92 525i Trans slips - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 07-08-2007, 05:38 PM
1003chris 1003chris is offline
Mein Auto: 1992 BMW 525i
92 525i Trans slips
My 92 525i trans slips in 1st gear , but runs fine in revers...what could be the issue? Is it clutch plates or a sensor??? I have to get the RPM'S up to even get it to pull off in first, then it soon stops pulling at 500ft , I have to pull over and shut off the engine to get it to going again. I got it to slowly creep home after many stops. Could it be the automatic clutch plates or a program issue since I have changed the pressure regulator and all of the other trans solenoids.
Old 07-08-2007, 07:27 PM
zocksbimmer's Avatar
zocksbimmer zocksbimmer is offline
zocksbimmer
Send a message via AIM to zocksbimmer Send a message via Yahoo to zocksbimmer
Mein Auto: 1991 525i, five-speed
try this...Transmission slippage: Transmission may slip and/or check-engine light may glow due to torque converter clutch (TCC) slipping and/or TCC solenoid failure. (1992-94)
found here
http://consumerguideauto.howstuffwor...5-series-2.htm
Old 07-09-2007, 10:42 AM
bimmer dot info bimmer dot info is offline
The Biggest P0st Whore!!
Mein Auto: 2008 MS3
TCC should not come into play in first gear. Unless it is stuck on which i have not heard of with these cars.
What do you mean it stops pulling? Does it just slip after that distance? Did you clean out the valve body? There is a chance that the clutches are shot. Have you done any other trans work?
Old 07-09-2007, 10:26 PM
I changed the valve body and all of the solenoids. The car stops and does not move forward or in reverse after about 500ft.
Old 07-10-2007, 06:06 AM
Mein Auto: 2008 MS3
You should probably take it to someone before you hurt it anymore. It is much cheaper to have them rebuilt before you start breaking hard parts.
Were you the first person to open the trans? What condition was the fluid in? Were there any large particles or a lot of fine metal shavings/powder?
Old 07-10-2007, 11:02 PM
Is a 97 Cadillac Catera 4L30E interchangeable with a 92 525i 4L30E?
Old 07-11-2007, 06:30 AM
Mein Auto: 2008 MS3
I didnt even realise that the Catera had a 4L30E. I'm not really sure if it will interchange. I wanted to change mine out with a 4L30E from a Rodeo. It has a lower ratio in first and second but the same in third and drive. Might help fix the sluggish acceleration.
If all the connectors are right you might be able to get it in and working (might need to swap the bellhousing). Wonder if there is somone you could contatct at GM that would have the answer?
After a quick search it looks like there are at least some differences. This guy makes it sound like it is a newer generation of the same trans (THM 4L30E).
http://www.cadillacforums.com/forums...n-cateras.html
Let us know what you find out and how things work out for you.
Old 07-10-2013, 07:27 AM
bannister bannister is offline
Mein Auto: 740 & 525
1995 525, started slipping changed fluid and filter and ran fine for two weeks then started slipping. Think clutches are gone. Trans swap above my pay grade. Quoted $2500 to replace. Spent bunch on new parts in prior 3 months. new tires struts alternator, water pump belts. selling for $1050. if I'd been able to find a inexpensive solution would have done it. Car was a faithful driver. Good luck.
