Old 06-07-2007, 01:45 PM
Ron Stygar's Avatar
19,585 Miles
Z4 Remove door trim panel
Doing the door mods.
Will post some pics to go with the following as I do the mods.
BMW handle pull light.
Interior door opener light.
Exterior door handle light.
Exterior door handle engraving. (M Coupe)
Puddle light.
Door open reflector.
Damplifier Pro insulation. Thanks Daniel.
36 sq ft was $172.36 delivered.
http://www.secondskinaudio.com
ID:	154666   Click image for larger version
ID:	154667   Click image for larger version
ID:	154668   Click image for larger version
ID:	154669   Click image for larger version
ID:	154671   Click image for larger version
ID:	154672   Click image for larger version
ID:	154673   Click image for larger version
ID:	154674   Click image for larger version
ID:	154676   Click image for larger version
Old 06-07-2007, 02:22 PM
Fast6 Fast6 is offline
matching revs in
Originally Posted by BMW
Do not detach trim (1) with tool at edge (A).
Shape butyl into a ball and stick centrally on trim (1).
Pull out butyl ball together with trim in direction of arrow.
Cute.How much does BMW butyl cost?
'06 M Coupe - Silver Gray/Sepang Brown Dark/Aluminum
E36 M3 - gone
E24 645 - gone
Old 06-07-2007, 03:38 PM
Ron Stygar's Avatar
19,585 Miles
It works.
Like the Z3 the Z4 has a foam piece over the door held in place by butyl tape.
Never was able to get the BMW stuff with the string inside. Been buying it from Volvo.
Used to be less than $7.00. Now around $20.00 a roll.
Old 06-08-2007, 10:17 PM
Ron Stygar's Avatar
19,585 Miles
Puddle light
Added the puddle light.
Similar to the E92.
Be careful of that extended leather.
Old 06-08-2007, 10:26 PM
AlanLX3 AlanLX3 is offline
Leftover Hippie
Mein Auto: 2010 328xiT
Nice job on the light.
How much sound deadening material is on the inside of the door panel itself? I have a bunch of dynamat laying around from work I did on my last car that could be put to good use if the door panel is bare. BMW does a pretty good sound deadening job with their foam baffles, but hitting up the metal panels can't hurt.
AKA AlanL on all other forums
2005 X3 2.5i - Mystic Blue
2010 328ix Sports Wagon - Space Gray
Old 06-08-2007, 10:28 PM
Ron Stygar's Avatar
19,585 Miles
Zero.
The Z3 had some.
Old 06-08-2007, 10:54 PM
Leftover Hippie
Thnx - I now have a new project
Old 06-08-2007, 11:04 PM
Ron Stygar's Avatar
19,585 Miles
Interior door lights
Old 06-09-2007, 11:50 PM
Ron Stygar's Avatar
19,585 Miles
Ai bag, foam piece and butyl tape removal
The window and mirror switches are now hot glued in place.
Need the switches if you want to use the car.
Was going to order a spare switch but was able to peel off the glue.
Air bag:
Foam piece and butyl tape:
Scraper is to remove wheel weights without scratching the wheel.
Works fine removing most of the butyl tape.
Finish removing with 91% Isopropyl alcohol.
I have two and just ordered two more. First two were $5.00r.
Now more than double that.
ID:	154680   Click image for larger version
ID:	154681   Click image for larger version
ID:	154682   Click image for larger version
ID:	154683   Click image for larger version
ID:	154685   Click image for larger version
ID:	154686   Click image for larger version
ID:	154687   Click image for larger version
ID:	154688   Click image for larger version
ID:	154690   Click image for larger version
Old 06-09-2007, 11:52 PM
Ron Stygar's Avatar
19,585 Miles
Continued
ID:	150164   Click image for larger version
Old 06-12-2007, 05:39 PM
Ron Stygar's Avatar
19,585 Miles
Unlike the Z3, the Z4 exterior handles can be removed without removing the interior trim panel.
ID:	154692   Click image for larger version
ID:	154693   Click image for larger version
ID:	154694   Click image for larger version
ID:	154695   Click image for larger version
ID:	154697   Click image for larger version
ID:	154698   Click image for larger version
ID:	154699   Click image for larger version
Old 06-13-2007, 09:50 PM
Ron Stygar's Avatar
19,585 Miles
Door cabin connector
To do the puddle and exterior door handle light, I need to run one wire from the door to the cabin.
