Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 07-01-2007, 01:37 AM
Ron Stygar's Avatar
19,585 Miles
LeatherZ Gauge panel: Gauge install & wiring
Last year at the HC Embassy parking lot, Ken, Jon and Andy Maddux and I discussed their armrest with cup holder and a three gauge panel with no cigar plug on the panel face. Ten months later and both items are available. Good job guys.
Surprised how low the price is for the gauge panel in quantity ten.
Wanted four gauges. Oil pressure, oil and water temp and voltmeter.
Was going to use M12x1.5 250 degree oil temperature sender and switch it between oil and water temperature. No sender available.
Anyhow will be doing a 250 degree 1/8-27 oil temp sender like Daniel (DWM and Randy Forbes did).
Will switch between water and oil temp on the same gauge. Thanks Daniel.
http://bimmerfest.com/forums/showthr...=oil+temp+sump
I had a 300 degree oil temp gauge temporarily installed to see how it compared to the stock one.
Like the stock Z3 water temp, the oil temp is buffered too. VDO is more sensitive than stock. You can watch it going up to around 210 and fall back when the thermostat opens. When everything stabilizes they both read the same.
When the VDO goes to 220 the stock gauge stays at 210. When things cool down, both gauges read 210.
Initially installed the gauges straight on which doesn't look good to me and hard to read.
Ended up installing them around 20 degrees angled towards the driver. Years ago I did this (1997) in my ti.
Checked the ti and it is around 20 degrees too.
<img src="http://www.unofficialbmw.com/images/e36_318ti_vdo_gauges.gif">
You have to mod the U gauge brackets for length either way along with clearance issues.
The panel holes are slightly larger. Two layers (one at a time not over laying) of Scotch super 88 tape and they fit perfect.
Will start wiring the panel tomorrow.
<img src="http://www.unofficialbmw.com/images/gaugepanelz4-1.jpg">
<img src="http://www.unofficialbmw.com/images/gaugepanelz4-2.jpg">
<img src="http://www.unofficialbmw.com/images/gaugepanelz4-3.jpg">
<img src="http://www.unofficialbmw.com/images/gaugepanelz4-4.jpg">
<img src="http://www.unofficialbmw.com/images/gaugepanelz4-5.jpg">
<img src="http://www.unofficialbmw.com/images/gaugepanelz4-6.jpg">
<img src="http://www.unofficialbmw.com/images/gaugepanelz4-7.jpg">
<img src="http://www.unofficialbmw.com/images/gaugepanelz4-8.jpg">
Old 07-01-2007, 02:01 AM
Palantirion's Avatar
Palantirion Palantirion is offline
Z4 Mvangelist
Mein Auto: 2003 M5-S2, 2002 540iT-S2
As good an install as I'd expect from you Ron
Old 07-01-2007, 11:29 AM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
Looks good Ron. to you and the Maddux gang.
Daniel
2002 M roadster
Old 07-02-2007, 07:35 PM
Cliff Cliff is offline
TMS
Mein Auto: 2015 Golf R
Nice. I'll have to play around with the gauge face angles a little on the 4th. I installed my kit to the same extent as you last Saturday. I likey. I also see you're using a stud-like arrangement instead of the screws that were provided with the kit. I spoke to the owner of the shop I use this morning and he's going to install the sensors and wire things up this Friday.
edit: I did not need to mod the brackets in any way and I'm a little confused by that.
2015 VW Golf R: (pic)
Old 07-02-2007, 08:26 PM
AndyM's Avatar
AndyM AndyM is offline
Suede Master
Mein Auto: '02 3.0i Z3 Coupe
Ron bought a 'panel only'. If you get the complete kit, everything is in the box and ready for the car.
Old 07-02-2007, 08:28 PM
TMS
Mystery solved, thanks
Old 07-02-2007, 08:40 PM
Ron Stygar's Avatar
19,585 Miles
Andy sent me a modified stock piece and the gauge panel.
I ordered the VDO brackets which came with the studs. I had to shorten the brackets and studs. The long nuts that came with the brackets are replaced with stainless M4x.7 jam nuts.
I thought that the right bracket was hitting the gauge panel screw holder piece. It was keeping the top three hole piece from going all the way right.
Turns out the front of the gauge was hitting the front plastic of the gauge panel. Removed some plastic and it's fine. This is with the gauges centered with the two wraps of tape mentioned.
<img src="http://bimmerfest.com/forums/attachment.php?attachmentid=113653&stc=1">
The left bracket was no issue at 19 > 20 degrees. At 21 it was. Wanted some leeway if I wanted to go
more. After driving it, I am happy with the 21.
<img src="http://bimmerfest.com/forums/attachment.php?attachmentid=113655&stc=1">
If your installer has any questions he can call afternoon.
Old 07-02-2007, 09:30 PM
TMS
Thanks Ron. He's done other gauge kits (for E36, E46, and Z3's), so I'm hoping this one goes smoothly.
Old 07-02-2007, 09:37 PM
Ron Stygar's Avatar
19,585 Miles
I've only done the water temp on the Z3's and Z4's. The Z4 is different than the Z3. Maybe the E46 is the same.
Old 07-04-2007, 09:34 PM
Ron Stygar's Avatar
19,585 Miles
Gauge wiring is done for now.
Gauges left to right (looking from the front) are oil pressure, water temp and voltmeter.
Oil temp will share the water temp via a switch. Oil temp sender will be next to the stock oil temp (oil sump) like Daniel did.
Parts are on order. Probably after HC.
Purple wires are hot in accessory, run and start. Fuse #12. If that fuse blows you can't start the car.
