Old 01-26-2003, 08:54 AM
scy scy is offline
Mein Auto: '00 Z3 Coupe
Onboard computer and clock wiring question
I purchased a '02 Z3 chrome dash and is thinking about replacing my Z3 dash with the updated dash.
My Z3 has the rectangular OBC with clock, temp, mpg, etc. The new dash came with the round clock but no round OBC.
My question is whether or not the OBC uses the same electrical connector as the clock? I couldn't care less for the OBC if I could plug the clock into the dash and have it work without modification.
I could open up the dash to look at the current OBC connector, but it's way too cold for that and I'm hoping someone here remembers what the OBC connector looks like.
The clock has a three pin connector.
If the OBC connector is different, does someone here have a round OBC from a '00-'02 Z3 forsale?
Thanks.
Old 01-26-2003, 07:57 PM
Ron Stygar's Avatar
19,585 Miles
Re: Onboard computer and clock wiring question
Thanks.
The OBC connector is 12 pin.
The round OBC 62 13 8 383 661 retails for $164.00. It is the same rectangular one that you have with a round bezel. You will have to have it coded or swap the bezels.
Paul McLaughlin at South Motors BMW in FL will discount 25% from suggested retail. 1-800-883-7278.
Old 01-26-2003, 09:17 PM
scy scy is offline
Re: Re: Onboard computer and clock wiring question
Yeah I read that the OBC needs to be "coded within 36 hours" from the ETK, but I don't know what that means.
Is the OBC "married" to the VIN, ala JimC's Shark Injector? Does this mean I can't use an OBC from another Z3? How do I code and uncode the OBC?
I didn't know I could swap the bezels. So if I can find a wrecked Z3 OBC, I can just swap bezels without going through the hassels with the code.
Thanks again.
Old 01-26-2003, 09:23 PM
Ron Stygar's Avatar
19,585 Miles
Re: Re: Re: Onboard computer and clock wiring question
Thanks again.
The dealer codes the OBC to the type of car. The coded OBC in my 318ti works in my Z but the mpg and miles left were not accurate.
The bezel swap is a good assumption.
Old 01-27-2003, 10:02 PM
Daver Daver is offline
Shake well
Mein Auto: 2003 325iT
My dad's 2002 Z3 Coupe doesn't have one, and he'd really like one. So is it as simple as purchasing an OBC module (assume self-install) and having it coded by the dealer?
I thought AndyM didn't find an OBC connector in his recent dash disassembly.
And, assuming the connector is present, and I get it installed and coded by the dealer, what about the toggle function that is supposed to be on the left stem?
Do no OBC cars have the same stem (and the function unused), or will that need to be replaced as well ... or can a momentary switch be installed elsewhere (e.g., switch blank adjacent to steering wheel)?
daver -- 2003 325iT
Old 01-27-2003, 10:12 PM
AndyM's Avatar
AndyM AndyM is offline
Suede Master
Mein Auto: '02 3.0i Z3 Coupe
I didn't see one. We didn't spend a lot of time looking and I would imagine that it could have been tucked away under the carpet (as BMW likes to do). There were no connectors just sitting around.
