Dirty Lights
Hey guys my head lights are so dirty how do i clean them, i used plastx but it's not working?
Thanks |
Are the lights dirty on the inside of the casing? Like this for example:
![]() and you want this result I assume:
_______________Going to Bimmerfest East AND West ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
I dont know when the lights are wet from the outside then they are clean and when they are dry they are so damn dirty
The dirty is throwing me off are they hazy looking? that's on the outside...they could have some smokey looking haze also but that sometimes is on the inside..clarify
Its Going To Cost How Much??????? |
They look hazy kinda dull also
pics?
http://classic-motoring.stores.yahoo...apllepoki.html
This what yours look like
Sounds like hazy plastic. Plastix will work but it will take forever. Start by wet sanding with 1000 grit wet/dry sandpaper. Work your way through 2500 grit. Then a couple of applications of Plastix should clear everything up.
Ya i will try to post some pics, wont the sand paper make marks on the plastic
Not unless you do it correctly. Once I had to remove a big scratch from an aircraft window. Used like 6 different sandpaper grits and a buffer.
before:
![]() After: ![]() Easy fix that costs $15 in supplies.... i will do it for you if you're local. EDIT: but you're not so i will tell you how to do it later i guess. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
