nobody can balance my 21 inch "128" - Bimmerfest - BMW Forums
Old 03-30-2007, 07:50 AM
minnesotaR6 minnesotaR6 is offline
Mein Auto: 95corolla
went to 2 diffrent tire shop. both balanced diffrently
still get a shake in my steering wheel at 45-70!!
should i bring it to bmw and have them balance it?
could it be somthing else?
Old 03-30-2007, 08:06 AM
n3rd n3rd is offline
Mein Auto: E70, GT4, RRS
Your tires could always have a flat spot. Be sure you get a gauge and check the tires all around. If they're good all around. The rims could be flawed (bent). If thats okay as well then go to BMW to balance. They should have no problem doing it for you.
Old 03-30-2007, 08:27 AM
i believe one rim is bent. maybe ill order a new one. ill check all the tire pressure today also
Old 03-30-2007, 03:07 PM
bimmer7's Avatar
bimmer7 bimmer7 is offline
Mein Auto: M3 Cab, 760Li, '08 LX570
Yesh a bent rim can make a whole world of diffference in your vibration
Ask me I went bananas over that with my 745
2008 M3 Cab -- Alpine White, Blk Novillo
2005 760Li Individual -- Azurite Blk, Platinum Merino, ED
2002 745Li -- Sold
2000 750iL -- Sold
Old 03-30-2007, 03:24 PM
drockstar's Avatar
drockstar drockstar is offline
Mein Auto: 2002 745Li
If it's not bent, tell them to use road force balanceing. I had to do that with some 22's on my Maxima.
Old 03-30-2007, 09:27 PM
standex standex is offline
Mein Auto: 750LI
I had, still have to deal with this issue. In my case, the BMW hub diameter is less then the hub diameter on the rims. We are looking at only a .030 total difference (.015 on a each side. Because the lug nuts have some play, the rims do not center with the lug nuts.
A company in Florida sells aluminum hub centric rings. These are not perfect but work reasonably well. As a test, I cut up an aluminum can, made four spacer pieces to fit between the wheel rim hub and the car hub. Then I put a second and third set of spacers on top of each other until there was no more space to fit any spacers. You have to install 4 each time to assure the wheel stays centered. These stay tight enough that they actually won't fall out. Good luck
Old 03-31-2007, 11:57 AM
drockstar's Avatar
I have had hub-centric rings and they work great. But aluminum cans and washers? haha, nope - don't go there.
Old 04-01-2007, 09:09 AM
curve001 curve001 is offline
Curve
Mein Auto: BMW 745 LI
Yo need to go to a garage with the special laser tire balancing equipments. I had the same issues with one rm slightly bent but with the laser balancng where they look at 2 dimensional balancing (not jst along the rms but also across the rimms where to lace the stickies). my tires are now prefect. In Toronto, Active Ross and Green has that machine.
Old 05-03-2013, 11:31 AM
ZedJes ZedJes is offline
Mein Auto: 750LI
Bent Rimm Repair
Has any one had a slightly bent rim repaired?
Old 05-03-2013, 03:01 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
there are many shops that can repair the wheels even if they have a crack in them. Google a wheel repair company in your area or call up your local dealer to see who they use. They usually charge b/w 50 and 150 a wheel to repair all the defects.
Wheel repairs usually work well, but sometimes if the person is inexperienced can lead to some issues!
2013 TL Advance 3.5L
2006 BMW 760Li - Alpine White/Ebony-Ivory Two Tone
2010 Honda Accord EX - Basque Red/Ivory
lOE Fog Lightsl
2007 MDX Sport/Ent.- NGM/Taupe
lRB Slotted RotorslRoof RailslFront & Rear GarnishlAuto Mirrorl
2004 TL NAVI Auto - SSM/Quartz
lComptech SwaybarlHacked NavlTVNAV2GolUSA-SPEClDVD PlayerlSwitchblade KeylRB Slotted RotorslA-Spec Brakesl
Old 05-03-2013, 08:22 PM
mgokool mgokool is offline
Mein Auto: 2013 528iX Build 03/13
+1 for road force balancing....
*** 2013 528i X-Drive ***
Old 05-04-2013, 11:12 AM
Mein Auto: 750LI
C,
Thanks for the info. Any TPM issues that could result from the repair?
Z
