E36 (1991 - 1999)
Old 03-16-2008, 09:34 AM
1canary's Avatar
1canary 1canary is offline
1 canary
Mein Auto: 1998 323i convertible
I eventually sorted the droning noise from the rear of my car....turned out it WAS the right rear wheel bearing. £40 and now sounds great. Such a good mechanic so I had him do some MOT advice work and rebuilt front right suspension (wishbone, drop link rod and track rod) for £120.
BTW not been around for a bit as I have been browsing the convertible section on bimmerforum. This is quite good to tap into for 'vert specific issues but not always heavily populated.
If you don't like the way I'm driving...get off the pavement.
Old 03-16-2008, 11:32 AM
MrHeeltoe MrHeeltoe is offline
BMW Grasshopper
Mein Auto: 97 M3 Coupe
I have sort of a groaning sound, intermittent, low speeds. I want to say it is the diff. Is there any advice for this? Its a 97 M3.
I bought an E36 and my Honda friends dis-p0wn3d me.
www.heeltoeauto.com
Old 04-11-2008, 01:50 PM
Scotty328 Scotty328 is offline
Send a message via MSN to Scotty328
Mein Auto: 1996 328i Sport
Originally Posted by spanieldecks View Post
Hey there, great thread. I'm currently troubleshooting a load of small noises in a recently acquired '97 M3. Here's a tip for y'all, check that the door trims are tight against the panel. New plastic clips can be bought from the BMW stealer of pence... and removed door trim rattles instantly! When doing this, don't be afraid to 'muscle' the panel off in the first place.. it's damn tight"
I have a 'squeak' when pulling away or accelerating from it sounds like the rear seat. or perhaps below it. No knocks or anything when driving (had new bushes to fix that), just a one off 'squeak' when pulling away. even had the wife drive it with the rear seats out so that I could locate it... any ideas or similar experiences?
Mine squeaks too, it's a 1996 328i Sport. No idea what's causing it either!
E36 328i Sport.
M50 Manifold with Big Bore Throttle Body, K&N Heatshielded CAI. Eibach Sportline Springs, E30 Wishbones, Powerflex Poly Bushes. 3.15:1 LSD, Factory M-Tech Bodystyling, Factory fitted Bilstein Dampers. Currently running 223 Bhp and 215 ft lbs, more to come.....
http://img.photobucket.com/albums/v98/liquidchild/My%20Car/328i%20Sport/Drift17sig2.jpg
Quattro ist fur sissies.....
Old 05-05-2008, 08:54 PM
SCANDINAVIAN13 SCANDINAVIAN13 is offline
Resident Pilot
Send a message via AIM to SCANDINAVIAN13 Send a message via Skype™ to SCANDINAVIAN13
Mein Auto: 1993 325is
I'd just like to add one more to the list.
A slight knocking from the left rear:
Check your exhaust mounts, as they could be loose. If they're loose, the system, from the cats back, will sway some.
Kyle
1993 325is - Frigg - Grounded
2001 Z3 2.5 - Išunn - Active
Old 05-31-2008, 02:53 PM
Corey Milne's Avatar
Corey Milne Corey Milne is offline
FixItFaster
Mein Auto: EuroS50B30, e83m54b30
Originally Posted by tonyyank View Post
That pic was taken in the summer, its all fixed now
I had some podunk mech look at it and all he said was "Your rear end is almost off the frame" I immediatly left. This is just a fun car, I own it. I beat it, and it blows in the snow. Just seeing if i HAVE to fix it, or it SHOULD be fixed. If i drop the clutch at about 3K its like BANG!!! If I ease off the clutch, its just sqeeks. I fixed one of the RSM already that took another noise away lol I wish I knew who had this car from new, cause they have absolutly NO respect for a BMW. Dumbass!!! Weekly and Monthly maint. on any vehicle is a must. My truck feels bad for my little bimmer
No offense but it sounds like you don't have very much respect for your bmw, you should never drop the clutch in any bmw, they arent made for it, dual mass flywheels get ruined from it and it is hard on the whole car. Bmw is a track car not a drag car, if you want a straight line car by a mercedes..
cuz there to heavy to turn corners anyways hahaha.
