Old 06-26-2007, 06:00 AM
justtune's Avatar
justtune justtune is offline
Mein Auto: 1997 528IA
I'm trying to identify this part...
It's not the window fountain.... yesterday as I was spraying the carb cleaner around that area to find a leak... my low idle inclease 300 to 600 RPM and air thumping sound went a way
If there's leak there is this something I can repair my self or is this thing needs to be replace... it seems this thing is on top of the ICV...
Finally 150K! => 166666 => 190900 =>??? 97 528i
Old 06-26-2007, 07:09 AM
cn90 cn90 is offline
justtune,
I thought you already posted the ICV DIY and should have an idea about that part.
Here was the thread you posted recently:
http://www.bimmerfest.com/forums/sho....php?p=2373227
Old 06-26-2007, 08:26 AM
justtune's Avatar
You guys gotta go easy on me... I know I can write up a decent DIY, but trying to identify parts from no experience its very difficult. For one thing my "learning BMW parts" english is getting better. (This is not bad for a guy who's been in US for 12 yrs)
Anyway... I'm still learning... So far the BMW vocab I learn so far... brake, MAF, ICV, O2, spark plugs, air filter, oil filter, exaust maf... and my e39 not bad for guy with medical background
Back to the question
this one is under the intake maf. and back of the ICV. ( getting to ICV is very easy... but this one is going to be a challenge ) I have no idea what the name is....
Old 08-08-2007, 09:27 AM
jaguar_wsc jaguar_wsc is offline
WSC-MOB
Send a message via AIM to jaguar_wsc
THAT IS NOT THE ICV! Its the CCV. crank case ventilation. stick ur finger underneath the vent on it while the engine is running. if it smooths out, replace it. the icv is on the outside of the manifold.
it is possible to replace this without taking the intake manifold off... its more difficult but it can be done.
Old 08-08-2007, 09:28 AM
WSC-MOB
great pic of the ccv by the way.
Old 08-08-2007, 09:33 AM
justtune's Avatar
Thanks finally CCV was the name....
I will do the finger trick today...
And let you know the result.
Old 08-10-2007, 08:25 AM
justtune's Avatar
Okay, so by by covering CCV vent, the engine does sound better and the vibration is gone...
Your saying that CCV is the root cause all this problem...
Question I have... can I just cover that vent with (tape or something) so car doesn't vibrate?
By covering the CCV vent, will this cause driving performance or any problem?
Old 01-18-2008, 04:33 PM
jfive96 jfive96 is offline
Connections Etc.
Send a message via MSN to jfive96 Send a message via Yahoo to jfive96
- -Bringing back to life an old topic, I have the same problem and I did the finger trick and all was fine. My same question is does the CCV need to be replace or can the vent be covered up?- -
[SIGPIC][/SIGPIC]* *Guns Don't Kill People, Crazy Mutherf*%$ers Like Me Kill Theives!!!!!!* *
"Connections Etc." I got what you need! Get at me!!!
I'm Rich B@*#$h!!!!
Old 01-18-2008, 04:44 PM
engind engind is offline
Mein Auto: bmw 520 98 e39
if you follow justtune's posts you will see ...
Change it immediately.
But before changing can you do one more test for me? i will be glad if you do.
when engine runnig open oil filler cap and place a plastic bag over it. And look if plastic bag vacuumed. Then post the result here.
Old 01-18-2008, 04:50 PM
Connections Etc.
- -I can do that for you, want be til Sat or Sun. What are you trying to see?- -
I'm Rich B@*#$h!!!!
Old 01-18-2008, 05:38 PM
i have a suspicion about my CCV is going bad, but when i do plastic bag trick its vacuumed.
if you sure your CCV is bad and you say plastic bag vacuumed too i am gonna change CCV.
if i were you i wouldnt drive more like that.
CCV designed to remove bad smokes from crankcase, if its clogged it can be harmful.
Thank You.
Old 01-19-2008, 05:42 AM
Connections Etc.
- -Well, I'm changing it this weekend. Getting the part today for $53 + tax. Going to remove the intake manifold because I bought gaskets thinking that was my problem. I"m going to go ahead and install them aslo. I was looking for the CCV on realoem.com and couldn't find it, does anyone have a link or part number I can plug in?- -
I'm Rich B@*#$h!!!!
Old 01-19-2008, 07:24 AM
dmako's Avatar
dmako dmako is offline
Mein Auto: 1999 528i
Any chance of take pics of the process? When warm weather returns here (3 months) I plan on replacing mine.
1999 BMW 528i sports pkg. 5-speed, rear lip spoiler, removed phone, Aspheric mirror, new M5 dead pedal, home made clutch stop, removed intake muffler, clear side and rear lights, Nein CDV, full cooling system overall, Beisan VANOS seals.
Best mod to date: removed seat clip.
Old 01-19-2008, 08:19 AM
Connections Etc.
- -Yes. Pics will be taken. I hate trying to find a problem on the boards and finally finding the solution and then there are no detailed pics. My driver just came back with the CCV and the part number is 11-61-7-501-566 from BMW of Dallas.- -
I'm Rich B@*#$h!!!!
Old 01-19-2008, 12:21 PM
http://www.realoem.com/bmw/showparts...87&hg=11&fg=15
its same as your 5.28i
and;
http://www.bimmerfest.com/forums/sho...d.php?t=225479
Old 01-19-2008, 03:54 PM
Connections Etc.
- -Well after looking at the links and the pics, the gave me the wrong part. I will have to update this once I get the correct part. #11151703484.- -
I'm Rich B@*#$h!!!!
Old 01-21-2008, 07:21 PM
Connections Etc.
- -Well I got the correct part today and I should be putting it on tomorrow if weather holds.- -
I'm Rich B@*#$h!!!!
