E46 M3 (2001-2006)
Old 02-27-2007, 04:59 PM
flick flick is offline
Mein Auto: M3
???launch control???
greetings,
I just purchased a 2004 M3 coupe and I absolutely love it. The power the car has is unmatched to anything I've been in before, granted they aren't anything to brag about. I had heard rumors about a few settings that can be programed for different modes. For example one called launch control and others pertaining to the car's general capabilities. I'm sure there are several capabilities this car has that I'm unaware of, but hopefully will be able to experience them. Thanks and if anyone knows these settings I would appreciate some advice.
Old 02-28-2007, 12:54 AM
realCL23 realCL23 is offline
Mein Auto: 2002 M3 SMG
I'm sure if you search for it there are bunch of threads regarding the launch control function for your m3 and also the burn out function.
2002 ///M3 SMG Carbon Black/Cinnamon Fully Loaded except for headlight washers and ski bag.(Like a californian needs those..)
Eisenmann Meisterschaft Ti/LED license plate lights
Old 02-28-2007, 08:01 AM
Mein Auto: M3
this is where I'm not sure. i'm new to the whole forums and am not sure how to go about searching for information regarding answers my questions/comments.
Old 02-28-2007, 12:15 PM
Underneath the huge sponsor banner on the top right there's the search function. Then type in m3 launch control and I'm sure you can find something.
Old 02-28-2007, 12:26 PM
motogp46 motogp46 is offline
Mein Auto: 2003 e46 M3 SMG II
Select manual mode, Turn OFF DSC, turn ON SPORT button, make sure all 6 lines are highlighted on the smg mode, push stick forward, and finally while holding stick forward press the gass pedal down slowly. Let go of the stick and hold on, be ready to UPSHIFT!!!
Old 02-28-2007, 08:13 PM
gr8330 gr8330 is offline
Mein Auto: For fun
This should help http://www.m3smg.com/index.html
550i Blk/Blk
M3 Imola/Blk
Mike
Old 03-01-2007, 08:58 AM
Mein Auto: M3
i'm not sure if it's just me, but i'm having a difficult time figuring out how to get it in S6 mode. i can obviously get to S5, but not sure how to obtain that extra bar. everything else makes sense to me. The SMG is way more effective then I knew, relative to the speed of shifting.
Old 03-01-2007, 09:17 AM
plien69 plien69 is offline
Mein Auto: '14 EB M235i
Turn off DSC
Patrick
Him:
2014 M235i Estoril Blue Tech|Winter|8-spd Sport Auto
2008 135i Alpine White Sport|NAV/iDrive|HDRadio|BT|Step (WAF) Traded in 9 Jun 2014.
2005 ///M3 Silver Gray PCD 25 May 2005 Traded in 26 Mar 2008.
1993 325i 5MT|H&R Sports|Bilstein HD|RD Sport Sways|Mille Miglia MM-IIs w/ 225/50-16 Bridgestone RE750s|UUC StrutBarbarian|JC Chip & CAI|M3 cat-back|UUC Clutch Stop Hit 9 Jun 2006. R.I.P. Donated to charity 5 Jul 2006.
Her:
2005 Honda Odyssey EX-L Silver Pearl
Old 03-01-2007, 10:45 AM
Mein Auto: M3
DSC off and 5 bars is still all im getting
Old 03-01-2007, 10:52 AM
Are you in Manual or Automatic mode? Automatic only has 5 modes whether DSC is on or off. Manual mode has the extra 6th bar when DSC is off.
Be advised that some people find the SMG display on the dash confusing when it comes to displaying Manual vs. Automatic mode. Note that the transmission will always switch to Manual mode when you call for a shift via paddles or the gear shift lever.
So, shift using paddles or lever, turn DSC off, and you should see an extra "slot" for the 6th bar.
Patrick
Him:
Her:
Old 03-01-2007, 11:39 AM
Mein Auto: M3
i'm not sure what the problem is for me....DSC is on/off as indicated by the dash, when i have it in manual mode 'D' and press the DSC the light comes on, push it again and the light goes off but no additional bar comes up. my year is a 2004, does that have anything to do with it??