Got stuck with that last Friday. Thank God that I had the LED fuses. Thanks Daniel.
Gauge wire just hanging in the console waiting for the install, went to ground.
Brown wires are body ground. There is a ground stud just to the right where the wiring comes into the cabin.
Gray wires are dimmed lighting.
Purchased some fiber black washers just slightly smaller than the screw head. Had to file out the inner hole.
Might keep them or make some Delrin thinner ones. Machinist left early Tuesday so that didn't happen.
<img src="http://www.unofficialbmw.com/images/gaugewiringz4-15.jpg">
<img src="http://www.unofficialbmw.com/images/gaugewiringz4-16.jpg">
<img src="http://www.unofficialbmw.com/images/gaugewiringz4-17.jpg">
<img src="http://www.unofficialbmw.com/images/gaugewiringz4-18.jpg">
<img src="http://www.unofficialbmw.com/images/gaugewiringz4-14.jpg">
Old 07-14-2007, 12:06 PM
TMS
Mine went in yesterday. It took my mechanic 5 hours to do the job. Thanks for the idea on angling the gauge faces Ron - I like it.
Old 07-15-2007, 01:13 PM
Dammmittt's Avatar
Dammmittt Dammmittt is offline
///M
Mein Auto: 07 M Coupe
They look nice but it seems like an odd place to look at while you're driving. I'm assuming you normally wouldn't look at those particular gauges very often anyway tho. So I guess I'm just wondering how functional/useful are these guages?
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website in the History of the Internet!
Old 07-15-2007, 01:52 PM
rjcoston's Avatar
rjcoston rjcoston is offline
///M Practical
Mein Auto: 00 M Roadster
Nice job as always Ron.
Old 07-15-2007, 02:28 PM
TMS
It would be nice if BMW gave us a proper instrument panel. Since they don't, this approach is an improvement over the idiot lights they do give us.
Now, are they $500 and 5 hours of shop time better than idiot lights? Only you can answer that question for yourself.
Old 11-19-2007, 10:20 AM
cmichaelo's Avatar
cmichaelo cmichaelo is offline
Mein Auto: 11 M3 coupe, 16 Acura RDX
Tilting anyone?
Did you relocate the cigarette lighter?
I like your installation. Though, I personally prefer more tilting so it's easier to see the gauges. As it is right now, you're sort of looking at them at a 30-40deg angle (0 deg being optimal).
Isn't it possible to slip in a tapered spacer between the gauges themselves and the panel holes? Anyone done this?
I know from doing this on my SHO that it createst a bit of a problem on the backside of the panel, as the more you tilt the gauges, the more the stick out beyond the perimeter of the panel itself.
You can check out how this tilting looks in the link below. I'm afraid my pics are in no way up to Ron's though. Good pics Ron!
Michael
For sale (2007 Z4 M Coupe parts): KW V3 coilovers (rears only), stock coilovers (front only), stock emerg. kit and ESS tune (supposedly only works on my car, but if you know how to tinker, i dunno, might be useful to you).
Old 11-19-2007, 10:27 AM
TMS
No. My V1 is hardwired and I don't have a pressing need to talk on or recharge the cell phone while driving this car, so the greatest potential use for a 12v plug is to make use of the M Mobility kit. Just call me a risk taker...
No idea on the rest. The gauges are visible enough for my needs.
Old 09-23-2010, 12:50 AM
Hoops432 Hoops432 is offline
Forever Fast
Mein Auto: '06 M Coupe, '08 K12S
Old thread revival!
Ron, did you decide to keep the extra oil temp gauge? Or do you think it is so close to the cluster gauge that it's better to use it for something else?
2006 IBlue BMW Z4 MC (OZ spec) - ESS VT2-525 Supercharged, JRZ RS1 suspension (500#F, 600#R) with Vorshlag plates, ST Trophy BBK with CL R6E pads, KKS gated exhaust, TMS sway bars, RE rear camber arms, VT engine mounts, Recaro Pole Position (driver), APR GT wing, Street: Volk G2s and Potenza, Track: Volk TE37SLs and BFG R1s.
Old 09-26-2010, 06:21 PM
Forever Fast
Bump for Ron. Or to anyone who has experience with this of course.
Old 09-28-2010, 09:50 PM
BeemerMikeTX's Avatar
BeemerMikeTX BeemerMikeTX is offline
Mein Auto: Z3 3.0i Roadster, K1300S
This has been discussed in a few other threads, but I understand that the Z3 water temperature gauge (and maybe all recent BMWs) does not really indicate the true water temperature. The gauge is governed by the computer so that for any water temperature in the "normal" range the needle points to the center, and only when the water is cold or too hot does the needle move off the center. The "gauge" is better thought of as an analog idiot light. Apparently this was to reduce questions from car owners about varying water temperatures (i.e., the cars were dumbed down). At least that is what my dealer's service manager told me when the plastic thermostat failed on my 2000 328Ci but the water temperature gauge did not show any variation in temperature. Based on the unbelievable stability of the water temperature in my Z3 (at least as indicated by the "gauge"), his explanation seems correct.
So, if you want to really know your water temperature, you will have to install a gauge that actually shows the water temperature.
Mike White
"That's right, you're not from Texas, but Texas wants you anyway." -LL
2001 Z3 3.0i Roadster (Topaz Blue Metallic, 5-speed manual, Sport Package, CD radio, heated seats and mirrors, non-power top via special order)
"Beemer" is for my BMW motorcycles - '13 K1300S, '95 R1100RS, '88 K75S, '75 R90S (gone, but not forgotten).
HTML code is Off
