E36 (1991 - 1999)
Old 06-27-2007, 11:49 AM
suntex01 suntex01 is offline
Mein Auto: 328is
Steering wheel bearing?
I got myself a 328is over the weekend...first problem that comes up...
the steering wheel squeals and is kinda heavy while turning it...would it be the bearing or hydraulics problem. It also rattles sometimes at high speed...would it be expensive to repair?
Another problem is the traction control light is always on...does that mean a big repair as well?
THanks for your help
Old 06-27-2007, 12:15 PM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Welcome to the fest buddy
Your power steering reservoir may need topping up with ATF if it is heavy. Have you checked your tyre pressures?
The rattle maybe caused by a tracking/tyre problem or is possible your rotors are warped and need replacing.
The TC light - Have you tried pressing the ASC button near the gearshift to turn it back on?
2001 Mini Cooper R50
Edirty6 for life
Old 06-27-2007, 05:57 PM
Mein Auto: 328is
Hey,
thanks alot for the quick reply...i checked the acs button...and didn't work. Also, what type of ATF should I use for the 328is.
One last question, if the airbag light keeps coming on, does that mean there's a problem with the seatbelt sensor?
thanks
Old 06-27-2007, 09:26 PM
Mein Auto: 328is
also, is it possible that the squeal from the steering wheel means that the bearing needs to be changed...?
thanks
Old 06-27-2007, 11:04 PM
Conehead Conehead is offline
Go you Good Thing
Mein Auto: e36 316I M
Is the noise you are describing coming from inside the car. If so, could be the steering wheel mount is a bit dry and needs some lube.
Try some drylube from and auto shop.
Cone
XXX
The best predictor for future behaviour, is past behaviour. ALSO, IT SHOULD BE NOTED:......AMATURES BUILT THE ARK..AND PROFESSIONALS BUILT THE TITANIC..................QUOTE FOR THE DAY.. Good drivers know how to get out of trouble, and better drivers know how to avoid it.....The Cone 2006 & 2007
Old 06-28-2007, 09:49 AM
BMWredneck's Avatar
BMWredneck BMWredneck is offline
Send a message via MSN to BMWredneck Send a message via Yahoo to BMWredneck
Mein Auto: 96 318is Auto
airbag light could be your seat belts. it could also mean the car was wrecked and fixed back up but the computer wasnt reset.
Old 07-02-2007, 06:46 AM
Mein Auto: 328is
hmmm....i made sure that there wasn't any wreck on carfax...maybe i was wrong...
No signs of rebuild of the car...but again, I'm an amateur...
