Old 02-12-2003, 08:51 PM
TeamM3's Avatar
TeamM3 TeamM3 is offline
Living on the redline
Mein Auto: a BMW killer
NASCAR-style conversion studs
New from TC Kline Racing for the serious competitor:
http://www.bimmerforums.com/forum/sh...threadid=75159
Old 02-15-2003, 09:52 PM
DannO's Avatar
DannO DannO is offline
Mein Auto: //M Coupes
Those are a bit pricey - about $200 for a set (5 lug) vs. $150ish for the "crap studs" that most vendors offer (including TC Kline) WITH nuts. Seems like a reasonable extra expense.
Now those Daiyama lug nuts are trick! But is that $80 for 4 or for a set of 4 x 4 = 16? At first the wording ("complete 4 lug set") had me thinking they wanted $20 per nut. Surely I was mistaken.
For $300 total it seems like good insurance.
Old 02-16-2003, 12:54 PM
TeamM3's Avatar
It's certainly not for everyone and is a bit pricey, but for people who must change wheels often or quickly it is a necessary convenience. I've seen hubs have to be replaced from having the bolts screwed in and out of them so often. They were not originally designed for this type of service and the threads in the hub mounting holes will weaken over time. Even the best lugbolts are not made out of material as strong as these studs. Lugbolts have been known to break and IMO are generally an all-around PITA.
Old 02-16-2003, 01:21 PM
DannO's Avatar
I agree. I'll give them a shot on my track car.
Old 02-17-2003, 09:41 AM
DannO's Avatar
Mark - who do you deal with at TC Kline?
Old 02-17-2003, 07:06 PM
TeamM3's Avatar
I dealt mostly with Pete Stackhouse on the studs. The set I have was the last of the prototypes, not sure when the production parts hit the shelf.
Old 02-17-2003, 08:43 PM
Jetfire's Avatar
Jetfire Jetfire is offline
Car Junkie
Mein Auto: '88 M3, Ex-'99 M3
I didn't realize that lug bolts were less durable than studs and nuts like the rest of the automotive world. Why does BMW use bolts, anyway?
'88 M3
Conforti chip, Evo airbox/K&N filter, UUC short shift kit, oil pan baffle, Hella H4 lights, OEM glass sunroof
sold: '99 M3 Coupe
Cosmos Black
Airbox baffle removed, ZKW ellipsoid headlights, UUC short shift kit, BMW x-brace, debadged
'96 Jeep Grand Cherokee Laredo V8
(Support Vehicle)
Old 02-18-2003, 01:12 AM
TeamM3's Avatar
They're not necessarily less durable for their intended street use; street cars don't typically swap wheels on and off several times a month like a serious autox or track application would
Old 02-18-2003, 06:41 AM
Jetfire's Avatar
Car Junkie
So are normal lug/nut assemblies (like you'd find stock on, say, a C5) more durable for frequent wheel swaps?
Either way, it's infinitely simpler to just use lugs and nuts to mount a wheel than it is to deal with wheel bolts. I wish I knew why BMW has used bolts for so long.
'88 M3
sold: '99 M3 Coupe
Cosmos Black
(Support Vehicle)
Old 02-19-2003, 08:13 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
With alloy wheels it is more likely to chew up the lug holes when putting the wheels on or taking them off with studs. The threads can chew up the holes. With bolts this doesn't happen.
Of course that does explain why bolts are used with steel wheels, like my old Fiat 850 Spider.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 02-19-2003, 08:47 AM
scottn2retro's Avatar
scottn2retro scottn2retro is offline
into things retro
Mein Auto: '02 M3 SMG & '08 135i
I'm looking at buying a car that has been upgraded to Group N hubs with studs. I'll have to get more details on the type of studs/nuts he's using. He said the nuts are 19mm.
facebook.com/sctsracing
02 M3 SMG Coupe - prepared class BMW Club racer
08 135i 6sp - stock class BMW Club racer
Photo gallery
Old 02-19-2003, 12:02 PM
TeamM3's Avatar
I've never heard of this happening and even if it did the actual holes are not a tight fit on the bolts or the studs. It's the cone seat machined into the wheel along with the hubcenter that does all the locating.
I'd rethink that position.
Old 02-19-2003, 01:45 PM
Pinecone's Avatar
M Mad
The problem comes from sliding the wheels on and off. People tend to drop them onto the studs, then "slide" them off. That's where the wheel thread contact comes from.
You are absolutely right, when installed there is no contact between the wheels and threads, just like with bolts.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 02-19-2003, 07:11 PM
TeamM3's Avatar
In otherwords, it's a problem yet no problem exists?
OK, I give up.
Old 02-19-2003, 07:21 PM
Jetfire's Avatar
Car Junkie
OK, I give up.
Dude, he said it could cause problems while mounting/unmounting wheels and not while it's actually mounted. You could really stand to be less combative/defensive around here.
'88 M3
sold: '99 M3 Coupe
Cosmos Black
(Support Vehicle)
Old 02-19-2003, 10:35 PM
TeamM3's Avatar
ok, the experts have spoken.
Old 02-20-2003, 06:12 AM
Pinecone's Avatar
M Mad
Yeah, like that.
READ my post, like Jetfire says, there can be a problem when most idiots pull the wheel off or put it on. If you watch the normal person do this, they loosen the wheel, then drop it on the studs then slide it off. For mounting they hoist it onto the studs, then slide it back then jiggle it around to get it in place, then put the nuts on.
The sliding the wheel across the threads cn damage the wheel.
You can avoid that if you are careful. Or you can just replace the wheels every so often like some race teams do.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 02-20-2003, 08:09 AM
into things retro
Yeah, like that.
I'll try to keep this in mind and be careful. The car I'm looking at with the Group N hubs has studs that are pressed in from the back (not screw in), but I may want to check on getting the nice lug nuts.
Photo gallery
