Old 02-24-2007, 09:25 PM
Din's Avatar
Din Din is offline
Mein Auto: 750LI M3 Mustang Tundra
who has sucessfully lowered a 745 with rear air suspension?
if u have please share details. thanks.
Old 02-26-2007, 10:49 AM
Din's Avatar
Din Din is offline
any?
Old 03-01-2007, 04:25 PM
Din's Avatar
Din Din is offline
Old 03-01-2007, 09:09 PM
socal745li socal745li is offline
Mein Auto: 2003 745 Li
This may be a stupid question, but
Do you know if 03's had the rear leveling system? If so how can you tell if you have it? I am getting ready to get the eibach pro kit for my 03 745li and want to make sure I do not have it.
Old 03-02-2007, 04:34 AM
SevenMan's Avatar
SevenMan SevenMan is offline
Mein Auto: 745Li
Just look inside your rear wheelwells. If you see coil springs, then you dont have the self leveling suspension.
_____________________SOLD_____________________
Old 03-02-2007, 09:02 AM
Thanks.
Old 03-06-2007, 06:41 PM
AZIPOD AZIPOD is offline
Mein Auto: E66,E90,W211,NSX,E39,E38
Some people say that when you lower the front, the rears will automatically adjust to the height of the front. Can anyone confirm this?
Old 03-09-2007, 11:59 PM
Din's Avatar
Din Din is offline
has anyone lowered theirs while lowering their rear more than 1inch?
Old 03-10-2007, 07:21 AM
SevenMan's Avatar
Mein Auto: 745Li
2fst2c lowered his with AC Schnitzer.
http://www.bimmerfest.com/forums/sho...d.php?t=132682
It looks about 1.2" in the rear.
http://www.bimmerfest.com/forums/sho...=126961&page=2
Old 03-10-2007, 09:22 AM
Din's Avatar
Din Din is offline
i read that before and in one thread it says he did it with the AC springs and in another thread it says he had H&R springs so i am a little confused what he used.
Old 03-14-2007, 03:25 PM
D2-AUTOSPORT D2-AUTOSPORT is offline
Past Sponsor
Send a message via AIM to D2-AUTOSPORT Send a message via Yahoo to D2-AUTOSPORT
Mein Auto: 745LI
He actually is a customer of mine (WALD kit) and he did have one of the first ACS kits with the springs and module. I'm not even sure if they still make that kit. I know its pricey (well alot pricer than 300 bucks for just eibach springs)
Old 03-14-2007, 07:45 PM
The AC Schnit kit is about $700. It includes front springs and software to lower the rear. The software has to be loaded at the bmw dealership. AC Schnit gave me the lowering figure in mm and I forgot what it is --- but I remember looking it up and it was a modest 1.0" drop only.
Old 03-14-2007, 09:13 PM
Din's Avatar
Din Din is offline
hmm.. i need to figure out a way to get the rear lowerd about 1.3inches.
Old 03-14-2007, 10:32 PM
If you put the car on the rack, you can see that there are one lever on each side of the suspension which is the ride height leveler arm. The position of the arm relative to the supension links "tells" the computer the height.
Just by looking at this setup, I think you can "trick" the system by changing the length of the leveler arm. If I'm picturing it correctly, I believe you can shorten the length to trick the computer into lowering the rear more.
The arm is made of hi strength plastic (i think). THe part # is 37146752797, retails for about $5, you'll need two (1 for each side).
It's worth a try. If all fails, just put your stock arms back. The swap shouldn't take you more than 30 minutes.
Old 03-15-2007, 05:25 AM
minnesotaR6 minnesotaR6 is offline
Mein Auto: 95corolla
whats the quickest/easiest way to determine if i have springs or air suspension in the rear?
and... why are some air and some spring? is it due to certain years?
Old 03-15-2007, 08:59 AM
Just look from the rear-wheel well.
If you don't see a spring, then you have the air-suspension.
The air-suspension is an option, its part of the adaptive ride package. I think it's a nice option but requires more work if you want to modify the suspension.
Similar Threads
E65 V12 debuts nate General BMW Questions 22 06-09-2016 12:44 AM
It's official 997 GT3 for poseurs only Stuka General Automotive Forum 16 06-11-2006 04:21 PM
Rear Suspension Problem! 8mw E46 (1999 - 2006) 5 11-24-2005 02:36 PM
WARNING - Rear Air Bags inactive! machmeter Ask-A-BMW-Dealer 13 01-24-2003 01:43 PM
Rear Air Bag Configuration Confusion SteveM 3 Series & 4 Series 5 09-19-2002 12:51 PM