Old 08-09-2008, 06:32 PM
Found out what was causing this! Diff carrier ripped itself from the chassis last ween
E36 328i Sport.
Old 08-13-2008, 11:04 AM
lewiboy lewiboy is offline
Mein Auto: 318ti
there is a noise coming from the rear drivers side, it sounds like a tin being dragged along the floor. It only makes the noise over bumps but stops when i hit the brakes, even just slightly touch them and it stops. i have checked the brakes and cant see anything out of the ordinary. please could someone write me a list of possibilites for what is causing it.
Old 08-20-2008, 01:08 PM
zanderbrown zanderbrown is offline
Send a message via AIM to zanderbrown
Mein Auto: 1995 325is
Had a crazy loud chopping noise like i was running over a robotic dog from the rear whenever i accelerated until i hit around 35 mph and would be fine except for the drastic drop in power. Turned out to be the universal converter joint.
'95 325is
Old 09-07-2008, 09:50 AM
BMER 323 BMER 323 is offline
Mein Auto: BMW 323 E36
hi have u checked the heat sheild on the brake?
Old 09-17-2008, 06:46 PM
foamerdave foamerdave is offline
OK this looks like the best place to post this. I am getting a signal "click" on acceleration from the right rear. Get more of a "clack" if I let off the gas hard. No squeaks or other sounds from out back there. If I hop on and off the gas it go click clack (did this to find out where/witch side it was coming from
Old 09-23-2008, 12:18 AM
spanieldecks spanieldecks is offline
Mein Auto: E36 M3 Cabrio
Squeaks knocks and bangs updated
Hi there, here's an update.
My E36 Evo convertible '99 has been on the ramp more times than I can count now. New rear trailing arm bushes, new rsms.... back end feels amazingly tight to drive but still a 'rattle rattle' over bumps. The garage never found it... but I have a solution for you all!
If the rattle from your back end is more of a 'chatter' over small bumps, try driving over bumps with your left foot slightly on the brake pedal. Does the sound go away? I might well. In which case you will find that the retention clips on the inner brake pad that hold it against the piston have broken. Solution, new brake pads. Without this clip that is part of the pad, the pad an rattle a few mm in the caliper.
The 'squeak' when pulling away, no idea. never found it, but it cured itself.
Cheers!
Dan
Old 09-23-2008, 12:20 AM
it's the brakes!
Clip on the inside brake pad. Get new pads. Its fiddly but you will find that you can move the brake pad with your fingers and the car at a stop (make sure it's not hot first).
Old 10-17-2008, 08:35 PM
BimPorDrvr BimPorDrvr is offline
Mein Auto: e36,e46
I've experienced three more types of clunks from the rear. I found the shock mount noise to be higher in the chassis as well as somewhat higher pitched. Sounded like hitting two 2x2's together. There's a lower pitched clunking that seems to originate from the floor in front of the rear wheel wells. It comes and goes but is noticeable when driving over poorly paved surfaces. It sounds like a door isn't closed and is rattling. It's the rear trailing arm bushing (RTAB). What happens is the rubber bushing gets compressed and allows the arm to rattle against its mount. It's in the floor just ahead of the rear wheel. Mine let go at 140k. An Indy shop charged me $260 for labor and $40 for parts. RTABs sound like worn CV joints but make their noise going over bumps. CVs make their noise when driving the car into a hard curve at low speed. CVs are easy to check - just grasp the half shaft (betwen rear trailing arm and diff) there should be NO vertical or front to back motion.
Great post. I'll check my dust shields. I've got the whooshing noise you've described.
Old 01-28-2009, 08:05 PM
This was the early sounds of my sub-frame mounts going bad
Old 01-28-2009, 09:55 PM
wippenberg wippenberg is offline
Mein Auto: A Tractor
Front or Rear?
