Old 03-16-2015, 01:21 AM
harleyrob harleyrob is offline
Mein Auto: 2004 330 CI
ATF D/F follow up
Completed AT filter/fluid change month ago and want to do a follow up D/F for good measure. Can I simply drain fluid and add back in the equivalent without bringing fluid up to temp, etc, etc?
Old 03-16-2015, 04:10 AM
davidmaria1 davidmaria1 is offline
Mein Auto: 2011 X5 3.0 Gasser
Sounds reasonable. I've done my fluid a couple times, both times I ran it up to temp. I can't think of a reason not to do it cold if you're only draining cold fluid and refilling with cold fluid.
It beats laying under a running car.
THINGS I'VE DONE: Cooling system refresh with radiator, key fob surgery, pulleys and tensioners, CCV cold weather, DISA gasket, OFHG, Fuel pump/filter PM, ZF auto trans fluid/filter, motor mounts, fcabs, trans fluid change, steering guibo, rear wheel bearings and hubs,
2001 330 has left the building
X5 fun includes: Battery. Trans fluid change. Nav update. Idler pulley replacement. Steering fluid flush. Tension struts. Pressure lip seal. TCS fluid flush.
Old 03-16-2015, 11:43 AM
cvx5832 cvx5832 is offline
Mein Auto: 325Ci, 325Cic, C300
In theory, yes. Unfortunately you can't get it to the proper fill level without starting the car.
Old 03-16-2015, 11:44 AM
It's not the fluid temp that's the big deal, it's that a running car takes up the fluid to fill the torque converter.
Old 03-16-2015, 12:05 PM
But I've already changed the filter and fluid once. If current fluid level is the correct level, then cant i just drain what is in the bottom of the pan (car off cold fluid) and replace with the same amount. I realize some fluid will remain in the TC but surely this will help insure cleaner fluid overall is in the AT. Like, if 75% of the fluid is clean currently this will increase that to say....85%.
Old 03-16-2015, 06:46 PM
No, as in the fluid from the torque converter drains back into the pan when you turn the engine off. The fluid level will be higher than the fill hole when the engine isn't running. This makes it impossible to fill correctly when the car is off.
You can do a D&F cold if you want, but the engine still has to be running if you want to fill it with the correct amount.
Old 03-16-2015, 11:43 PM
Gotcha! Thx!
Old 03-17-2015, 03:50 AM
Forgot about the t/c. I did mine at running temp. both times. Unscientific at best, but it seems to work.
