Old 05-23-2007, 12:43 PM
98bmw528i 98bmw528i is offline
Mein Auto: 98' BMW 528i
Dirty Lights
Hey guys my head lights are so dirty how do i clean them, i used plastx but it's not working?
Old 05-23-2007, 12:47 PM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
Are the lights dirty on the inside of the casing? Like this for example:
Photo Sharing and Video Hosting at Photobucket
and you want this result I assume:
Old 05-23-2007, 01:21 PM
I dont know when the lights are wet from the outside then they are clean and when they are dry they are so damn dirty
Old 05-23-2007, 01:40 PM
dboy11 dboy11 is offline
Mein Auto: 99...540i
The dirty is throwing me off are they hazy looking? that's on the outside...they could have some smokey looking haze also but that sometimes is on the inside..clarify
Its Going To Cost How Much???????
Old 05-23-2007, 01:55 PM
They look hazy kinda dull also
Old 05-23-2007, 01:58 PM
frhsfootball80 frhsfootball80 is offline
looking for a car
Mein Auto: e39 m5 & 92 civic
pics?
Old 05-23-2007, 02:03 PM
http://classic-motoring.stores.yahoo...apllepoki.html
This what yours look like
Old 05-23-2007, 02:22 PM
KTrostel KTrostel is offline
Mein Auto: 1998 540i and 2002 M5
Sounds like hazy plastic. Plastix will work but it will take forever. Start by wet sanding with 1000 grit wet/dry sandpaper. Work your way through 2500 grit. Then a couple of applications of Plastix should clear everything up.
Old 05-23-2007, 04:02 PM
Ya i will try to post some pics, wont the sand paper make marks on the plastic
Old 05-23-2007, 04:10 PM
Solidjake's Avatar
Zero. Leaks.
Not unless you do it correctly. Once I had to remove a big scratch from an aircraft window. Used like 6 different sandpaper grits and a buffer.
Old 05-23-2007, 04:20 PM
JBss's Avatar
JBss JBss is offline
ASC OFF
Mein Auto: 528i
before:
After:
Easy fix that costs $15 in supplies.... i will do it for you if you're local.
EDIT: but you're not so i will tell you how to do it later i guess.
Mad Photo Skillz - Flickr
This is with the NAWZ
