Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 07-24-2007, 06:10 PM
omw41's Avatar
omw41 omw41 is offline
Mein Auto: 1986 BMW 325 E
steering wheel removal
86 325 -I am planning to switch the stock steering wheel with the three spoke type found on the M3 and the ES-anyone happen to know what size socket fits over the nut under the emblem? I was screwing around in the junkyard today and couldn't seem to find the right size. Second, is it an easy switch with the horn wiring? Last, I bought a steering wheel puller-did I need to do that? It was only 14.95 at Advance...so I can take it back.
Old 07-24-2007, 07:15 PM
lordofthewaters's Avatar
lordofthewaters lordofthewaters is offline
Rather Large Member
Mein Auto: 88 325is 04&09 jetta TDi
21mm and you don't need a puller. I just pop out the center emblem, take off the nut, turn the key in the switch and pull it off. I would insure that your wheels are good and straight, before pulling the wheel though.
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson
Old age and treachery, will always overcome youth and skill.
Old 07-24-2007, 07:24 PM
omw41's Avatar
Once again, praise the lord. In the words of a prison inmate: "I don't know how a person without faith can possibly do time."
Any feedback on the horn wiring?
Old 07-24-2007, 10:54 PM
markseven markseven is offline
an audience of One
Mein Auto: BMW M Power
Word
The horn wiring/connector should be the same. You really should get a new steering wheel nut from the dealer and then torque to 56lb/ft.
WTB:
Minty Seat Belt Receptacles - Front
Old 05-26-2008, 03:40 AM
moha114 moha114 is offline
Mein Auto: BMW E30
you can use the wheel spanner that is wat i always use,remove the center emblem with flat screw driver remove the nut and swith the key on and pull it out.
Old 05-06-2011, 03:36 PM
SBibbo SBibbo is offline
Mein Auto: 1988 325 iC
It's a 22mm socket, you should also use a torque wrench and tighten to 56 lb/ft
Old 05-06-2011, 04:01 PM
Rather Large Member
Geeez. Holy thread resurrection for no purpose Batman!
Old 05-06-2011, 04:16 PM
LOL... I just wanted to get the size right. I did the search myself and ended up buying the wrong socket.
Old 12-05-2012, 04:19 AM
helphos helphos is offline
Mein Auto: 2004 325xi
LOL. I'm guilty of the same charge. But when it adds to the discussion it makes life so much easier. I was searching yesterday for information on changing the steering wheel, and this thread notes 21, 22 mm and lug wrench sizes (my lug wrench is a 17!). If you have a complete socket set it's no big deal, but if you have to buy one, it's a PITA to get the wrong one.
From all appearances it looks like you can swap steering wheels among E30s without adapters as long as airbags don't figure into the equation. That's neat!
Cheers!
