The X5 SAV Forum
Old 05-26-2007, 07:55 AM
BMW745LI04 BMW745LI04 is offline
Send a message via ICQ to BMW745LI04
Mein Auto: 2004 Black BMW 2004
X5 Air Bag Light Reset
Does anyone know how to reset the airbag light.
I have a 2001 X5 (built sept 2000) and I took off the door panel to fix a widow lift. When I discontected the side air bag and drove for a day the air bag light on the dash when on.
Can anyone help.
Thank you
Old 05-26-2007, 08:15 AM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
Buy a Peake SRS Reset tool.
Sent via Telegraph wires using my Morse Key.
2001 X5 3.0L
Old 08-19-2008, 06:39 PM
panthrax's Avatar
panthrax panthrax is offline
***** Prowler
Mein Auto: there and therabouts
hi, i've done a similar thing with my window and the Airbag symbol came up as well. Is there anyway to remove it without resorting to go to the dealer or buy a special tool?
mine's a 2002 4.6is
Old 08-20-2008, 04:53 PM
Barcius Barcius is offline
Barcius
Mein Auto: 2008 BMW X5 4.8i
No. However, asking the dealer to reset it should be easy and it should not cost you anything. I had an issue with my battery in my 2004 325i and I ask the dealer to reset the airbag light, which they did at no cost and only took it 1 minute.
2008 BMW X5 4.8i/Space Gray Metallic/Gray Nevada Leather/Dark Burl Walnut Wood Trim/Sport Package/Premium Package/Cold Weather Package/Technology Package/Ipod and USB Adapter/Running Boards/Satellite Radio
Retired: 2004 325i Orient Blue/Sand Leather/Wood Trim/SMG/Premium/Sport/Navigation/Xenon/Premium Sound
Old 07-03-2013, 11:02 AM
cchandonnait cchandonnait is offline
Mein Auto: 2001 bmw x5
my dealer wnts to charge me 95$ to reset my air bag i have a memo scan u381 can i reset it with that
Old 07-03-2013, 12:35 PM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
From what i am reading, no. that scanner is a generic OBD2 scanner basically to read check engine lights on all obd2 equipped vehicles. You need either bmw diagnostic software installed on a laptop with the usb to obd2 cable or a peak scanner or some other srs compatible reset tool. Generic scanners will not work for that.
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +5000k LED H11 Foglights, +Blacked Out Chrome Grill Surround, +Puddle Light Logo Projector
.. more updates to come
PREVIOUS 2002 745i
Old 07-03-2013, 04:29 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Ditto...to reset an airbag light...one requires a dedicated SRS reset tool.
The forum member that got their local BMW dealership to reset the light without diagnostic got VERY lucky. The reason being, if the dealership or other shop would reset your SRS warning light without diagnostics to determine if the issue is fixed/resolved...and it WASN'T...and then you get involved in an accident where you or a passenger was injured by an an airbag that didn't deploy as it was supposed to...they'd be liable for a MAJOR lawsuit which they won't win even though you told them to clear the warning.
So, to anyone working around any airbag in your car...MAKE SURE YOU DISCONNECT THE BATTERY FIRST before disconnecting any airbag electrical connector...and DO NOT reconnect the battery UNTIL you've reconnected the electrical connector to the airbag connector. If you don't, you'll end up like those in this thread with an SRS warning light illuminated.
Q {BMW CCA Member #191509}
(SOLD)
Old 08-17-2013, 09:14 AM
e30cabriolet e30cabriolet is offline
Mein Auto: 90 325ic
Can INPA reset the airbag? I got table before I had the car. I installed it on a Win 7/64 laptop only to find the driver is 32 bit and then got caught up in database errors on install on an XP 32 bit laptop.
I'll redouble my efforts to get it installed on the XP laptop if it will solve my airbag.
Old 08-17-2013, 10:34 AM
745iguy's Avatar
Yes, Inpa CAN be used to reset various models airbag lights.
PREVIOUS 2002 745i
Old 08-17-2013, 01:36 PM
Mein Auto: 90 325ic
Thanks. I got it running but after the update have lost e53. (I have a 2003 X5 4.4) I tried e39 since they are mechanically similar and get this error:
I saw that meant a port issue (I told it to use USB emulation during install) but do not see any config options in Inpa.
Old 08-17-2013, 02:27 PM
Mein Auto: 90 325ic
I found a post on e46 fanatics that directed me to a folder with USB settings.
I changed it as directed with no change.
Old 08-17-2013, 03:10 PM
Mein Auto: 90 325ic
I missed that in the body of the post, it said com1 where the file said 5. Changed it to 1, past the com error now get: ifh-0009: no response from controlunit.
Old 08-17-2013, 04:11 PM
Mein Auto: 90 325ic
It's really odd. It reads the modules and sees what the car has:
It read the trans errors & said it cleared them (there were none)
How do I get e53 back on the list?
Old 08-17-2013, 05:35 PM
745iguy's Avatar
You need the right daten files for inpa most installations include e53 so im confused a bit there? (Or at least the ones i had did)
PREVIOUS 2002 745i
Old 08-17-2013, 05:39 PM
Mein Auto: 90 325ic
It was there before the update 502 update.
Old 08-17-2013, 07:58 PM
Mein Auto: 90 325ic
I uninstalled & reinstalled without the update and have e53 back. It accepts commands to run the electric fan end do other things but says no response when I try to reset the airbag.
Old 08-18-2013, 01:59 PM
Mein Auto: 90 325ic
I tried some more. The video below is what I referred to as seeing the bags. After watching it again it seems it is not seeing anything but the transmission because at :59 it shows data after the transmission control.
What should I check to get it to see everything else assuming my theory is valid.
http://s20.photobucket.com/user/e30c...2ddcd.mp4.html
Old 08-18-2013, 06:30 PM
745iguy's Avatar
Probably something wrong with your installation or the machine it is on or the cable even. Have you ever used it before successfully or is this your first try? Whats the os you're using it on? (Nvm i see xp i think? Starting to think either the cable or the install setup you used if its xp; tis supposed to run perfect on xp, and inpa on win7 32 bit)
PREVIOUS 2002 745i
Old 08-18-2013, 06:36 PM
Mein Auto: 90 325ic
It is a fresh install of XP pro done because I could not get it to install on 7 64. It has not worked outside making the fan run faster and some valve to purge and getting info from the transmission & engine.
I fixed the link in my last post
