Old 04-11-2007, 09:45 PM
IraXI IraXI is offline
Mein Auto: 06 330XI 6Spd
My fear of Modifing the CDV
Ive been driving standard for a long time and like to think I am very good at it. I havent stalled a car in over 4 years. I ordered a UCC clutch stop for the car, and I also wanted to get a modified CDV however I have a fear. I work for a car dealership selling Nissan's. Over the course of any given week I drive about 30 or so cars that are not mine.. I would say 5 or 6 are standard. My problem is if I drive a car for a few hours I start to get used to that clutch, then I hop back in my own car and it takes a few minutes to adjust to my car again. Im not stalling the car by any means but sometimes I have to adjust how much gas to give as I release the clutch. My problem is I dont want to damage my clutch if I modify my CDV when I have to readjust to the car. Im left in a position as I dont know what to do. What would you do? Modify it? Keep OEM? Thanks for the help!
Matt
IraXI's My Space
Old 04-11-2007, 11:00 PM
peeti peeti is offline
Mein Auto: 07 Moupe
The CDV actually IS damaging to the clutch. It saves on the drivetrain - supposedly. That's it's purpose (that is limit torque delivery to wheels, through all the 'stuff'). By removing the CDV, you're going to INCREASE clutch life, but possibly increase the likelihood of damage to, say, the diff.
Hope this helps you - and btw, do it and don't look back!
Old 04-11-2007, 11:01 PM
MysticBlue MysticBlue is offline
They call 'em rigs here
Mein Auto: '09 E92.
I don't think the CDV's purpose is to save the driveline from the occasional stall. That's not nearly the kind of stress and wear and tear that would come from dumping the clutch at high speed or doing power shifts which is what I think it is made to help protect against. I had a 330i for 4 years, put in a modified CDV after one year and never looked back. Made a huge difference. About a month after I got my M Coupe I didn't even bother with the modified one, I just took it out. My vote is do it. If something is going to break just because you let the clutch out a little too fast and stall the engine once in a while, then it's going to break anyway.
09 E92, IB, DCT.
Old 04-11-2007, 11:16 PM
Mein Auto: '09 E92.
peeti is absolutely right. The CDV shifts wear and tear from the drivetrain to the clutch. I experienced this first hand in my 330i. While doing full acceleration shifts I could tell the clutch was slipping. These weren't power shifts, but close...full throttle until close to redline, clutch in and lift throttle and shift up, all at the same time, as fast as possible, then clutch out and full throttle, also as fast as possible. Under that full throttle, immediately after shifting, the clutch took 1/2 a second to fully engage. With modified CDV, that 1/2 a second of slippage went away. I didn't drive like that very often of course, but when I did, it was a good indication of what was going on and helped explain why, as everyone else has indicated, it was also hard to drive smoothly when you are driving normally. It just adds another unpredictable variable to the shifting process. I took it out of my M before it was broke in so I never got to do a before and after comparison regarding hard acceleration, but it did make a difference as far as smooth shifting during normal driving.
09 E92, IB, DCT.
Old 04-12-2007, 02:21 AM
BKH BKH is offline
Mein Auto: E39 M5, E36 M3. E86 Z4 MC
My replacement CDV is going in later this morning. I can't wait to get that OE POS outta there. Also, Hawk Ceramic brake pads.
Old 04-12-2007, 06:54 AM
Zuzax's Avatar
Zuzax Zuzax is offline
Calvinball Professional
Mein Auto: '07 M Roadster
Why bother putting in the fake CDV? If something breaks and you try to claim warranty on it, I think you'd have a much better chance with BMW by just not having the part versus having an obviously bogus (fraudulent?) part in the car.
And if you're not going to claim warranty, then why put a fake part in at all? It's not like it's an aesthetic consideration.
2007 Z4 M Roadster Sepang/Sepang-X/Black, Premium, Nav, BMW Strut Bar, Stubby Antenna, Dice, UUC clutch stop, Star Specs, and the rest joyfully stock.
Old 04-12-2007, 07:17 AM
wildag's Avatar
wildag wildag is offline
///M 'n it up!
Send a message via AIM to wildag
Mein Auto: '06 Z4 M Roadster
From the exterior, the replacement CDV looks exactly the same. And I would bet that no service tech is going to notice or care that the hole is larger. If he does notice that its larger, he'll probably just assume it was manufacturing change. Therefore, he will never report the modification that could potentially void the warranty.
Old 04-12-2007, 07:55 AM
inTgr8r's Avatar
inTgr8r inTgr8r is offline
Mein Auto: Z4 M Coupe
Originally Posted by IraXI View Post
............Im left in a position as I dont know what to do. What would you do? Modify it? Keep OEM? Thanks for the help!
Matt
Like the Nike slogan "just do it"
Have you read this?
Old 04-12-2007, 08:04 AM
SacM3 SacM3 is offline
Mein Auto:
As I'm not at all mechanical, I'd want someone to do it for me so I don't screw something up. Where are folks going to have the CDV removed?
