Old 06-06-2007, 10:13 PM
Ron Stygar's Avatar
19,585 Miles
Gauge sender wiring Z4 M Coupe
I wired my Coupe for four gauges.
Oil pressure, water temperature, oil temperature and voltmeter.
If the oil temperature gauge follows the stock instrument cluster gauge, I will replace it with the voltmeter.
I use black wiring so that it doesn't stick out.
I used #12 THNN wiring. THNN is a smaller diameter.
Fourth wire is for the ooga horn.
Initially tried going from the engine compartment on the drivers side. Not easy to do so decided to go in on the passenger side.
Basically headed towards the front, across under the front cover to the passenger side and back towards the firewall.
Many, many hours to make it look right.
Will add the water and oil temp sender wiring info soon.
ID:	111045   Click image for larger version
ID:	111046   Click image for larger version
ID:	111047   Click image for larger version
ID:	111048   Click image for larger version
ID:	111051   Click image for larger version
ID:	111052   Click image for larger version
ID:	111053   Click image for larger version
ID:	111054   Click image for larger version
ID:	111056   Click image for larger version
Old 06-06-2007, 10:17 PM
Ron Stygar's Avatar
19,585 Miles
Old 06-08-2007, 07:05 AM
AndyM's Avatar
AndyM AndyM is offline
Suede Master
Mein Auto: '02 3.0i Z3 Coupe
Great pics Ron! Does the glovebox need to be removed to access the 'plug' from the cabin side?
Old 06-08-2007, 08:26 AM
Ron Stygar's Avatar
19,585 Miles
No. It's right above the carpet line. Will post a pic after breakfast.
Old 06-08-2007, 08:54 AM
Palantirion's Avatar
Palantirion Palantirion is offline
Z4 Mvangelist
Mein Auto: 2003 M5-S2, 2002 540iT-S2
I don't know if it's relevant to you Ron, but BMS has a new billet aluminum oil filter cap that has bosses tapped for oil temp and/or pressure senders. I don't have one yet since I feel like I need one yet, but it's rather beautiful. I might get one just for dress-up and future use. Wish I had a pick
Old 06-08-2007, 10:52 AM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
Billet oil filter caps look great (I have one of Ron's chrome oil filter caps) -- until you hang senders off of them. Then they look sort of robocop/hacked in. Plus is makes oil changes messier.
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 06-08-2007, 11:04 AM
Ron Stygar's Avatar
19,585 Miles
Let me know if you need more info.
Old 06-11-2007, 09:13 PM
Ron Stygar's Avatar
19,585 Miles
VDO oil pressure hose clearance with air collector
Old 06-12-2007, 07:42 AM
JonM's Avatar
Moderator
LZ Block clearance with air collector
It is tight with our block also. I am advising customers to install the block temporarily so it is snug, then re-install the air collector to check clearance, then apply final torque.
Jon Maddux
Old 06-12-2007, 03:53 PM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
On mine I just go straight out with an adaptor from Earl's since my temperature sender is in the sump cover of the oil pan (no need for a distribution block). My kevlar hose is longer, but I think AutoMeter sells a shorter one.
Ron's setup looks fine. If it doesn't leak and doesn't make oil changes more work/messy, it gets my stamp of approval.
Daniel
2002 M roadster
Old 07-03-2012, 05:37 PM
inTgr8r's Avatar
inTgr8r inTgr8r is offline
Originally Posted by Ron Stygar View Post
resurrecting an old thread here....
Ron, do you recall the size of the port where you added the VDO block?
I'm looking to add an oil pressure sender similar to the way you did this.
I'm really not a fan of those filter cover adapters.
Thanks...
Old 07-03-2012, 06:37 PM
Ron Stygar's Avatar
19,585 Miles
Thanks...
Andy uses Loctite 565 thread sealant (Net 1.69 FL.OZ.(50ml). My sealant leaks.
M10 x 1 taper on hose. I think it's into the M10 x 1 straight on the block.
Old 07-04-2012, 03:07 AM
inTgr8r's Avatar
Thats Great... Thanks
