Old 03-04-2007, 06:59 AM
Russs335i Russs335i is offline
Russ335i
Mein Auto: BMW 335I Coupe
335I Engine Malfunction
One of the reasons I joined this forum is to see if anyone else has experiended a similar problem I'm having with my 335I Coupe. I'm currently living in Germany and purchased my American spec 335I Coupe in Nov and have approx 4100 miles on it. While crusing at approx 80 MPH in 6 gear my car started to run rough, acting as if a spark plug was misfiring or water was in the gas tank. Eventually an engine fault indication appeared on my display and the words power reduced service engine also appeared. I took it to my local dealer and was informed there was a recall and I needed new software. The software was loaded and the probelm remained. I took it to a different dealer and they hooked it up to their computer and found nothing wrong. I will take it for a thrid time because I'm still having the problem. When driving agressively and shifting throught the gears at high RPMs I don't experience the problem only at crusing speed and lower RPMs. Has anyone else had this problem?
Old 03-04-2007, 08:31 AM
Steve Espo Steve Espo is offline
Mein Auto: 2007 335i Coupe
Possible fuel pump issue. Has been a fairly common problem on these engines.
Old 03-04-2007, 11:38 PM
tenzig tenzig is offline
Mein Auto: 335i
I had the exact same problem you described to a T. The dealer replaced the fuel pump (one week back ordered) and the problem immediately went away.
Old 03-05-2007, 12:04 AM
WalterMiddy WalterMiddy is offline
Mein Auto: 2007 335i Sedan
My 335i Sedan was manufactured in December and delivered in early Februrary. I had the fuel pump replaced after 2000 miles when the car started taking extra long to crank over because the fuel in the line was flowing back while it sat. I also noticed that when I punched it at times the car studdered, as it were. It will take about a week to get the part, but your dealer will likely give you a loaner if you take it to the place you bought it.
Take it in stride. Not a big deal.
Good luck and let us know how it all turns out.
335i 2007 Sedan: Arctic / Terra / Sport Pkg / Cold Pkg / Comfort Access / Active Cruise / Nav /Sirius / Park Assist / Oil Cooler /
Old 03-07-2007, 04:27 PM
drjensen's Avatar
drjensen drjensen is offline
Mein Auto: 2008 335i Coupe
I have a similar problem. My car bucks/hesitates at low RPMs, especially when the engine is cold. I took it to the dealer yesterday morning, and they are working with BMW North America on diagnosing the problem. They said my car already has the most current software, and they think it is actually a fuel pump problem. I'm waiting to hear back from my service advisor for an update on the diagnosis. I hope I don't have to be without my car for long. I've only had it since Feb. 3.
Old 03-07-2007, 05:25 PM
SenSpeed SenSpeed is offline
Mein Auto: Gremlin
Damn. A lot of people having trouble with their 335 engines?
Old 03-07-2007, 06:21 PM
Andre Andre is offline
Resu Deretsiger
Mein Auto: 2007 335i E90 AW CA ZSP
My ZHP had that issue. Turned out to be a coil issue.
'07 E90 335i - Alpine White, Sport Package, CA, 6FL
Old 03-07-2007, 06:33 PM
johnc_22's Avatar
johnc_22 johnc_22 is offline
Squeal like a BMW
Mein Auto: 2013 Audi A4
I think the fuel pump issues were related to an early build period but cars built recently shouldn't have this problem. I think if you search you can find the specific date range that was affected.
2013 Audi A4 - Premium+/Sport/MMI/B+O Audio
2007 BMW E90 335i (retired)
Old 03-07-2007, 08:11 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Jeezus, man....can`t you read???? It`s NOT an engine problem, it`s a fuel pump (or other auxiliary system component) problem....
Old 03-07-2007, 08:24 PM
Mein Auto: Gremlin
you mean like when you have a stroke it's not a brain problem but a blood vessel problem? dont be a dumbass. I can read just fine.
Old 03-07-2007, 08:46 PM
Bombay Jay's Avatar
Bombay Jay Bombay Jay is offline
In the heat
Mein Auto: '14 Chevy Silverado
Reading and comprehension are two different things!
