Old 05-19-2007, 07:50 AM
BigPimp's Avatar
BigPimp BigPimp is offline
Ten2Six
Mein Auto: '11 550i
How to reset brake pad indicator
Hi Guys, some help would be great.
I have e60 545. I replaced front brake rotors and pads last week, I did not replace the brake sensor as according to the computer, it had 6k last and it was ok when we looked at it in a garage.
So on Thursday, I tried to reset the brake pad indicator for the front, only to produce a negative result. In fact the indicator now shows -9000 miles and the brake light is on in the dash. I read through some threads here and people had similar issue.
So is the resolution to replace the sensor or is there another way to reset this? Am I doing something wrong during the reset? I am holding down the button until the P shows, let go, press and hold again for Reset? to show up and then let go, press and hold until it resets. It resets with -9000 miles.
Any help would be great as this is bugging the hell out of me. Thank you
Old 05-19-2007, 11:06 AM
killcrap killcrap is offline
Mein Auto: BMW
you cannot reset a worn out sensor, this sensor has a resistor built in, once the brake pad wears past this point. you probably will not be able to reset it. install a new sensor, it may take up to 3 consecutive resets to reset the light.
Old 05-19-2007, 01:42 PM
BigPimp's Avatar
Ten2Six
Mein Auto: '11 550i
Even if the sensor did not seem to be worn out and IDrive said that I had 6k left before replacement?
Old 05-19-2007, 08:38 PM
Mein Auto: BMW
6000 miles left would mean the sensor was worn out big time.
Old 05-20-2007, 09:08 AM
carl@carltaylor carl@carltaylor is offline
Mein Auto: 530d
i have the same problem after replacing the pads and rotors and sensor,have tried to reset many times and still getting the same -9000 miles and warning in the idrive display.the oil service interval reset without any problems.any further idears would be welcome
Old 05-20-2007, 05:17 PM
BigPimp's Avatar
Ten2Six
Mein Auto: '11 550i
I am planning to replace the sensor this week and hoping that the problem will be solved.
Is there a certain way to reset it that I am not doing? I select the brake pad option, let it go and press and hold again until RESET? appears, let go and press and hold again until mileage appears, which appears at -9000.
Old 05-21-2007, 04:24 AM
Mein Auto: 530d
replaced sensor with genuine bmw sensor and now reset mileage.as was said it took 3 attempts to reset but it did it.
Old 06-02-2007, 01:02 PM
BigPimp's Avatar
Ten2Six
Mein Auto: '11 550i
Latest update:
Replaced the sensor with an OEM sensor which was not purchase through BMW dealer. Still unable to reset the on board computer. Spoke with BMW, they suggested that it NEEDS to be a genuine BMW sensor and now it might even need to be reset using their GT1 system. Any thoughts?
Old 07-12-2011, 08:39 PM
SquashMolly SquashMolly is offline
Mein Auto: 2000 528i and 2000 323Ci
BigPimp, did you get your issue fixed? I am having same issue with rear brakes...keep getting -15000 miles when reseting computer, and dash brake light is on. Curious if you found out how to fix. Thanks
Old 07-25-2011, 02:51 PM
Reflex27 Reflex27 is offline
Send a message via AIM to Reflex27 Send a message via MSN to Reflex27 Send a message via Yahoo to Reflex27
Mein Auto: 2007 530XI
How much did the BMW OEM brake sensors cost from the dealer?
Old 07-25-2011, 03:06 PM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
On the 550i.. (from my visit)
Dealer list price..$35 , ECS tuning price (which BMW dealers will match) $19.
Just go to oem parts sites, find your part/price, print, take it to the dealer when asking for the part and done!
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 07-25-2011, 04:12 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Does the stealer REALLY match outside vendor's prices?
I never go to the stealer unless I'm bleeding to death already ... but ... this is the first time I've heard that the stealer will 'match' outside prices.
Is this the experience of others also?
PS: Here's what we use for price comparison on the E39 side of the house (should also work for the E60 as nothing is E39 specific below):
- BMWfans phantom parts diagrams (1) & realoem nominal prices by part number (1) & EACTuning prices by part number (1) & labour/labor rates by job shop rate by zip code (1) (2) (3) & where to find a good mechanic (1) (2) & how to join BMWCCA to lower parts costs & find helpful local friends (1) (2) & how to select a reputable BMW indy in your area (1) (2) & the most often recommended BMW-parts suppliers (1)
Old 07-25-2011, 11:51 PM
bluebee's Avatar
Since I didn't get a response here to this question today, I asked over in my home forum:
- E39 (1997 - 2003) > Has it been your experience that the local BMW dealer will match prices on E39 parts?
A half dozen people replied today, none of which said the stealer matches prices.
So, to the person who said that ... can you confirm that (wonderful, if true) oddity?
Old 07-26-2011, 08:38 AM
Dking078's Avatar
Member Supremo
As far as i know its just for parts, I DIY the install, Sorry for the thread jack
Well at least the dealers i go to yes. (Monrovia / Savage) in CA. (in recent times)
For little things under $10 they dont really match 100%
But all of my purchases so far have been matched using ECS's prices. ( ill try to use pelican parts too )
I just showed the rep. the paper and asked if he could match them and oddly enough he did!
