E46 (1999 - 2006)
Old 02-28-2007, 11:38 AM
Random() Random() is offline
Mein Auto: 325Ci
Unhappy Engine oil >Red< light - Need help.
I've searched the forums & while there seems to be plenty of info on the yellow light, I'm not seeing much on the red one. Unfortunate this had to be my first post, but it is what it is.
By the way, I'm a BMW Motorrad vet (K12), but this is my first BMW car - So I'm not a complete slacker. The car is a 2004 325Ci, by the way.
Anyway, what I'm running into:
Start car, no problems. Putter around town, no problems. After about 30 miles of city driving, the red oil light comes on intermittently while stopped. Sometimes in longer intervals, sometimes in short flashing type intervals. Moving the RPMs up to 700-1000 turns off the light. I've never seen the yellow warning light, only red. Nothing ever as soon as you turn over the engine, only after about 30 miles and warm-ish weather (80ish deg F), if that matters.
The oil level is good and is fresh oil & filter. Idle RPMs are around 400-500. I do not have the service history, that's on my to do list still. Car has 56k miles on it.
Any thoughts? I'm not obligated to buy it yet if this is super bad.
Thanks in advance.
Old 02-28-2007, 11:53 AM
rwh330CiC rwh330CiC is offline
Mein Auto: 330i 330CiC
Since the car is under warranty, tell the seller to get it fixed. Look at the repair order and then get back to us. Bob
Old 02-28-2007, 12:41 PM
Ssalpathan Ssalpathan is offline
Mein Auto: 2004 330i M package
Hey Random,
I have a 330i, and i had a similar problem. It is nothing to worry about because it has to do with an oversensitive oil detector, which needs to be replaced by bmw. The only problem here is that because the indicator gives you incorrect information sometimes does not mean that it also wont give you correct information, when actually there is a problem. So get it replaced, because the car should be not driven at all, if the oil light is on...
Old 02-28-2007, 01:15 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
He mentions the car has 56k miles on it...that's out of warranty.
E46s idle at 700 or so...400-500 is too low. Red oil light means oil pressure dangerously low.
Since you say the oil level is fine, I'm guessing this could be a bad oil pump.
I'd pass on a car that's been driven for any measurable amount of time with this condition. For the most part, any red lights illuminating mean "stop immediately."
The manual even says:
Engine oil pressure
***9679; Stop the vehicle immediately
and switch off the engine.
Check the engine oil level; top off as
required. If the oil level is correct:
Please contact the nearest BMW center.
Do not continue driving, as the
engine could sustain serious damage
from inadequate lubrication.
It's certainly possible it's a bad sensor... but the low idle worries me.
Old 02-28-2007, 06:13 PM
pinoyromeo16 pinoyromeo16 is offline
330aye!
That's a manufacturer defect thats common on e46's. Should be covered under waranty.
Old 02-28-2007, 06:21 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Oil level sensors are known to go bad. Oil pressure sensors are not.
Old 03-02-2007, 12:00 PM
Mein Auto: 325Ci
Extended warranty, but either way -
I guess my biggest fear was what Kris is saying - I wasn't aware there were two different sensors; level and pressure. The shop took a look at it twice now & wasn't able to reproduce the problem. The idle speed is supposed to be up around 700 though - That's quite interesting.
I can give it another drive tomorrow. It's still in the shop right now, they were working on the steering wheel controls & put everything back together without reconnecting the airbag yesterday. Kinda losing faith in our Orlando techs :/
Does anyone know if the pump, level / pressure sensors are tested in the onboard diagnostic program?
The pump failing (or being reported as failing) is a rather significant event - I can't believe it's not being logged somehow, even if it is a false error. Anyone know if this stuff is logged somewhere that I can check myself?
Need to make sure I'm getting a reliable vehicle, not something that I'm going to have endless problems with.
Old 03-02-2007, 12:07 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
Bro - Plenty of used cars on the market - why would you want this one?
If a car I was looking at had issues with a red oil warning lamp, I would be backing up slowly towards the door nervously fingering my car keys...
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 03-02-2007, 07:07 PM
oxford oxford is offline
Mein Auto: '01 Z3, '03 330i
Random(),
If you are looking for a reliable vehicle, I am thinking this one ain't it from what I've read here.
