E46 (1999 - 2006)
Old 05-11-2007, 08:44 PM
forzam forzam is offline
Mein Auto: 04 325Ci
2004 325Ci Passenger Door Panel Removal
Hello all,
Unfortunately, the subwoofer speaker grill is broken on the passenger side. In order to replace this, I have to take off the door panel. Is it correct that you don't have to disconnect the battery to do this (airbag)? If you do disconnect the battery, will it screw with any of the electronics?
Also, if you have any experience replacing this part, I would like to hear about it.
Old 05-11-2007, 08:58 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
You don't have to disconnect the battery - just don't turn the key to the ON position with the airbag disconnected.
Follow a link in the wiki for the window regulator fix to find more info on removing the door panel.
Old 05-11-2007, 09:23 PM
HW's Avatar
HW HW is offline
lurking
Mein Auto: 323ci, manual
some of us here have unwillingly become professional e46 door panel remover/reinstallers
2010 Acura TSX manual
Old 07-21-2007, 01:53 PM
guitarslinger guitarslinger is offline
Mein Auto: 325i/2001
How big of a job is this? 1hr/door ? ...also, is this a 1 man job or do you need assistance? I'm in the same situation of removing the front panel to re-connect the tweeter...
Old 07-21-2007, 02:33 PM
crowz's Avatar
crowz crowz is offline
Mein Auto: '00 323i/97 528i/94 318is
It takes about 15 minutes total to do what your wanting to do. You dont have to touch the airbag if your just plugging the tweeter back up.
As soon as you remove the door panel itself you should see the tweeter wires. I did on mine.
