E36 (1991 - 1999)
Old 06-28-2007, 12:17 PM
BimmerRacer007 BimmerRacer007 is offline
Trust me, I'm a pro......
Mein Auto: '97 z3 (///m powered)
Question OBD II code help
ok guys, so i received the error code P0170 which is fuel trim bank 1 fault. is this for pre-cat O2 sensors? MAF sensor? anyone know?
oh yeah, it's for an s52 in my z3 as well. (i know it's not an e36 in the traditional sense, but it's the same powertrain. im trying to get this fixed to pass emissions. lol)
thanks!
Dan
Old 06-28-2007, 12:28 PM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Hey buddy, maybe better asking in the M3 forum for this one as it is an 'M' Engine
Is there more to the error as it should say whether it is running lean or rich. From what i have read, it seems like a MAS error but the M3 guys will know more
I found this though
The code is for a system that cannot add enough fuel to maintain balanced air/fuel control. This can be caused by
- Vacuum leaks
- POSSIBLE MAF failure
- Restricted fuel filter
- Failing Fuel pump
- Thermostat or ECT sensor
- Failing oxygen sensor.
- Exhaust leak before the oxygen sensor
2001 Mini Cooper R50
Edirty6 for life
Old 06-28-2007, 09:17 PM
thanks, yeah it's posted in the m3 section as well. im just trying to get the widest range of info. yeah, i found one vacuum leak, and i'll be searching for more when the weather lets up. from what i can tell bank 1 means that it affects cylinders 1-3 only (which is why im thinking o2 sensor and not a complete vacuum or MAF failure). i just don't wanna chase the problem with hundreds of dollars before it's fixed.
