Old 06-13-2007, 09:39 PM
tgriffin tgriffin is offline
Mein Auto: 745i
How in the hell do you replace a 540i water pump?
My water pump fell apart on my 2003 540i. I've taken the thermostat off, along with all the hoses, fan shroud, and such. The water pump is finally off... my wife had to get the bottom screw off because I couldn't get my fingers back there. My question is how do I get the water pump past that steel bar in front? Does the steel bar come out? The water pump is trapped behind it. Any tips would be greatly appreciated!!!
Old 06-13-2007, 10:17 PM
applecran applecran is offline
Mein Auto: '99 540i6
you might have to take the crank shaft pulley off... that is the big one on the bottom, there are a bunch of bolts in there, take them all off and it will come off... hold on to it, it has a bit of weight - not heavy, but will fall down)... once that is off you should be able tot get it past that silver bar that is in the way...
That helped me anyway.
Good luck.
'99 540i 6 speed. Black on Black. M5 spoiler. 18" M-Pars, BF Goodrich KDW2s. UUC Big Boy v3 clutch stop. DICE Ipod integration half installed. Metrix Motorsport 3.15 M5 LSD. 03 AE Hellas. M5 rear sway bar. M5 shifter. Custom lit Shift knowb. Umnitza M5 bumper. UGDO retrofit.
If you ever need to get rid of a lot of money quickly, buy a bmw and start modding.
Old 06-13-2007, 11:39 PM
chivas's Avatar
chivas chivas is offline
You Lick It, You Own It
Send a message via ICQ to chivas Send a message via AIM to chivas
Mein Auto: 98 540i/6
if you lived closer, i would give you a hand. i can replace a pump in 90 minutes, start to finish and that included burping the system.
americandan.com
It takes a lot of work to be lazy.
Old 06-14-2007, 06:43 AM
Mein Auto: 745i
Thanks for the tip about removing the crankshaft pulley. It's the one thing I have taken off yet. Taking that off should allow access to put this thing back together again.
I'm proud of the other guy who can complete the job in 90 minutes. His comments don't really offer any help though, do they?
Old 06-14-2007, 07:46 AM
KTrostel KTrostel is offline
Mein Auto: 1998 540i and 2002 M5
I would take Chivas' comments to indicate the difficulty level of the project - 90 min ie not that difficult.
When I swapped out my w pump Bimmerd00d (I think) suggested that I use a 10mm ratching head box end wrench to extract the bolt hidden behind the crankshaft pulley. This way it is not necessary to remove the pulley. You will not be able to apply the exact torque to this bolt but a light coat of form a gasket and a good guess on the torque has worked quite well for my 540i.
Old 06-14-2007, 07:50 AM
cn90 cn90 is offline
Some Info for DIY
Last year I wrote the Cooling Overhaul Tips for Inline 6 (1998 528i):
http://www.bimmerboard.com/forums/posts/199986
For V8:
http://bimmerboard.com/forums/posts/361164
As from the picture, there is a trick to remove the WP WITHOUT removing the Crank pulley.
HTH.....
Old 06-14-2007, 08:33 AM
bimmerd00d's Avatar
bimmerd00d bimmerd00d is offline
just havin a heart attack
Send a message via AIM to bimmerd00d Send a message via MSN to bimmerd00d Send a message via Yahoo to bimmerd00d
Mein Auto: 1998 540i 6-speed
Yep, 10mm ratchet box-end wrench makes that one bolt a LOT easier. I would recommend removing the crank pulley now, as my bolts on the pulley backed thmselves out. R&R the crank pulley would allow them to be re-tightened. Definitely remove it, it's 6 10mm bolts.
2011 535i xDrive M-Sport - 114k miles
2003 Land Rover Discovery 2 - needs a core support or a new owner (cheap)
2005 Dodge Ram 2500 - Cummins with a Bully Dog and some goodies
Old 06-14-2007, 09:31 AM
Did you use any loctite on the crank pulley bolts? Blue, Red...
Old 06-14-2007, 02:47 PM
gb1k gb1k is offline
Mein Auto: 02 530i Sport
10mm bolt deep inside the the front of the head, look where the pipes go inside the head, you will see the securing bolt.
BMW Certified Diagnostic Technician
Working with BMW since 1998
02 530i Sport- K40 radar, Parrot bluetooth
02 Suzuki GSX-R 1000 220 rwhp
05 Suzuki Hayabusa Turbo 295 rwhp
Old 06-14-2007, 07:21 PM
Mein Auto: 745i
I could pull the water pump after removing the pulley. Thanks for all the suggestions!
Old 08-13-2011, 09:42 AM
mad12.1964 mad12.1964 is offline
Mein Auto: 540i
What is the trick to remvoe the WP WITHOUT removing the Crank pulley?
Old 08-13-2011, 10:19 PM
540indiana's Avatar
540indiana 540indiana is offline
Mein Auto: 2000 540i Sport
There is no trick. You dont need to remove the crank pulley to remove the water pump.
Old 08-14-2011, 03:30 AM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
Don't bother taking off the pulley.
Remove the 10mm hex head bolt at each end of the tube, a 2 minute job.
There is a small flange welded to each end of the tube, the bolt holds the flange to the head. Get a mirror and look at it.
The secondary air tube will pull straight out.
Old 08-14-2011, 12:15 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
So that others can find this easier in the future, I added this to the bestlinks:
- How to remove the BMW E39 540i V8 waterpump without removing the crankshaft pulley (1) (2)
As always, if you know of better links, let me know.
Old 08-14-2011, 05:39 PM
chivas's Avatar
OMG!! Hi Jim!!! Glad to see you here. How are things?
americandan.com
Old 08-15-2011, 06:35 AM
Mein Auto: 540i
Thank you for your reply.... One more question.... from the procedure Cerber posted (#1), he cautioned about the two aluminum tubes sandwiched between the WP and back of the engine. I am concern when I pull the water pump out, I will remove the two tubes. Is there a correct way to remove the WP without disturbing the two tubes?
Old 08-15-2011, 06:52 AM
Mein Auto: 540i
Link #1 showes the procuedure by CNN-090 for 528i and the second links show a picture of V8 (but no insturctions)..... Did I miss a link or instruction for the 540i in these two posting?
Old 05-26-2012, 12:16 PM
Columbian Columbian is offline
Air Tube Photo
Thanks for the tip.
ID:	326619   Click image for larger version
Old 01-01-2013, 07:08 PM
bin01123's Avatar
bin01123 bin01123 is online now
Mein Auto: 2013 535i
working on this in a few days and I'm thinking about removing the pulley. That piping has gaskets and if I went that route I would like to replace those while I was there.
Old 01-01-2013, 07:47 PM
nsogiba nsogiba is offline
Mein Auto: 2001 540i/6
i removed the secondary air injection pipe as described above when i did my water pump, and did not replace the o-rings on the pipe. did not leak and no problems.
6.0L LSx/T56 Swap
2001 BMW 540i/6 Sport, under the knife
Old 01-01-2013, 08:03 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
this link is for a more indepth project but it covers alot of the same dissassembly as the water pump is removed so the pics and bolt location hints should help alot.
http://www.beisansystems.com/procedu..._procedure.htm
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 01-01-2013, 08:27 PM
bin01123's Avatar
Thanks for the input. I'll work on this tomorrow when I get back from work
Sent from my HTC VLE_U using Bimmer App
Old 01-02-2013, 08:12 PM
bin01123's Avatar
Thanks guys. Removing the injection pipe was the way to go. It came off pretty easy.