- 2007 SG M-Coupe
- 2002 M3 Convertible *Sold*
- 2000 323i *Sold*
Old 04-12-2007, 08:06 AM
I was going to be asking the same question. Im obviously not taking it to the bmw dealer to do this. I dont trust the nissan service techs in my dealer to do it either.
IraXI's My Space
Old 04-12-2007, 08:14 AM
Zuzax's Avatar
In most metro areas there is usually one or two highly recommended independent BMW shops that have probably done this before. A bit of local investigation will probably turn someone up. If you don't have the tools and knowledge to do it yourself, this is the way to go.
Old 04-12-2007, 10:43 AM
reidconti reidconti is offline
Officially Weird
Mein Auto: Clownshoe,Miata,WeeStrom
After 2-3 hours laying in brake fluid trying to get my UUC stainless line on my car, I gave up and went back to stock. At least I can drive the car again.
Somehow, the hardline had damaged threads, and the stainless line simply would not go on. The "factory" one went right back on no problem. However, I am beginning to wonder if it was already "fixed" be a previous owner, because the ID of the stock line looked bigger than the ID of the stainless line, and I've never had any of the clutch problems CDV users complain of. *shrug* Will have to drive another S52 car with a CDV delete to compare.
Old 04-12-2007, 01:43 PM
Adam12Hicks's Avatar
Adam12Hicks Adam12Hicks is offline
Send a message via AIM to Adam12Hicks Send a message via Yahoo to Adam12Hicks
Mein Auto: 06 Sapph Blk M Roadster
I'll help anyone in Dallas / Ft. Worth area with theirs. Just bring it by.
2006 Z4 M Roadster
2005 X5 Kid Truckster
1991 318is e30 Play Car
Old 04-12-2007, 03:47 PM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
My honest opinion is that the CDV is only there for one thing. To make sure the M cars clutches last the 36000 mile 3year maintenance period. I bet it does nothing but put more stress on the drivetrain to save the clutch a little.
I would change it immediately. If I don't want to dump the clutch, my foot can feather it just fine.
2001 Alpine / Schwartz Coupe
2001 Estoril / Estoril Coupe
2001 Steel Grey / Estoril Coupe
1999 Estoril / Estoril Coupe
Sunroofs are for girls.
Old 04-12-2007, 03:48 PM
Mcoupe Mcoupe is offline
Mein Auto: 99 M Coupe
I'm close by if you're interested, but I also have a LTW fly, so that'll be different as well.
Old 04-12-2007, 07:41 PM
DaveZ's Avatar
DaveZ DaveZ is offline
The knights who say Ni!
Mein Auto: 2006 Z4 M Roadster
My BMW dealer did the CDV removal for me.
DaveZ - http://www.zeleznik-klein.com/z4
2006 MZ4 Roadster, Interlagos Blue, Light Sepang, CF Trim
CDV delete, OEM Strut Bar, Homelink
Old 04-12-2007, 08:45 PM
I have Turner Motorsports about 20 minutes away from me, Im sure they wont have any issues doing it for me.
IraXI's My Space
Old 04-15-2007, 05:41 PM
bigbirdk bigbirdk is offline
Mein Auto: Z3 3.0i
I'm no "super-wrench". but this was an easy install for the weekend warrior. Two wrenches and a vice-grip. MUCH better clutch engagement!
Old 07-11-2007, 06:54 PM
beachbuggy beachbuggy is offline
Mein Auto: 2001 M Roadster
A must do mod.
Same here. My dealer also did my clutch pressure line swap out. Dealer charged 1/2 hour labor ($62.50) to do work. I had work done while car was in for programing recall. HUGE difference thru all gears, but especially 1st to 2nd.
Snooker
Old 07-11-2007, 07:06 PM
Ron Stygar's Avatar
19,585 Miles
Bmw
BMW is aware of CDV, center over and extension spring along with after market clutch pedal bushings.
Old 07-11-2007, 08:41 PM
Hey now... what's this about the clutch pressure line swap? Did I miss something while I was building my home theather room and not watching the forums? I've done the CDV but I'm all for anything that makes this thing drive more like it should... can someone point me to a URL?
2006 Z4 M Roadster
Old 07-12-2007, 08:04 AM
mjposner mjposner is offline
Mein Auto: BMW M
I just got my UCC Clutch Line and will have her installed next week.
Old 07-12-2007, 07:31 PM
The S54's do not have the CDV as do the other Z models. Their pressure clutch line has built in restictions via smaller diameter fittings. By swapping out the OEM clutch line from the S54 to the non S54 line (standard Z part#), it accomplishes the same result as removing the CDV in the standard Z pressure clutch line. I think that's an accurate answer. Ron, care to elaborate further?
Snooker
Old 07-13-2007, 04:34 AM
inTgr8r's Avatar
Z4 S54 has a CDV
Old 07-13-2007, 06:33 AM
Mein Auto: '09 E92.
Originally Posted by inTgr8r View Post
Z4 S54 has a CDV
+1. Mine definitely had one... for about a week.
09 E92, IB, DCT.
