E39 Auxiliary Fan DIY write up-With Pics.
MODS PLEASE STICKY
Thanks to E39Dream for helping me when i did it and being patient to answer my questions. DISCLAIMER: I am not responsible for any damages to your car upon using this or any other DIY write up. You assume all responsibility for damages or improper installation to your car. Hello, Here is a write up for a E39 Aux fan change. This was done on a 1999 528I and may differ slightly for your car.(resistors) Job difficulty 2.5 wrenches out of 5. Tools Needed -1/4' ratchet -3/8' ratchet -8mm socket -10mm socket -13mm socket -Needle nose pliers -T45 torx bit -8' extension Parts Needed - Auxiliary fan assembly - see No. 5 in link below http://realoem.com/bmw/showparts.do?...& hg=64&fg=55 -Resistor No. 08 on link above. - 50 amp fuse - various fuses. - Rivets Nos. 22 and 31 ten of each http://www.realoem.com/bmw/showparts...& hg=51&fg=15 before ANYTHING. Turn your ac on after your car has been operating for a while and is HOT 60 degrees and wait, if fan turns your aux fan is fine, if not you have a problem. I have been told it can be your aux fan assembly itself, blow fuse, OR coolant temp sensor, or failed relay (ive been told this is very rare.) FIRST THING, check the fuses in your glove compartment, Fuses in glove compartment guide ![]() This is a pic of fuse 75 and 76 lookin lying down above into your glove compartment from the passenger side foot well. That panel needs to be pulled BACK towards the passenger side seat with SLIGHT pressure to the floor and should come out. THE AREA THAT 75 and 76 are in is circled. you will reach in there, and grab the fuse and push UP towards the sky and it will come out. ![]() Preparation park your car on a flat leveled surface or your driveway. put a blanket or sheet infront of your bumper, and set weights down so it doesnt fly away, i used my tool box. here we go! 1- Use the 8mm bolt to remove the 4 bolts that hold the headlight. Make sure you remove the bulbs from the housing of the headlamp. there are 4 screws 2 on top and 2 on bottom. ![]() 2- Remove 3 bolts from your wheel well, 1 above and 2 on bottom. refer below Top bolt ![]() Bottom bolt-the second one is just left to that, it may help to turn your tires side to side. ![]() 3- Go and lie down on the sheet you just put in front of your front bumper. You will look above the grills in your bumper and see little buttons, these are the plastic rivets. MAKE SURE YOU BUY EXTRA ONES FROM THE DEALER. 10 OF EACH TO BE ON THE SAFE SIDE IS WHAT I DID. use the needle nose pliers and pull away the center pin, and pull out the rest of the rivet. there are about 4 rivets on each grill, pull them all out and pull away the grill. ![]() 4- You will now see T45 torx bolt on the left of your license plate, and the right, the grill covered this area. Heres a pic find both and unscrew using the T45 bit. ![]() 5- Disconnect fog lights from the back You should now be able to remove the bumper, MINE however was unremovable. so i had to remove the bumper shock absorber pictured below This isnt necessary to remove it, but if your having a tough time getting the bumper off, it helps. after you have done 1-5. have a friend support the bumper while you go to each side and SLIDE out the bumper from its track, it sits in a sliding track. ![]() 6- This is what your car should look like now. ![]() 7- Use a 10mm bolt and remove 3 bolts that hold this air snorkel. the next one is to the right UNDER the snorkel. last one is all the way to the right. cant miss it. ![]() ![]() ![]() 8- Use the same method that you used for the grill on these plastic rivets Remove ALL 3 ![]() 9- This rivet holds the power supply to the Fan, disconnect the wire this wire from the fan assembly This is another rivet that i broke, but my dealer gave me a plastic zip tie and said this is better ![]() 10- Remove 4 fan bolts, these are the 13mm bolts. there are 4. do the same on the opposite sides also remove the kidney shroud which you removed the 3 rivets from. BE VERY DELICATE WITH THE SHROUD it breaks easily. Front right ![]() front right bottom ![]() 11- Gently remove the fan frame assembly. MAKE SURE YOU SEE EVERY LITTLE POINT IN TAKING IT OFF, THE NEXT ONE NEEDS TO BE MOUNTED ON EXACTLY THE SAME OR IT WONT WORK. Once removed, clean all the crap. (if you have a resistor now is the time to replace it use diagram to locate resistor, if its not there you dont have one. http://realoem.com/bmw/showparts.do?...