Old 01-29-2009, 01:11 PM
Well with this thread being called "Sounds From the Rear: Explained" I'll give you three guesses
Old 01-29-2009, 01:13 PM
Ah. My Genius must be on hold when i posted that.
Old 02-16-2009, 03:39 PM
arte444 arte444 is offline
Send a message via AIM to arte444
Mein Auto: 1993 BMW 325is
How about a ... "woo-woo-woo-woo sound while crusing 30 - up MPH" Kind of higher pitched. Doesn't happen when i'm off the gas or half throttle. Just got new tires and an alignment also.
-Kyle
1979 Suzuki FZ 50cc Scooter
1988 Pontiac Fiero 5spd 4.9L V8 Cadillac (220,000 mi)
Delta Cam, True Dual Exhaust, Spec Stage 4
1993 BMW 325is 2.5L I6 DOHC (135,000 mi)
Mods: Fan Delete, New tires
Old 02-19-2009, 08:32 PM
Well get my car back tomorrow from having the subframe fixed. If you think you have this happing to you, get it fix as fast as you can. I drove on mine for close to six months and was told that it was one of the worst ripped up rears they had ever scene. They had to cut the floor on the inside of the car to fix it right ( 95% of the time it can be done from the under side) They had to weld a plate on the top of the mounts be for they could weld in the new reinforcement plates.
The flip side to all this is I was told that it looks like my car has been very well taken care of over the years (93 155k on it) as they found all sorts of new bushings and other parts that they would replace at this time that where already new
Old 02-19-2009, 08:35 PM
sounds like a bad belt in one of the new tires to me
Old 02-20-2009, 06:55 AM
That might be true. Didn't start making the noise until I got the tires.
-Kyle
Old 02-23-2009, 07:01 PM
dgraypost79 dgraypost79 is offline
Mein Auto: BMW 318i
If you ever hear a really horrible metal on metal cracking sounds it's most likely your lower control control arm bushing. Bad thing is when I got it fixed it was really expensive I took it to midwestern auto group that was my first mistake and learned later that I could do it myself...
Old 03-30-2009, 11:13 AM
ivesy2005 ivesy2005 is offline
mtech style!!!
Mein Auto: e36
i had that noise turned out sum dip **** me forgot to put the anti rattle clip back on the front discs slides across to stop them rattling about wen theyve worn i a bit
Old 03-30-2009, 01:52 PM
kevzep kevzep is offline
Mein Auto: e36 316i
How's it going?
Good advice Kyle.
Done a few rear bearings without any puller or press tools, used a home made slide hammer for one, the others i removed the trailing arm, pretty easy to do, but be sure to mark the mounting bracket position. Also mark the eliptical bolt head at the lower control arm ( this should help get the geometry right ). Once the trailing arm was out i tapped the drive shaft out and then used a lump hammer and some brass to get the hub out from behind. To get the outer race out i used a lenght of thick treaded bar with nuts, washers and bits of scrap metal as spacers to press the bearing out. Used the same rod to get the new one into the trailing arm and the hub into the bearing, using the old bearing parts as spacers ( they usualy break when being removed).
People attempting this should beware that when fitting the new bearing into the trailing arm to apply force only to the outer race and when pressing the hub in to apply force only to the inner race.
Also clean the inside of the hub and the splines on the drive shaft and apply some engine oil to aid easy re-assembly.
Kev
A lenght of threaded rod you should get for a few dollars.
Old 04-14-2009, 06:41 AM
cjf351 cjf351 is offline
Mein Auto: 325is
I have the same issue, and i believe i have found the problem.
The inboard brake pad has retaining clips/springs on the back side that hold it in the caliper. The clip/springs have broken off and are allowing the brake pad to float freely. This does not effect braking at all, but rattles like the car is going to fall apart every time you hit a bump. You may have to replace rotors and pads at the same time to prevent squealing. Looks like a pretty easy fix though.
:3
