Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW
General BMW
Use this forum to talk about general BMW news/stories and to chat with fellow enthusiasts about the direction that BMW is going in for their cars and/or motorcycles!
Old 01-30-2013, 02:25 PM
bimmerman420 bimmerman420 is offline
Mein Auto: 2000 bmw 328 is
Tunnel ride!
Old 02-08-2013, 04:00 PM
cruisingbimmer's Avatar
cruisingbimmer cruisingbimmer is offline
Bond Girl
Mein Auto: 2007 BMW 328i
Great video! Made me want to go out and find a tunnel to drive through!
"Just the thing for unwinding after a rough day at the office."
BMW CCA Member 473595
Old 02-24-2013, 10:43 PM
californiawills californiawills is offline
pending
Mein Auto: car
Originally Posted by KrisL View Post
Here are the top 10 things that anyone considering a new or used BMW should know. I'm going to make this a sticky - feel free to add on to it!
  1. Most newer BMWs require synthetic oil and premium fuel. Do not give your car less than it requires.
  2. Contrary to popular belief, parts and labor on BMWs is not more than the competition; however, BMWs are not as reliable as Japanese cars and they do require more maintenance.
  3. If your car is out of warranty, find yourself a competent independent mechanic. Their labor rates tend to be about half that of dealers. http://www.bimrs.org/ lists such shops.
  4. Buy a Bentley repair manual for you car. Even if you don't work on your car yourself, it's good to be an informed consumer (example: if your check engine light illuminates, Autozone will plug into your car for free and give you the car's trouble code. You can cross-reference it in the Bentley manual to see what's wrong).
  5. Historically, manual transmissions are more reliable that automatic or steptronic transmissions.
  6. BMWs have great brakes - this is due in part to the rather soft pads and rotors they use. Don't expect them to last more than 30-50k miles. The rotors generally wear at the same rate as the pads so 'machining' the rotors OR replacing pads without rotors is not recommended. There is a 'brake pad low' warning light that is triggered by a wear sensor that will illuminate on your dash when you are due for new brakes. It looks like this: . When you replace your brakes, you also need to replace the wear sensors ($10-20 each). There's one on the front left wheel and one on the rear right wheel. Parts for all 4 rotors, pads, and sensors are generally $200-500 and labor is about the same.
  7. The 'sport package' available on most BMWs is usually considered a necessary option by enthusiasts. It usually includes better (bolstered) seats, stiffer suspension (better handling), as well as larger wheels and tires. One caveat: It also comes with summer only tires that are NOT suitable for ANY slushy/snowy/icy conditions. If you live in an area that gets snow, it's highly recommended that you buy a second set of wheels with dedicated snow tires.
  8. It's fairly common for OEM tires to only last 10-20k miles. Price out replacements on www.TireRack.com to prevent being shocked: It can cost $600-1500 for replacement rubber. Also remember that tires are the #1 performance mod available to you! There's a significant difference between cheap all-season tires and good summer-only tires. Ask any questions in the Tires, Wheels, and Brakes forum.
  9. BMW engines are tuned very well from the factory. It's very difficult to get more than a few horsepower out of intakes, exhausts, chips, headers, etc. (the newer the car, the more true this is)....unless, of course, you're talking about the N54 twin-turbo (335i, 535i, etc), in which case, completely disregard what I just said!
  10. The BMW Car Club of America (BMW CCA) is a great organization- membership ($48/yr) entitles you to a free subscription to the monthly magazine Roundel, discounts on parts at most BMW dealers, high performance driving schools/car control clinics/autocrosses, local gatherings/rallys/dinners, as well as a $500-1500 discount on your next new or CPO BMW (you must be a member for at least a year prior to purchase - and this transaction is completely independent of the dealer - you receive a rebate check after purchasing the car for at your dealer-negotiated price). Join here and if you found this post useful, use me as your referrer (Kris Linquist #170334)
I agree with you.
But these following three check....
1.Exterior: Take a look at the exterior of the car properly.
The moment you see a dent or a scratch think twice before buying it since it may have been involved in an accident.
2.Engine: Lift the hood and inspect the condition of the engine.
Even if you are not an expert at such things, you can definitely look for anything suspicious like excess oil splattered over different components and things like that.
These will actually help you in making a decision whether to purchase the vehicle. Also check for the various oil or fluid levels of the car. If any of the components look extremely dirty then it may mean that there might be an issue with it.
3.Test-drive: Never buy a car before test driving it, even if it is a used BMW.
Tacoma citizens, amongst others in US have faced numerous issues in the past just because they did not perform this test before buying the vehicle.
