Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   bimmerfest - BMW Forums > BMW Model Discussions > 3 Series
3 Series
The 3 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 01-13-2003, 08:58 PM
pt00323i pt00323i is offline
Will work for track time.
Mein auto: 2000 323i/man/sp/pp
Question Anti squeak stuff for brake do I need it?
Per brakefest, just use anti-seize compond.
some did pad change w/out anything, some with anti sqeak spray/stuff.
Need your imput.
thanks
Old 01-14-2003, 06:45 AM
Ack's Avatar
Ack Ack is offline
In Mod Heaven
Mein auto: 2002 330Ci
When I changed out my pads, I replaced them with PBR (Axiss) Deluxe pads. To reduce the squeal that these brakes seem to cause, I used anti-squeal compound on the brakes. It has helped tremendously to eliminate brake squeal.
If you are just replacing your brakes with OEM pads, I don't think its necessary, but it won't hurt to apply it yourself.
Old 01-14-2003, 08:51 AM
The HACK's Avatar
The HACK The HACK is offline
Non-hunter
Mein auto: '06 MZ4C, '09 WRX Wagon
If you are putting on racing pads, no amount of brake silencer will help.
If you are putting on street pads, definately slather on some of that stuff...Makes a huge difference on street pads.
"Hack has been around the block (and back) with BMWs. And, he wrenches and tracks his cars (offering some excellent insight)! "
-World Famous Automotive Journalist (not Dan Neil, but close).
Old 01-14-2003, 09:39 AM
Thanks,
I'm planning on installing new Brembo OEM rotors, Cryo treated with Axxis Ultimate pads.
so sounds like I should use some of those anti sqeak stuff.
Old 01-14-2003, 10:15 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein auto: Daihatsu Terrios
i used CRC antisqueal spray, was like 3 bucks at autozone
nice red color, sticky as heck.
no squealing with my axxis pads
Old 01-14-2003, 10:19 AM
The HACK's Avatar
Non-hunter
Originally posted by pt00323i
Thanks,
Not if they're drilled or slatted.
Drilled or slatted rotor will induce a lot more vibration into the caliper. No amount of anti-squeal will quiet those brakes. Live with the squeals...You should see the looks I get when I pull up to a stop. Brembo drilled rotors coupled with racing pads makes like I'm driving a FedEx delivery truck.
Old 01-14-2003, 11:06 AM
rwg rwg is offline
Send a message via ICQ to rwg
Mein auto: '08 335i
This stuff goes on the back of the pad? I have never used it on any of four sets of stock pads, but my brakes don't squeel, so I have never researched it. Can someone give a quick explanation of why it helps? I am assuming the back of the pad - I can't imagine putting any gel like substance on the friction surface.
Old 01-14-2003, 12:34 PM
yes, this stuff is appied on the back of the pads and must wait for it to dry before installing.
I am also not sure how they are suppose to help.
I've heard that Axxis pad do squeak so I'm going to put this stuff on the pads.
E46-00323i-5MT/SP/PP/uuc sways/udp/clears
E30-89325i-Track car
B5-99A4Avant-Tip/SP/GIAC ECU+Tip
Old 01-14-2003, 12:50 PM
SteveM's Avatar
SteveM SteveM is offline
Missing
Mein auto: 2003 330i SP 6sp
I always thought it worked by damping vibrations.
That stuff always smells suspiciously like Elmer's glue to me.......
=Steve=
I'm SteveM and I approve this post.
Old 01-14-2003, 01:13 PM
The HACK's Avatar
Non-hunter
Brake squeal comes from the back of the backing plate (metal) vibrating against the frame of the caliper. The brake pad on rotor actually do not create any sort of squealing noise.
How this prevents squeal, is the compound drys to a semi-hard rubbery compound and dampens the vibration against the frame of the caliper (theoretically), that's why you need to wait for it to dry before installing for maximum efficiency. However, with REALLY grabby brake pads, there's little to nothing you can do.
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2001-2009 performanceIX, Inc. All Rights Reserved .: guidelines .:. privacy .:. terms