& hg=64&fg=55 number 8) Hook up the fan, let the car run for a bit and see if the aux fan is working, there is no guarantee it will work, because the engine needs to be at a certain temp. Put everything back together again. Go to Autozone, buy R134a with a guage, turn ac on at 60 and fill the AC to the BLUE level of the guage. If after ALL of this your aux fan is not working, it could be the coolant temp sensor pictured below ![]() Buy soda, drink, and look at the progress youve made. and now Congratulations your Auxilary fan is now working. its better than paying 900 at the dealer right! Cost Aux fan assembly 297 50 amp fuse 2 dollars. rivets about 3-5 dollars. coolant temp sensor 22 resistors 60 soda 1.39 DISCLAIMER: I am not responsible for any damages to your car upon using this or any other DIY write up. You assume all responsibility for damages or improper installation to your car. QUESTIONS!?!?! Pm me. Last edited by SleekBMW; 05-13-2007 at 01:39 AM. |
Beautifully done. Thanks for sharing this with us.
Your welcome and ty
how long did this fix take you?
for a newb at this stuff, it will take you 3 hours, keep in mind i took the car apart 3 times, first time 3 hours(forgot parts)
then 45 mins after that. |
Great Stuff mate!!! very detailed and complete.
Sheer Driving Pleasure on The Ultimate Driving Machine |
Will this work on a 2001 525i bimmer that has a bad pusher fan in front of the radiator. I have taken my bumper off before so I know how to do that. But is that the only way to get to the pusher fan? robertlking@verizon.net
Yes, great write up and definitely money and time saving. The only thing that I noticed was the torx bit is actually a 47 and not a 45. Thanbks alot and that was one of the best waters I have ever enjoyed after a job.
Great DIY
Thanks for the great instructions, saved me about $350. I have a 2002 530i and the instructions for this apply without many differences.
Actually, the Torx bit is a T50. You can of course get a smaller one to go in, but the 50 is the perfect fit.
Great write up.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03 Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02 |
Just completed this project. Very easy thanks to this DIY and my BlackBerry Playbook. Took me about an hour, thank you.
Thanks for the write up with Pics...Going to Replace my now...will let you know how it goes.
Went perfect! AC blowing nice and cold. While the headlights were out I Purchase a 3M headlight restoration kit...they look brand new! Last edited by rdeleon11; 09-30-2012 at 04:14 PM. |
I have a 1997 540 I e39 and am in the middle of replacing my auxillary fan. I don't see the t45 bolt ? I was wondering if mine had on ? I've got my headlights out can some one please help? Thanks Tal.
Problem solved!! I removed the grill and found the bolt!!!! This thread is amazing, I finished the job!!! Thanks again Talmadge.
For the crosslinked record, JimLev offers good advice here for discerning aux fan types:
- DIY for how to replace the auxiliary fan (1) (2) (3) & how to test the cooling system auxiliary electrical fan (1) (2) & the infamous fuse 75 (1) & the aux fan relay (1) & an exploding aux fan noise situation (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
Just done this job on my 2001 M54 Touring.
I have the PWM e-Fan with three wire connector. The DME had a code for no response from E-fan. Another post I found suggested checking for the control square wave with an oscilloscope which I did. INPA has an 'ACTIVATE', 'E-Lufter' facility for simulating fan speed demands from 10-90%. The signal wasn't present at the fan connector, but I did find it in the e-box with the DME. I examined the connector wiring, and sure enough it was corroded about 4" down the cable and broke without any effort. A new piece of wire spliced in, and it's all over. Looks like I saved a couple a hundred bucks!! This is a common theme with BMW. Lots of clever wiring which doesn't stand up to the weather |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
