E34 (1989 - 1995)
Old 06-27-2007, 10:57 PM
yodabmw yodabmw is offline
Mein Auto: '93 525i
Ran out of gas, car wont start now
My son ran my '93 525i out of gas. We put gas in and it ran for 2 or 3 min. We let it sit for a half our and it started up again and ran for 2 or 3 min. Now it wont turn over at all. I replaced the fuel filter and it just cranks but you can tell no gas it getting to the engine. Any ideas what this could be? Maybe fuel pump? Is there a fues I maybe should be looking for that could have blown?
Old 06-28-2007, 06:04 AM
bimmer dot info bimmer dot info is offline
The Biggest P0st Whore!!
Mein Auto: 2008 MS3
Was the key left in run for a long time with the tank empty?
Crap from the bottom of the tank might have the system blocked.
You could try jumping the relay with a fused jumper wire. It is in the PSGR side electronics box near the computer.
Old 07-01-2007, 10:27 AM
SewerSideUp's Avatar
SewerSideUp SewerSideUp is offline
Spitfire
Mein Auto: 94' 318iS
Could also be your fuel pump, over-heated and caused some serious damage!
Old 07-01-2007, 11:54 AM
528JD's Avatar
528JD 528JD is offline
Migrated to the X5 SAV
Mein Auto: '07 X5, '00 528i
Did you put gas in?
Old 07-01-2007, 03:05 PM
Steveng1993 Steveng1993 is offline
Mein Auto: 1993 325is and 1995 530i
I just went through a no start nightmare.
Put the key in and listen to see if you hear the fuel pump running.
Old 07-01-2007, 05:36 PM
Spitfire
When the tank is dry and refilled, after the heat damage to the fuel pump ofcourse !
Debris and dirt flots ans sticks to the filter, blocking it!
So, change youre pump and filter and you should be good to go!
Old 07-10-2007, 05:25 PM
Mein Auto: '93 525i
I replaced both the Fuel Pump and filter and still nothing. It doesn't sound like anything is getting to the engine but the fuel line is charged. Any other ideas???
Old 07-10-2007, 08:13 PM
zocksbimmer's Avatar
zocksbimmer zocksbimmer is offline
zocksbimmer
Send a message via AIM to zocksbimmer Send a message via Yahoo to zocksbimmer
Mein Auto: 1991 525i, five-speed
injectors? throw some sea foam in the gas tank just in case
Old 07-11-2007, 01:22 AM
attack eagle attack eagle is offline
No more e34!
Mein Auto: Nikes + Mongoose
are your injectors firing? is your fuel pressure good at the FPR and after it?
Still cruising after all of these years...
now on iOS 9 (saves gas)
Mutual Admiration Society
Member #5
Old 07-11-2007, 05:58 AM
K73 K73 is offline
Mein Auto: E34 525
I agree, has to blocked injectors if pump and filter have been changed.
89' 525i
Old 07-11-2007, 11:53 PM
Mein Auto: '93 525i
Got it running!
charged the battery good and gave it another try. It took a min. to crank it over, but it started up and is running great! Now my only problem is getting the radio to work again. How do I find the serial number of the radio so that I can get an unlock code?
thanks for all of the great suggestions. Your advise saved me loads of $$ and allowed me to fix the car on my own!
Old 07-12-2007, 01:13 AM
K73 K73 is offline
Mein Auto: E34 525
There should be a card in the service books with the code on it. I lost mine in my e36 but it was on a sticker on top of the unit itself, my e34 doesnt have a sticker on though.
89' 525i
Old 07-12-2007, 05:48 AM
Mein Auto: 2008 MS3
If you cant find the code you will have to go to the dealer. They will often look it up for free. If you cant take it out yourself to get the S/N they will probably charge you.