Old 03-01-2007, 11:53 AM
Mein Auto: M3
i'm an idiot, i just figured it out, i was thinking when the light is on, DSC is engaged,but in reality it's just the opposite, means it's disengaged when the light is on. thank you to all and again sorry for my stupidity.
Old 03-01-2007, 04:30 PM
paulnwgb paulnwgb is offline
Mein Auto: M3/X5/Ferrari 360/330Ci
http://www.m3smg.com/fpfiles/special...nchcontrol.mov
Oh man, I can't wait.
So how do we make our US M3s LC at 3500rpm instead of 1500?
Old 03-01-2007, 06:13 PM
Mein Auto: M3
so i was able to do it, but i burned out-not what i wanted to do, but damn it was awesome. i'm not sure why i burnt out instead of not but for people like me that aren't too familiar with M3 this is a pretty good website explaining the capabilites of the car.
http://www.m3smg.com/special_functions.htm
Old 03-01-2007, 06:20 PM
XMN XMN is offline
Acct Closed
Mein Auto:
i'm not sure why i burnt out instead.
You have to ease into the gas pedal and don't put it to the floor to just launch.
Have Fun
Good Luck
Peace
Rick
Old 03-01-2007, 10:06 PM
Mein Auto: M3
i knew to ease into the pedal, but have read to put all the way to the floor. will try, but from what i read it depends on how gradual the pedal is pushed dtermines between a burn out and launch
Old 03-02-2007, 08:25 AM
rruiter rruiter is offline
Mein Auto: 04 M3 Coupe SMG
You have to SLOWLY press it to the floor. There are 2 modes, one is burnout and one is maximum launch speed. If you slowly press the pedal all the way to the floor the car will monitor wheel slip and prevent a burnout and give you maximum launch.
If you slam the pedal to the floor it will do a burnout; It will go all out and ignore any wheel slip. Not pretty and hard on the drivetrain too ( but so is the other mode). Unless you like to replace tires often this isn't something you want to do much.
04 BMW M3 Coupe SMG-II Carbon Black
Old 03-04-2007, 01:29 PM
Jim in Oregon Jim in Oregon is offline
Mein Auto: 2009 E92 M3 Coupe
If you want the higher rpm launch control....it's $599.
http://www.esstuning.com/default.asp...at2=143&id=207
Old 03-04-2007, 01:47 PM
XMN XMN is offline
Acct Closed
Mein Auto:
Thanks.
I am going to look into getting this.
Be Easy
Rick
Old 03-04-2007, 02:49 PM
Leo Leo is offline
Mein Auto: M3 CSL, Golf IV
Smile
My FAQ might help aswell
http://www.leo.nutz.de/BMW.php
Sorry for the shameless plug
///Leo
Old 03-05-2007, 01:57 PM
Mein Auto: M3
i tried launch control again, pushing the petal to the floor slowly and it still burnt out. i'm going to stop b/c i know it's not good on the car. i just wanted to see what it felt like but not having good luck trying.
Old 03-06-2007, 11:20 AM
Leo Leo is offline
The gas pedal must be FULLY depressed at all times while in LC mode.
///Leo
Old 03-06-2007, 02:23 PM
Mein Auto: M3
yeah i had read that too, and tried it while depressing the pedal slowly and still no luck. i'm obviously not doing something right, but not sure what.
Old 03-06-2007, 02:28 PM
XMN XMN is offline
Acct Closed
Mein Auto:
Leo, your M3 is a Euro Spec model right, what does your rpm's get up to for launches.
Rick
Old 03-07-2007, 01:49 PM
Leo Leo is offline
Rick
Correct.
ca. 3500 rpm
///Leo
Similar Threads
manual to auto climate control andy_thomas Do-It-Yourself H.Q. 1 05-28-2009 03:10 PM
E36 Cruise control retrofit help 318tiCS Do-It-Yourself H.Q. 5 02-13-2009 02:38 PM
Going down. Europcopter crash video eksath Off-Topic 5 05-16-2006 09:21 PM
Climate control woes karmapolice E46 (1999 - 2006) 4 04-02-2006 01:58 PM
Is the automatic climate control programmable? Mcbruges X3 E83 (2004 - 2010) 8 02-12-2006 10:39 AM
