E30 (1982 - 1993)
Old 06-28-2007, 05:25 PM
325esgyrl 325esgyrl is offline
Mein Auto: 86' 325es
Question fuse burnout number10
my number 10 fuse keeps on burning out, it started lst week i had th ac running then all of a sudden within an hour of driving my tachometer, temp gauge, fuel gauge and ac all shut off.. i replaced the fuse and it was working 4 two days then shut off again, within the past couple days i went through 10 7.5amp fuses?? what could be wrong?
Old 06-28-2007, 07:35 PM
Bimmer ese's Avatar
Bimmer ese Bimmer ese is offline
Mein Auto: 04 X5, 01 330i
There is a wiring harness that plugs into the reverse switch on the transmission. Over time, the wiring harness insulation will wear thin, since it's positioned between the shifter boot and the transmission hump. The edge of the metal with wear through the wiring, thus, shorting the harness to ground.
Hope this helps. If you need more help, let me know.
Dan
Old 08-19-2007, 06:05 AM
lindylex lindylex is offline
Mein Auto: 1987 325 es
Bimmer ese, where is the "reverse switch"?
Old 08-20-2007, 11:31 AM
Bimmer ese's Avatar
It is located on top of the gearbox. If you remove the shifter boot, you will see the wiring harness near the shifter.
Dan
