Old 02-17-2003, 01:13 AM
Ron Stygar's Avatar
19,585 Miles
S54 Engine with plugged ingots
Old 02-17-2003, 05:33 AM
Randy Forbes's Avatar
Investigative Tinkerer
So, how much lower is the idle air feed pipe now?
Did you see what I mean about the idle valve fitting into a pocket on the backside of the airbox? Prevents lowering it unless you mod the airbox...
Randy Forbes
1999///M Rdstr Cosmos Black
2001///M Rdstr Steel Gray
Old 02-17-2003, 09:15 PM
Ron Stygar's Avatar
19,585 Miles
Each hose is 1/16 inch shorter than what was there.
Yes.
Old 02-18-2003, 12:04 AM
TeamM3's Avatar
TeamM3 TeamM3 is offline
Living on the redline
Mein Auto: a BMW killer
care to explain to the rest of us numbnuts what you guyz are talking about?
Old 02-18-2003, 05:52 AM
The blue tube shown in Ron's opening picture turns out to be the highest point of the engine (as far as a strut brace is concerned).
That was why azzman had to come up with another pattern of bar.
Ron too has been working on one.
While I had the airbox off my car I tried a couple of tricks to lower that tube. Extensive work required no matter which approach you take.
To really answer your question:
The blue tube introduces the idle air to the throttle bodies (downstream of the butterflys).
That "device" under the blue tube is a valve that allows the air to flow through.
Underneath the valve is a rubber tube that gets its supply of air from the airbox plenum, downstream of the air flowmeter.
Naturally, the injectors supply the fuel for atomization.
Too bad we need to keep the air flowmeter in the circuit, some nice velocity tubes with "socks" on them would really look nice...
Randy Forbes