Maybe you should suggest to the techs that they try checking the actual oil pressure at idle with the engine warm. If the pressure is within spec and steady, the sender or wiring is most likely at fault.
And, who knows how long this intermittent light has been happening? If it happened to the previous owner, and they didn't get it fixed, I'd be thinking two things:
1) How long has this been going on, and how much internal engine damage has happened because of it?
2) What else - less obvious problems - have been ignored?
Just my long-winded $0.02...
Old 03-06-2007, 08:13 AM
Mein Auto: 325Ci
True 'nuff. Thanks for the thoughts. It's still at BMW - They also don't release full maintenance records anymore, at least down here, saying it's a privacy thing for the previous owner. I told them I wanted the car's maintenance records, not the owners annual checkup results with the doc - That didn't go over well either. O.o
They also haven't even fixed the airbags. Think it's time to walk. Thanks for being the voice of sanity, all.
Old 03-06-2007, 08:39 AM
Deepak's Avatar
Deepak Deepak is offline
:(){ :|:&amp; };:
Mein Auto: 325 Ci
That service record thing is definately balogna. I purchased a '04 325Ci in January and was provided with a Carfax report and the vehicle's service record - with the previous owner's information blanked out. The previous owner is entitled to privacy, not the vehicle.
Old 03-07-2007, 04:18 AM
gitpicker's Avatar
gitpicker gitpicker is offline
Mein Auto: 2009 328i Sport
I was also provided with a maintenence and service history when I bought my 2003 last June. Of course I had to have some help figuring out what all the codes meant, but it was very informative. It would be even better to talk to the previous owner. But I think you should walk away from this one.
Old 11-02-2007, 07:38 AM
TenzoR TenzoR is offline
Mein Auto: 2003 BMW 325i
Hello Sorry to bring this thread up. I'm having similar problem (sort of). My oil light flashes in red once every blue moon. A quick flash for a bit and it's gone for another month or more. I've already contacted the dealer (since my car is CPO) they said they can't diagnose the problem unless the light is on permanently. They noted on my file and checked the oil level for me and said I was fine. They also said they could try to diagnose it but if they can't find out the problem I will have to be charged for their time. My SA said Is hould just wait till the light is fully litted and come in. I lefted at that, but I thought the computer will store the last error code (dispite how fast it appears). Oil level is spot on and the car appears to drive normal. No hesitation, idle is near silent at the correct RPM. Could it just be the oil pressure switch that's slightly bad or a loose connector?
Old 11-02-2007, 12:10 PM
Lbert Lbert is offline
Mein Auto: 325i
If your idle is too low, the mechanical oil pump is not spinning or pumping at its proper speed thus the oil pressure will be lower. The lower pressure thus trigger the oil pressure sensor to send an error signal.
Old 11-05-2007, 02:37 PM
idle is normal AFAIK, it's at 600-700 ish
Old 11-06-2007, 09:46 AM
Mein Auto: 325i
Spray the connector to the oil pressure swicth with a electrical contact cleaner. You can get this at your auto supply store. If that does not work, replace the oil pressure switch. I'm not sure how much the switch cost.
Old Today, 07:39 PM
myBeamer328IS myBeamer328IS is offline
Mein Auto: 1997 BMW 328 IS
Check the sensor connection first if that is good then replace the sensor. It's only like $10
Old Today, 08:42 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is online now
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Originally Posted by myBeamer328IS View Post
Check the sensor connection first ...
No--check the posting dates first. Dude, this thread died nine years ago!
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47° 35' 30.13" E11° 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Similar Threads
06' 330i first oil change....yeah... yzandrl E90/E91/E92/E93 (2006 - 2013) 49 08-01-2008 11:47 AM
engine clacky noise coming from bottom half of engine. please help XThang E39 (1997 - 2003) 28 11-27-2006 11:55 AM
More on the N54 engine/ new transmission mapezzul E90/E91/E92/E93 (2006 - 2013) 5 07-18-2006 09:30 PM
Alex, someone, anyone HELP! (engine oil pressure light) mecklaiz General BMW Questions 7 06-20-2003 05:46 AM
Curious oil light and engine oil fluctuations. C-Bear General BMW Questions 1 03-11-2003 08:41 AM