There are four unused locations.
On the door side the wiring (three wires) is in place for the fold-in mirrors.
On the cabin side no wires in those positions.
ID:	154701   Click image for larger version
Old 06-14-2007, 02:15 PM
Ron Stygar's Avatar
19,585 Miles
Added wires
ID:	150166   Click image for larger version
ID:	150167   Click image for larger version
Old 06-18-2007, 07:12 AM
matching revs in
Ron, how hard would it be to implement this functionality?
E36 M3 - gone
E24 645 - gone
Old 06-18-2007, 11:26 PM
Ron Stygar's Avatar
19,585 Miles
Have to install the wiring.
Have to purchase the mirrors, switch and a module too.
mirrors 51 16 7 114 045/6 $426r each
switch 61 31 6 955 040 $125.25r
module 61 35 6 915 061 $61.60r
$1038.85r
Cheaper than I've heard. Quick look.
Will check in detail when I get a chance.
Probably after HC.
No support from NA.
Old 06-21-2007, 10:50 PM
Palantirion's Avatar
Palantirion Palantirion is offline
Z4 Mvangelist
Mein Auto: 2003 M5-S2, 2002 540iT-S2
$1038.85r
Probably after HC.
No support from NA.
-Awesome writup Ron, as usual!
Maybe I missed it, did you add the Eruo power-folding mirrors? I'd love to see pics and stuff, as that (and having the mirror tilt down when in reverse) are features from my M5 that I sorely miss!
Old 06-22-2007, 10:26 AM
louv louv is offline
BMW Addict
Mein Auto: '00 M5, '15 i8
But why would you want the reversing-fold-down mirrors? This car has such amazingly great visibility out the back windows. oh... wait... sorry... what was I thinking!?!
bmw addict.
Old 06-22-2007, 03:49 PM
Z4 Mvangelist
Come to think of it, DO the euro mirrors right side fold down when in reverse?
Old 06-22-2007, 03:54 PM
Ron Stygar's Avatar
19,585 Miles
My guess is no. Doesn't need fold-in for that.
Will have to ask somone in Canada that has it.
Old 06-22-2007, 04:01 PM
Z4 Mvangelist
-The more I think about it, tilt is even more important to me than the fold in - since the mirrors don't stick out much compared to our E39s.
Old 07-07-2007, 06:16 PM
Ron Stygar's Avatar
19,585 Miles
Added the insulation to the drivers door.
Made templates which I will use again when I do the passenger door.
Added the lower part of the door. 8 -oz which took care of the tinny sound.
Added the upper part of the door. 12.6 -oz.
1.29 pounds total.
Also gets rid of the road noise.
Thanks Daniel.
Old 07-07-2007, 09:01 PM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
Nice work!
36 sq. ft. of Damplifier Pro... what are you going to do with the leftovers? If you're looking to get rid of it, let me know and I'll buy it from you. I need more for the MINI.
Daniel
2002 M roadster
Old 07-07-2007, 09:12 PM
Ron Stygar's Avatar
19,585 Miles
Originally Posted by dwm View Post
Nice work!
36 sq ft was a package price.
Used 4 sq ft for the drivers door plus. Since I now have templates from the drivers side should be better laying it out for the passener side.
So it should be 8 sq ft for both doors.
Will be doing some in the truck area. The vertical wall and some side and floor stuff.
Old 07-09-2007, 08:43 AM
dwaynemosley's Avatar
dwaynemosley dwaynemosley is offline
Mein Auto: Lots of different stuff
If you want to sell some of the leftovers, I'll buy pieces cut to fit into my doors. All of my Z3 coupes have had a lot less road noise than this Z4 M Coupe. I'm also interested in what you learn after doing the back area. I've always felt that a lot of my noise emanated from the rear.
Let me know if you're interested in selling some pieces.
'10 M3 coupe, Space Gray / Black, DCT
'12 X5d Alpine White
'17 911 Carerra S White
'14 X1 M sport 3.5 Alpine White
'91 M5 Jet Black
'01 M3 Alpine White
Old 07-16-2007, 09:41 AM
inTgr8r's Avatar
inTgr8r inTgr8r is offline
Correct...
No reverse tilt.
