Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series
3 Series & 4 Series
The BMW 3 Series and 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 01-25-2003, 01:14 PM
e46supra e46supra is offline
S62 powered
Mein Auto: ///M5
Amazing E46 328i Suspension Problem (pics)
Hello fellow Bimmerfest members:
I have been complaining to my local dealer (Cunningham BMW) about a clunking noise in my car when I drive over bumps at a low speed.
Well, I decided to lift the rear end of the car and take a look see at what was wrong. The sound came from the driver's rear side of the suspension.
Here is what I found:
The 19mm bolt holding the lower control arm (is that what it is called?) to the differential bracket (again, is it what it is called)is about 3/4 out of its hole. It is also bent out of shape, possible the only thing keeping it there. It has caused the hole in the differential bracket to change shape.
I complained about this problem to them twice while my car was in the shop at Cunningham BMW and they said they "lubed it". Don't you think they would have seen a bolt that is sticking out like this one is??
What should I do guys? My car is 2 months and 500 miles out of warranty, but I complained about this noise while it was still in it's warranty period. My car is a 1999 328i 5speed with a stock sports package suspension and stock type 44 wheels.
I have included pictures..
Old 01-25-2003, 01:16 PM
S62 powered
Mein Auto: ///M5
a picture from a different view.
Notice how large the hole has gotten in the differential cover/bracket/subframe (not sure what the proper terminology is)
Old 01-25-2003, 01:24 PM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
You should demand a repair under warranty. Clearly, they missed it.
Good luck!
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 01-25-2003, 01:33 PM
S62 powered
Mein Auto: ///M5
I do hope so.
I figure that BMW would, after owning 5 of their beasts!
1999 BMW 328i
1998 BMW 540ia (dad's car)
1995 BMW M3 (deceased 12/1/99 totalled)
1993 BMW 325is (still running strong!!)
1992 BMW 325ia (deceased 06/03/96 totalled)
2004 Mercedes Benz E55 AMG
2010 Toyota Prius III
Former: E39 M5, E46 M3, E36 M3, E53 X5 4.4i, E46 328i
nate's Avatar
nate nate is offline
I like cookies.
Mein Auto: 328Ci
Call the 1-800 number, they SHOULD fix it under warranty if you complained about it and they attempted a fix.
Old 01-25-2003, 03:18 PM
Andrew Andrew is offline
Mein Auto: 330ci
Originally posted by e46supra
I do hope so.
1999 BMW 328i
You totalled 2 cars in a span of 3 years? I have been driving for over 25 yrs., and have yet to total a vehicle (knock on wood). If you were not at fault in either instance, then you just have bad luck. If you were at fault, then I am glad you don't live in MA-- my insurance is plenty high as it is.
Old 01-25-2003, 06:05 PM
S62 powered
Mein Auto: ///M5
1995 M3 was totalled in and unfortunate accident on the 94 east here in San Diego when I was driving to SDSU for an early morning final. Engine, front suspension and fronty body panel damage totalled 22K which was enough to total the vehicle.
1992 325ia was totalled because it was stolen and stripped for parts.
Old 01-25-2003, 08:12 PM
Raffi's Avatar
Raffi Raffi is offline
Hi
Mein Auto: Frankenstein monster
Don't take no for an answer. Demand that they repair the problem under warranty, since you complained to them when the car was still under warranty. If they refuse, call BMW NA. Good luck.
'01 330ci
Old 01-25-2003, 09:53 PM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
Did you ever had any suspension work done (springs, shocks...whatever)?
I've never seen this problem before. A couple of quick comments...The big "hole" on the diff carrier may be designed that way so when they fit the bracket on there's some room to adjust it. Then again I could be blowing smoke out of my @ss since I've never took that bolt off before.
But if you've never had any suspension work done, I can't imagine how this could have happened besides FACTORY DEFECT. If Cunningham BMW missed it twice already, I think you should approach BMWNA first and get THEM to put some pressure on the dealership to do the right thing.
But honestly though, mechanics are trained to fix customer complaints in a systematic way. If you tell them "car is clunking" all they'll do is lube various areas that can possibly cause the clunk. Now that you're out of warranty I suggest you go to a third party BMW mechanic instead of your dealership. Check the back of your local BMW CCA chapter newsletter for reputable mechanics.
"Bench racing" about track times driven by professionals are like a bunch of nerds arguing which Princess Leia is hotter, the slave Leia or the no-bra jail-bait Leia. No matter how compelling your argument is, the plain and simple fact is, none of you will EVER get to hit that.
Old 01-26-2003, 04:08 PM
10chi 10chi is offline
Send a message via AIM to 10chi
Mein Auto: 06 UDM
holy cow! I wonder if I have that problem. I had "clunking" noises too and had some suspension parts replaced. But the clunking never went away. I will definitely check underneath and see if I have that problem too.
Where are the women?
'06 E90 330i ZSP, ZPP, ZCP
Future: With this economy, who knows?