My parts so far have been for the E53 & E60
I dont like the stealer that much too, but if they can match my price i'll go there.
ex. Dealer list price for Msport/M5 steering wheel trim (e60), list price $95! ECS matched price $55. 42% savings!
Old 07-26-2011, 09:01 PM
Hogie's Avatar
Hogie Hogie is offline
It's 5 O'clock Somwhere
Mein Auto: 330i, Z4 3.0, 535i
I have not changed mine in the e60 but I did do my e90 rear brakes. I did buy a genuine BMW sensor. Prior to changing the sensor I could not clear or reset the brake wear. Once I replaced the new sensor and followd the reset sequence it reset just fine. it reset to 50K miles
Old 07-27-2011, 11:47 AM
Porando Porando is offline
Mein Auto: 2011 335i, 2004 X5 4.4L
In older models car computer did not monitor brakes - only brake sensors and they had single fuse - ones it was burned (mechanically shaved when sensor contacted rotor) you would get red warning on dashboard
Now sensors have 2 fuses - when first is burned i ti an early warning and 3600 miles countdown starts. When second is broken - dash warning shows. So in order to be able to restore the "normal" condition which allows warning reset - sensor must be installed with 2 good fuses.
Old 07-27-2011, 02:41 PM
PET PET is offline
PET's 2007 530xi
Mein Auto: 2007, 530xi
Glad to see someone is still responding to this old thread, my guess is that "Big Pimp" (what???), anyway, got his problem solved; as no other messages are coming from him. However, Porando here offers a totally new version, one I have not heard before. I too am having a huge problem with this reset, with New BMW Sensors, Pads and (front) Rotors. Are these fuses easily identified? And reading all the other responses, I can say that I have considered them all, nothing so far has cleared the Brake Warning. Any further input be great! pt
Old 07-27-2011, 02:53 PM
by "fuzes" I mean parts of sensor. Sensor is a "plastic" "finger" which is attached to one of the pads (one on front right and one on rear left) has inside embedded two wire loops ( I call them "fuzes") and as pads get thinner this sensor gets closer and closer to the rotor and finally rotor start wearing it off... When reaches first "fuse" and shaves it through - it puts first warning......
it is number 13 on the diagram http://www.realoem.com/bmw/showparts...42&hg=34&fg=05
Old 07-27-2011, 03:11 PM
PET PET is offline
PET's 2007 530xi
Okay got it now Thanks a ton. I'll keep reading and trying things, eventually I'll get this resolved. Regarding your response, I'm guessing this fuse---or---sensor is not my problem unless I'm missing something within your response (??). That's because I replaced all of them...pt
Old 07-27-2011, 06:19 PM
I just got a non- dealer sensor and will change my rear brakes soon..will see how my reset will go
If sensor is same shape as BMW and has same connections, it is fully plugged in ( I would assume that it gas two fuses and they are nothing more than just shorts) , I would be surprised if it was the source of reset problem.
In case of troubles I can take apart used one, check wiring and measure/compare to the new one to make sure it is connected same way... sometimes these non-OEM connectors are source of problems
Old 07-28-2011, 08:08 AM
PET PET is offline
PET's 2007 530xi
Agreed, mine are the OEM Sensor/Fuse
Old 09-26-2011, 06:19 PM
Skim Milk's Avatar
Skim Milk Skim Milk is offline
Mein Auto: 2004 530i
All problems no solutions... please if you have an issue post your solution even if it was go to stealership so at least we know. I would love to know the answer to this question.
2004 E60 with M54B30 - Manual Trans - Winter Package - 19" Style 101 BBS Wheels
Old 09-26-2011, 06:46 PM
Skim Milk's Avatar
Okay I have fixed my problem
http://www.bimmerfest.com/forums/sho...d.php?t=133613
I tried the reset process above countless times and it would only reset to -15000(that's a negative 15K). What made the difference for me was on the last step when the car would display ------ just before it normally would display the -15k I cut the car off while holding the reset button down (didn't work without this part). Strange thing was it left the display on after the key was removed, but upon turning the ignition back on everything was normal again and the sensor was reset back to 31K. Hope this can help someone.
Old 09-26-2011, 07:29 PM
Nube1kenobi's Avatar
Nube1kenobi Nube1kenobi is online now
U of Dawgs
Mein Auto: 08 535iA Spt/11 X5 35i
Nube1Kenobi
2011 X5 35i Sport Activity|Plat Gray/Beige/Dk Poplar|Conv Pkg|Cold WX Pkg|Tech Pkg|Prem Sound|Comfort Seats|Hitch|
2008 535i Mon Blue/Dakota Blk/Dk Poplar|Sports Pkg|Prem Pkg|Cold WX Pkg|Nav|RTTI|PDC|L7|HD|I-Pod/USB|PWR Rr shade|Sports Auto - paddles|Active Stg|Comfort Access|F/D R/seats|Rr DMS Airbags|Adaptive Xenons
Do not argue with an idiot else he lowers you to his level and beat you down with experience..
Old 10-09-2011, 12:09 PM
str8jckt str8jckt is offline
Mein Auto: '07 530i
Thanks Skim Milk! turning off during reset ( ----- ) worked perfectly on my '07 E60
btw I did a front and rear rotor/pad/sensor replacement...all aftermarket/ non-OEM parts. Dealer wanted 1100 for rear only, did all four for under 500
