Old 04-19-2007, 06:21 PM
RedButtedMonkey RedButtedMonkey is offline
BlackSapphire
Mein Auto: 2003 540i M-Tech
Originally Posted by chivas View Post
left is sport, right is race
both for E39
Wrong!
50464 is what I have and they are definitely sport springs, NOT race. Dark, metallic blue, same model #, etc.
Old 04-19-2007, 06:49 PM
chivas's Avatar
chivas chivas is offline
You Lick It, You Own It
Send a message via ICQ to chivas Send a message via AIM to chivas
Mein Auto: 98 540i/6
Originally Posted by RedButtedMonkey View Post
Wrong!
then what's the one on the left????? eh??? confused
americandan.com
It takes a lot of work to be lazy.
Old 04-19-2007, 07:05 PM
BlackSapphire
Well I'll be damned!!!! OK, for a second, try to ignore the fact that everyone thinks a sport/no sport application are the same when it comes to aftermarket springs.
It appears that there is some confusion afoot (on my part and others)!
When you go to the H&R website and you look up springs for the 540i sport application, they list the 50464 springs (what I purchased). In fact, it says this:
Stage - Sport Spring
Chassis / Drivetrain - E39
Notes - not touring
Approx. Front Lowering - .75"
Approx. Rear Lowering - .6"
Part Number - 50464
Now, here's where it gets interesting. When you look up a 540i (non-sport), here's what you get:
Notes - no sport sus
Approx. Front Lowering - 1.3"
Approx. Rear Lowering - .75"
Part Number - 29764
Stage - Race Spring
Notes - not touring, no sport sus
Approx. Front Lowering - 1.7"
Approx. Rear Lowering - 1.2"
Part Number - 50464-88
Mine don't say -88. I wouldn't even wonder about that if the fact that the Sport springs for the 'non sport 540' weren't listed as 29764 and the pics show an obvious height difference (thanks for the pics btw).
Judging by your pics Dan, I'm inclined to think that there really is a difference between springs for the sport and non-sport applications. Chris with understeer thinks so too. Sorry to get your panties in a wad Franka - I know you're getting ready to blast me.
Old 02-20-2013, 04:29 PM
G-Moussa's Avatar
G-Moussa G-Moussa is online now
Mein Auto: 2002 BMW 540i
Notes - not touring
Part Number - 50464
Part Number - 29764
Stage - Race Spring
Basically what I want to know is which ones do i buy. I have 2002 BMW 540i with sport package. Therefore I have the sport suspension from BMW and a bit of a lower drop then the standard 540i. So do i buy the sport suspension 50464 (the first one listed) or the race which some people said has the same drop as the sport for the sport models... if that makes any sense. Help would be appreciated. Thanks
My "check engine" light came on while driving to work this morning. I looked and the engine is still there...silly light
Old 02-21-2013, 02:10 AM
BlackSapphire
You definitely want the 50464. It'll sit perfect.
Old 02-21-2013, 02:37 AM
jbonly21's Avatar
jbonly21 jbonly21 is offline
Mein Auto: 02 525I SPORT
I also have the blue one on my 528i, and I am happy with the drop and ride. With non sport shock.
ID:	363214   Click image for larger version
02 525I Sterling Gray, 18" M Parallels, M Tech bumper, Magnaflow Highflow cat, Resonator delete, 3" OBX muffler, H&R spring and Bills sport shocks.
RIP ALPINE WHITE 97 528I
Old 02-21-2013, 04:54 AM
JimLev JimLev is offline
Mein Auto: 540/6, S60 Volvo, Tribeca
Here's my '00 540 sport with the 50464 springs. The front drop is more than what H&R has listed on their literature. The front drops about 1.5" and the rear about 1/4". I'm using Koni FSD's.
The fender arch is at the top of the tire on the front and rear. They are about 15% stiffer than the OEM sport springs, the ride is not jarring at all.
2000 540/6 Slightly tweeked...everywhere
Old 02-21-2013, 11:15 AM
G-Moussa's Avatar
Amazing thank you, I just wanted to know if this was the one for a 540i already with stock sport suspension. Also you think these will work on my sport 540i with 19" wheels? Hopefully it won't rub my fender
Old 02-21-2013, 11:16 AM
G-Moussa's Avatar
That looks sick. Just what I'm looking for. I want a nice low stance and something that will handle on turns better. I also want to make sure these will work with my 19" wheels in my signature. Hopefully it won't be too much of a drop
Old 02-21-2013, 12:04 PM
NoWayJose's Avatar
NoWayJose NoWayJose is offline
Mein Auto: 00 528ia Sport
i think it looks lower in person
00 BMW 528ia Sport
M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza VXX 10w LED Halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks adjustable, 19" M6 Reps, Full LEDs.
Old 02-21-2013, 06:04 PM
The fit will depend on the aspect ratio of your tires. My tires are ~25.3" in diameter.
Your sidwalls should be shorter than mine so your diameter should be close to mine.
My tires are PS2's, fronts 235/45/zr17, rears 265/40/zr17.
Hi Jose, see you changed your sig.
Old 02-22-2013, 07:11 AM
Andreas540i's Avatar
Andreas540i Andreas540i is offline
Mein Auto: 1997 BMW 540i
My sports were gray. H&R sport with OEM non-sport shocks.
ID:	363340   Click image for larger version
1997 BMW 540i
Hella Angel Eyes - Eyelids - Hella LED Tail Lights - Clear Side Markers - Race Mesh Grille - E60 Style 122 Wheels - M5 Grill
AFe Air Filter - Cool Carbon Brake Pads - Ebay Slotted and Drilled Rotors - Y Resonator and Silencer Delete
Custom Center Consol w/Oil Temp, Volt Meter, and iPod Dock - iPod Adapter - Arm Rest Subwoofer
Old 02-26-2013, 04:58 PM
Tom 01 6sp Tom 01 6sp is offline
Mein Auto: 2001 540i
I did the complete suspension front and back on my 01 Sport. Went with the H&R Sport when I did it. Since I did everything at once I really can't say what kind of diff the springs made in regards to stiffness. The back dropped about a 1/2 inch compared to the original sport spring. The front dropped a little over an inch. It accomplished what I wanted which was dropping the front to match the back.
Here's a side by side comparison of the H&R(L) & OEM(R). Scared me at first.
Old 02-27-2013, 10:13 PM
jbonly21's Avatar
Got my bills sport today, put them in with the h&r, not much of a drop.
Old 02-27-2013, 11:03 PM
NoWayJose's Avatar
let them settle for about two days, if not check install
to match my license plate
00 BMW 528ia Sport
Old 02-27-2013, 11:31 PM
Erick_munoz Erick_munoz is offline
Mein Auto: 2009 328i Coupe
Just installed My H&R Race Springs today an I love the way it sits now! Perfect and as of right now haven't noticed much of a ride difference! Love them!!!!
Old 03-01-2013, 10:34 PM
jbonly21's Avatar
Love the drop I am running the stock non sport shock up front, and bills sports in the rear.