HARK
330i monaco blue, -- ED pickup 4/28 -- Frankfort Dropoff 5/2 -- Redelivery 6/10 Chi-town
Old 03-07-2007, 08:53 PM
picus picus is offline
Banned
Mein Auto: Cars
It's not the main fuel pump, it's the secondary high pressure fuel pump. It runs at a very high pressure so it's sort of not a huge shock they are dying. Apparently it's limited to a certain production run though, so once these are all sorted we should stop hearing about them.
It's a pretty easy fix too.
Old 03-07-2007, 09:02 PM
Bombay Jay's Avatar
In the heat
More than 30 psi??
HARK
Old 03-07-2007, 10:24 PM
roup1's Avatar
roup1 roup1 is offline
Mein Auto: Bavarian
I had the same symptoms (09/06 build) and needed a new HP fuel pump. It took 11 days to get BMWNA to approve the repair and get the part from Germany. As of a few weeks ago, there was a national backorder...
Current:
2014 M235i Alpine White (ED), 2013 335i M-Sport Melbourne Red (ED)
Past:
2014 i3 BEV, 2014 435i M-Sport (ED), 2011 335is (ED), 2008 135i Coupe, 2007 335i Conv (ED), 2007 335i Coupe (ED), 2006 330i (ED), 2005 M5 SMG, 2004 330Ci (ED), 2004 645i Coupe, 2004 545i (ED), 2003 330CiC (ED), 2002 530i (ED), 2002 M3 SMG, 2002 330CiC (ED), 2001 X5 4.4i, 2001 M3, 2001 330Ci (ED), 2000 323i (ED), 1969 2002 (and a few cars from Oxford and Zuffenhausen in between)
Old 03-08-2007, 09:52 AM
drjensen's Avatar
I just heard from my Service Advisor. He said that BMW NA approved the replacement of the high pressure fuel pump in my car. He said the part is on backorder, as expected, and he said I can come pick up my car and hold onto it until the part comes in. That way I don't have to drive the smoke stinking loaner they gave me. By the way, my car was a 12/23/06 build. Attached is the service bulletin I found on the problem. You can see that they now think the problem exists on engines produced between 6/06 and 12/1/06. And that is the ENGINE build date, not the car build date.
Old 03-08-2007, 11:47 AM
Mein Auto: Gremlin
man you guys, this is no ok. fuel pump or not. at 3000 miles? Multiple failures? Give me a break. blind loyalty can only get in the way of improving a product. Look a ford and chevy. Their cars sucks and it had been ok because people still bought them. Now facing share loss they actually starting to make better cars.
So stop defending the cars defects and maybe BMW will start building more reliable cars. Wake up and realize that BMW didn't fully validate this vehicle and are using the first batch of owners to do the most basic of tests. Any sort of decent testing would have uncovered this.
Some of you guys are like the moms that defend their obnoxious kids without reason and point to other kids. It cracks me up every time I see a "Infiniti recalled 1000 times!" thread on the 3series board.
Old 03-08-2007, 11:51 AM
Banned
Mein Auto: Cars
No one is defending them (at least I don't think?), we're just pointing out the facts behind this issue. It's a secondary high pressure pump, it effects engines built between June '06 and Dec '06, the repair itself is not difficult, nor is diagnosing it (it's a black or white yes or no code), but the part is on backorder so it can take some time. Yes, it sucks; same as the engine oil cooler being left out of auto's with ZSP sucks - but get some perspective, in terms of brand new model launches this one has been surprisingly uneventful.
Old 03-08-2007, 11:52 AM
sflgator's Avatar
sflgator sflgator is offline
Mein Auto: '07 BMW 335i Coupe
No, that's not true...a small percentage of ppl on BMW Enthusiast Internet Forums are having some issues, but a majority of 335i owners are enjoying trouble-free driving!
FWIW -- to the OP, it does sound like the fuel pump problem.
'07 335i Coupe
|Sparkling Graphite|Black Leather|Aluminum Trim|AT|Paddles|Prem|Sport|Navi|CA|Sirius|SS Pedals|Tint|
|MTEC Super White HID Coronas|19" Morr Forged VS7s|Falken FK452s|Rear Lip Spoiler|BMC Air Filter|PROcede v2|
Old 03-08-2007, 12:00 PM
roup1's Avatar
Mein Auto: Bavarian
I have yet to see a single post "defending the cars defects..." Although these cars are thoroughly tested before launch, I know that this is not uncommon for a first year car. I bought my 335i knowing that I would be one of the first owners and that there might be some teething issues. It's the price that we pay for being on the bleeding edge and having the newest toy in the neighborhood!
