Old 04-22-2007, 04:07 PM
KenU KenU is offline
Mein Auto: '07 750i Sport
Help! Window goes up; then 1/2 down - stops
This is a good one..
Just shut the car off; hit the window button to bring it up. It goes up, then goes down half-way and stays there. It won't stay in the up position. Tried this a few times with the key in , the key out. The car running, the car off, etc. Same result.
Not too thrilled with this as I leave this car in my driveway.
Anybody??
Old 05-01-2007, 07:51 PM
yzpilot yzpilot is offline
Mein Auto: 750Li
Hold switch in up position
I had that problem. Pull the window switch up past the resistence point and hold it there. The window will roll up, then back down and then up again. It goes up almost all the way and if you continue to hold the switch up it will ease up the last little bit until it's fully closed.
It's the "pinch protection" that's causing it to roll back down half way. It thinks it caught your finger or something. Holding the switch up overrides the pinch protection system. It's in your owner's manual if my description doesn't make sense.
When it happened to me I planned on taking it to the dealer, but it never did it again. Just had a problem that one day.
Old 05-02-2007, 06:08 PM
splatmatic splatmatic is offline
Mein Auto: 06 750i Sport, 04 X5 3.0i
Exclamation
Are the windows tinted? We ran into this problem last week and brought our 7er in to the dealer on Monday.. They said they could not repeat the problem, but suddenly as soon as we turned the car on we got the window to do it. They took the car over night and the master Tech. said the cause was the window tint. The SA did not agree with him on that and inserted the problem/question in a PUMA system (its there help system). Hopefully there will be a solution to this problem.
also guys, which window is this happening on? For us, its the passenger side window.
-2006 750i, black on black, ZSP, Comfort package - European Delivery
-2004 X5 3.0, Stratus Gray Metallic on Black, fully loaded
http://gallery.sphost.org <-- NJBMWCCA autocross pics and European Delivery
