Old 06-04-2007, 05:56 PM
540fan 540fan is offline
Mein Auto: 2001 540iT & 2004 745Li
Missing Voice Commands (phone & Nav)
I had an interesting problem today. In the morning, I could use the voice command system and was able to use: "dial name" then give the name, listen to the name repeated, then say dial. Everything worked fine with my cell phone. Later today, I get command unavailable but all other phone and address book functions along iwth the pop out dial pad are working fine.
Next one, when I say "navigation", it doesn't recognize the command although the book say it should.
Any ideas? Is this part of the Idrive woes?
04 745Li using BTUM and BB 8703
Thanks,
Newbie with the 7 series.
Old 06-13-2007, 07:27 PM
asci01's Avatar
asci01 asci01 is offline
Mein Auto: 10 750i
Thanks,
Background noise perhaps?
Otherwise you may have a problem
Old 06-17-2007, 06:27 PM
I'm going to have it looked. At first I thought it was the key programing because I thought I was using the other key. Not the case, I loose the Nav and Tele voice commands every once and awhile. The address book plays back but every time I say Navigation or Dial Name, I get "function temporarily not available." These commands do show up on the display in the tach.
iDrive, what a great thing...
Old 07-02-2007, 07:59 PM
clawsonbob clawsonbob is offline
Mein Auto: F02 750LI, 997C2, ShlbyGT
voice command reset
check the FAQ section..there is a fuse in the glove box door you remove to re-set the voice command system...happened to mine, removed fuse for a minute or so or what ever the FAQ said and voila...all fixed....good luck
here it is
Voice Command (SVS) doesn't work?
You can remove fuse 5 in located in the glove box for 2 minutes. This will reset SVS and telephone control modules and restores Voice Activation.
regards
bob
