Old 05-17-2007, 10:32 PM
odacity509 odacity509 is offline
Mein Auto: 1997 528i
tail light warnings in dash
I have a 1997 528i and I'm having some problems with the lights. When I put the car in the start position everything comes up as normal. Then the car picture or light comes up, but the little lights that come up on the back (still in the dash) indicating that the bulbs in the back need to be changed or something like that are still there. So I checked the blinkers, lights, and brake lights and the problem is the brake lights. I changed the bulbs and the light symbol on the dash still does not go away. Can anybody help me???
The clear bulb and the one next to it are both good bulbs. suggestions anyone?
Are the clear lights supposed to light up when the brakes are pressed or are the clear lights just the reverse lights?
Does anybody know a way to reset it? or am i just going to have to take it to a stealer?
I'll try to post some pics tomorrow and give some more info
In the meantime any suggestions would be greatly appreciated
Old 05-17-2007, 10:56 PM
JBss's Avatar
JBss JBss is offline
ASC OFF
Mein Auto: 528i
wiggle the bulb around a little
Mad Photo Skillz - Flickr
This is with the NAWZ
Old 05-18-2007, 04:29 AM
spydrz's Avatar
spydrz spydrz is offline
Sandlapper Chapter
Mein Auto: 2013 X1 xDrive35i
Chmsl?
1984 318i/man./Tornadorot*
1990 525i/man./Alpinweiß*
2001 525i/man./SP/PP/Cosmosschwarz/Sandbeige*
2002 X5 3.0i/man./SP/PP/Sirius/BT/Titansilber/Sandbeige*
2006 330i/man./SP/PP/CWP/Sirius/Blackline/Rear Fogs/Arktis/Grau*
2001 525i/step./SP/PP/CP/CWP/Xenons/Rear Shade/OEM Sirius/OEM BT/OEM AUX/M5 Rear Sway/Bilstein HDs/Beisan Vanos/Rear Fogs/Schiefergrün/Sandbeige*
2012 VW Golf R/Rising Blue*
2013 X1 xDrive35i Alpinweiß/Schwarz/M Sport/Premium/Tech/Dinan Stage 2
*retired
Old 05-18-2007, 09:38 AM
2slow4u's Avatar
2slow4u 2slow4u is offline
Mein Auto: 528i
It's most likely the third tail light in the center. I had the same problem. Open the trunk look up inside at the rear deck, you'll notice a little black square. Pry that off and twist the bulb holder out.
Old 05-18-2007, 09:42 AM
oembimmerparts oembimmerparts is offline
Mein Auto: 2001 Z3
You may also want to look for corrosion around the bulb sockets, I have seen a few posts where the metal tabs that contact the bulb are rusting.
Old 05-18-2007, 09:49 AM
armysweitzer armysweitzer is offline
Mein Auto: RB20 S13/ 1997 540i/6
what can you do in case of corrosion. Ive replaced my third tail light many times now and its still showing up.
Old 05-18-2007, 10:28 AM
2slow4u's Avatar
Mein Auto: 528i
If you have rust anywhere on the contacts, rub them down with rust remover or take some light sand paper and scuff them up a bit. you should be set. I wish the display would actually tell specifically which light it is out. I have a 98 528, perhaps later models do that and I'm just naive.
Old 05-23-2007, 10:01 PM
Yup, it's the middle brake light. I've replaced the bulb and it still shows up. I checked the connections but none of them look rusted. I read some posts about the bulb being brass so I got some stainless steel bulbs but the light still shows up. I thought it might not be making contact so I stripped some speaker wire and inserted it between the bulb and the metal thingy. I turned the key to the off position then back on and the light went away. The light went away for about ten minutes then it came back on. So I took the speaker wire off about 15 minutes later because the light didn't turn on and it still felt a little warm. I didn't want short circuit my car. So I am stuck in the same position I was, warning light still comes up even with a new bulb.
Suggestions??? Please....