Current:
Past:
Old 03-08-2007, 02:11 PM
Mein Auto: Gremlin
definition of defend here is blowing it off as something that is expected or writing a problem off as a minor bug. I would be angry and embarassed if my 46k vehicle started sputtering before I even finished the break-in.
I am a previous owner of a s2000, and on the forums whenever a cluth problem, or tranny problem appears everyone on the forums would be all over it. None of this "ah it's nothing" or "hey, it's just the teething process".
Of course it is always difficult to criticize your baby.
Old 03-08-2007, 02:35 PM
zim248 zim248 is offline
Mein Auto: bmw 335i Coupe
Hey,
I don't want to jinx my 335i coupe, but I'm at 4000 miles and it's running great. I did have a nail in one of my runflats and had to replace it..........$350- ouch.
Old 03-08-2007, 03:13 PM
DenverNoob DenverNoob is offline
Mein Auto: 2004.5 Audi A4 1.8T
Originally Posted by zim248 View Post
Hey,
knock on wood my friend!
i support the teething theory here honestly...people should know that in technically advanced cars the first MY has issues...i mean look at toyota/lexus! the haulted the launch of several new MY cars last year because there were pre-release issues not caught in initial testing!
fact of the matter is this...direct injection is a new technology for production cars...audi brought it in MY 2005.5 with the 2.0T FSI...and that has initial fuel pump issues fixed for MY 2006+...if you want ot lead the pack in ownership you MUST accept the fact that these things happen. furthermore, FI is new for BMW after decades of hiatus...there will be a few bumps in the road, and at the end of the day that is what a waranty is for.
by MY 2008 all of these little issues will have been resolved and it wil be back to normal for the 335, and time to run into issues with the new m3!
2004.5 Audi A4 1.8T QMT6 Ultrasport Loaded
Bullseye Power S256 Turbo, Built Engine by Autobahn Premier Service of Denver, CO.
Fast....really really really fast.
Old 03-08-2007, 04:18 PM
quidycat quidycat is offline
Mein Auto: bmw 335 convertible
i agree that it's not acceptable for having more than average reliability issues on cars costing a lot more than average. can't german car companies learn from janpanese companies? there really isn't any excuse. and making new car owner wait for parts to fix problems is poor customer care. i'm impressed that most toyotas are built in the usa and are able to maintain their quality.
Old 03-08-2007, 05:49 PM
LA525iT's Avatar
LA525iT LA525iT is offline
swinging a big stick
Mein Auto: 03 525iT & 06 Z4 3.0si
It's not the origin of the car, the lesson is to never buy a new product in its first year. I can assure you that my E39 (last year of production) has been way more reliable in its first 50k miles than my old 1997 Toyota Camry (first year of that bodystyle's production, and my car was built in Japan not Kentucky)
My car: 2003 525iT 5M/SP/PP/Xenons/Aux/Sirius
Her car: 2006 Z4 3.0si 6M/SP/PP/Xenons/Heated Seats
Dog car: 1996 Integra SE 5M/Leather/Dog Fur/Sand
Old 03-08-2007, 10:44 PM
Banned
Mein Auto: Cars
Maybe there is just a different perspective coming from BMW owners compared to, in your example, S2000 owners. I'm a pretty laid back guy. If my car had the fuel pump problem I'd make an appointment, drive a loaner for a week, and then get my car back fixed. If it were another brand of car I'd look at this issue the exact same way. If I continued to have problems then I would start to look at other solution; but right now this particular problem seems to be well handled. I don't know, that's just me.
Similar Threads
E65 V12 debuts nate General BMW Questions 22 06-09-2016 01:44 AM
335i Starter Motor Cranks Extra Long before Engine Starts WalterMiddy E90/E91/E92/E93 (2006 - 2013) 5 02-21-2007 01:40 AM
New 335i turbo engine in base Z4 Coupe? Cornhusker E85 / E86 Z4 (2003-2008) 35 09-28-2006 08:32 PM
BMW Update for S54 Engines BMWNA 1M & M2 2 08-13-2003 06:55 PM
Product review: Griot's Engine cleaner kit(m) The HACK The Detail Department 20 01-08-2002 08:56 PM
