Old 05-24-2007, 01:21 PM
Fulltone74's Avatar
Fulltone74 Fulltone74 is offline
Mein Auto: 98 BMW 540i-6speed
Go with FSDs or upgrade sway bars
Hi all:
I currently have the Koni sport shocks with Dinan springs and stock 540i sport sway bars.
I was wondering whether I should stick with the shocks and upgrade the sway bars, or keep the sway bars the same and go with Koni FSDs.
I must admit, I have a fairly decent ride quality setup with my Konis, but the tradeoff is that the car seems unsettled on rapid transitions, or sort of "wavy" road surfaces.
I was thinking that as the car temporarily pitches to the left or right, that could be reduced with bigger sway bars. But on the other hand, i think a shock with a bit more low speed damping could accomplish the same thing without adding to much extra harshness on the harder bumps.
I was thinking with FSDs, i might get both the better body control and ride quality, while the sway bars would reduce some of the body roll. But I would like to cut down on the acceleration squat, and sway bars won't really help with that.
The labor seems comparable in doing a sway bar upgrade vs. changing the shocks.
I don't want to do just a rear sway bar upgrade, because my balance is already pretty good. It would have to be both front and rear sways.
But in the really long sweepers, I think the sway bars would be more effective, while better shocks would work better in the transient motions where the car otherwise gets a little unsettled for a second or two before stabilizing.
Or should I really just do both a shock and sway bar upgrade?
Hmm -- decisions, decisions.
1998 BMW 540i 6-speed (SOLD)
Jet black on tan
Dinan springs, Dinan Koni dampers, Dinan front strut tower bar, M5 rear sway bar,
Dinan Stage-1 software, Dinan clutch, Dinan short throw shifter, CDV delete, Bosch Design III injectors,
Dice I-pod kit,
Hawk ceramic brake pads....
2001 BMW M5
Silverstone on Caramel
All stock.
Old 05-24-2007, 03:17 PM
540ig5's Avatar
540ig5 540ig5 is offline
Mein Auto: new york metro area
Save yourself the headache of trying to figure out which one to get and get both upgrades. Weather you go with sways or fsd's first i promise you in due time you'll get the other one. So start saving.
Old 05-24-2007, 10:15 PM
Fulltone74's Avatar
Well, yes. I think that is really the answer. But it won't end there. Because once I do the shocks and sway bars, then I'll find some reason to need bigger wheels too.
Oh why must the mod bug have bitten me so deeply ??
Jet black on tan
Dice I-pod kit,
2001 BMW M5
All stock.
