E30 (1982 - 1993)
Old 06-14-2007, 12:59 PM
alejo honduras alejo honduras is offline
BMW CATRACHO!!!!
Mein Auto: BMw 325e 1985
fuel gauge
Hello people. I have a problem with my fuel gauge. It reads like a half and a little bit more, even when on empty. It never moves, only when I turn off the car. Is there anything to do with it? thanx a lot
horsepower sell cars, torque wins races. Racer, definately not a ricer
Old 06-14-2007, 01:23 PM
Just Bryce's Avatar
Just Bryce Just Bryce is offline
Mein Auto: Slammin Taco
Welcome to the club, my #1 E30 has the notorious erratic fuel guage, seems the newly purchased #2 is fully operational but only time will tell. It's a very common problem and an easy fix with a new sending unit installed under the back seat
Old 06-14-2007, 05:39 PM
lordofthewaters's Avatar
lordofthewaters lordofthewaters is offline
Rather Large Member
Mein Auto: 88 325is 04&09 jetta TDi
Yeah. What he said.
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's 3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson
Old age and treachery, will always overcome youth and skill.
Old 06-14-2007, 08:21 PM
kishg's Avatar
kishg kishg is offline
E30 Maniac
Mein Auto: too many bmws
i tried replacing the sender only to find it was the guage itself. it sort of works now, shows F when i fill up but seems to quickly drop after the half-way mark.
'91 SpecE30 #523
'03 540i/6 M-Sport
'00 Ford F-350 Dually Tow Vehicle
BMWCCA #360858 NASA #
128290
My Track Schedule
Old 06-15-2007, 03:39 PM
danielw05 danielw05 is offline
Send a message via AIM to danielw05 Send a message via MSN to danielw05 Send a message via Yahoo to danielw05
Mein Auto: 1990 325i
sounds exactly like mine...where is the sender and how much does it cost to replace?
Old 06-15-2007, 07:13 PM
kishg's Avatar
E30 Maniac
it's under the rear seat. lift it up to access. cost around $80 new.
'91 SpecE30 #523
'03 540i/6 M-Sport
128290
My Track Schedule
Old 10-11-2007, 03:06 PM
so I have tried twice now in the past couple of months to lift up the back seat..as you can tell I am in a huge hurry to fix this.....is there some kind of trick? do I just need to work out my arms for the next month and then try again?
maybe the previous owner used gorilla glue on it!!!
Old 10-13-2007, 08:13 AM
Just Bryce's Avatar
Use a bit of pressure from your knee while pulling up on the seat at the same time, should pop right up. On the passenger side you will see a black access cover. Take that off and you will see the lines coming off the pump assembly. There are four small nuts visable, 6mm I think, remove those and lift the sending unit straight up.
Old 10-13-2007, 09:47 AM
Soviet1942's Avatar
Soviet1942 Soviet1942 is offline
Zinnobitch
Send a message via AIM to Soviet1942 Send a message via MSN to Soviet1942
Mein Auto: 1987 325is
O_O Theres another fuel gauges under the seat? I don't understand the new sending unit installed under the seat ideal.
Mine works fine but gets a little crazy after it passes the half way mark.
Old 10-13-2007, 01:22 PM
omw41's Avatar
omw41 omw41 is offline
Mein Auto: 1986 BMW 325 E
Also...it could be that the screws on the gauge itself are loose...look at the dash...look at the gauge...and you'll see the screws I mean...another common problem...
Old 10-14-2007, 11:37 PM
Paul Christian Paul Christian is offline
Mein Auto: 87.325is
does your dash go crazy or just the gas gauge??if so it the SI batts.....to get sanding unit out was 2 mid sizes screw drives pust down and turn........
Old 10-15-2007, 08:33 AM
just the guage on mine...
