even if they did, unlikely using the same construction techniques. In addition, there are pretty large variations in performance and quality within sizes (just check the differences in Consumer Reports), so unless any of them are Group 49, again the information may not be helpful.
540 M-Sport package (Canadian market), factory Bluetooth phone kit, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, H&R 15mm spacers, Bilstein B14 PSS coil overs, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 11-20-2010, 08:55 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
These references might be useful to the OP:
- What battery (1) & what battery maintenance (1) & battery replacement DIY (1) (2) & how NOT to change it (1) (2) (3)
Old 11-20-2010, 08:57 PM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
Regardless, the Autozone battery is good and they back it as well.
94 530i sold (That was difficult for me)
01 530i >144,500+ miles SOLD
06 330XI winter's especially fun drive (SOLD)
10 M3 Sedan (sweet)
13 Nissan GT-R Black Edition
14 Porsche Cayenne Platinum Diesel
15 Porsche GT3
16 Porsche GT4
BMWCCA 4215
Similar Threads
E46 Replacement Battery Info Here Weaselboy Do-It-Yourself H.Q. 106 12-29-2014 03:38 PM
01 330i Battery Replacement jchan168 E46 (1999 - 2006) 72 12-15-2010 05:12 PM
This Is The Official Hijack Thread... Sabrina Off-Topic 146 05-21-2009 07:38 PM
My first BMW service (please advise what you would do)? shaftdrive E39 (1997 - 2003) 23 08-18-2006 08:51 PM
BMW's, problems, and people who post their problems Guest84 3 Series & 4 Series 17 03-10-2003 12:45 PM
