E36 (1991 - 1999)
Old 07-05-2011, 05:20 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Could it be your tires rubbing, since it only happens when the car is weighted down?
1998 BMW 328is
1966 Pontiac GTO
Old 07-05-2011, 07:36 PM
Dino1394's Avatar
Dino1394 Dino1394 is online now
bimmerfest Supporting Member
Mein Auto: 04 330xi
I hear this flex disc sounding noise when I'm going slow over uneven roads but if I go over a speed bumps or over a bump at regular speed I dont hear the noise. Also occurs when taking a left turn at about 20mph?
I need help festers. My flex disc is fine so I already ruled that out.
Sent from my Nexus One using Bimmer App
Old 07-05-2011, 07:45 PM
Alpina B3 3.0 Alpina B3 3.0 is offline
Mein Auto: Alpina B3 3.0 1994 #219
Hmm no it cant be the wheels they clear pretty well. Its like a vibration noise....it happens when i'm alone too sometimes at really low rpm.
Sent from my X10a
Old 07-06-2011, 11:14 AM
Moeman10's Avatar
Moeman10 Moeman10 is offline
hookersandblow
Send a message via AIM to Moeman10
Mein Auto: 1992 325is
RTAB's?
Originally Posted by petriej View Post
You can sleep in your car, but you can't race your house!
Old 07-08-2011, 12:33 PM
Dino1394's Avatar
Mein Auto: 04 330xi
Originally Posted by Dino1394 View Post
I hear this flex disc sounding noise when I'm going slow over uneven roads but if I go over a speed bumps or over a bump at regular speed I dont hear the noise. Also occurs when taking a right turn at about 20mph?
Anyone?
Old 07-08-2011, 03:38 PM
Moeman10's Avatar
hookersandblow
Originally Posted by Moeman10 View Post
RTAB's?
Anyone?
Old 07-08-2011, 04:20 PM
Dino1394's Avatar
Mein Auto: 04 330xi
oh that was for me? lol my bad
i will check em them, i hear they're PITA to do
but....
i google'd what symptoms would also come with bad rtabs...but i dont have any of those?
Old 07-09-2011, 05:53 AM
Willow609 Willow609 is offline
Mein Auto: 323i 2.5 coupe
What are rtab's. I'm stupid I know.
Old 07-09-2011, 09:02 AM
Dino1394's Avatar
Mein Auto: 04 330xi
Rear trailing arm bushings
Old 07-09-2011, 06:21 PM
3B2M8WI 3B2M8WI is offline
Mein Auto: 1998 BMW 328i - Avus blue
quick question..
When i am really pushing the car (Pedal all the way down) and the rpms hit the red line my car make a loud screeching noise is this my flex disc???
Old 07-09-2011, 06:26 PM
ZeGerman's Avatar
Warm Leatherette
Nope. Assuming the screeching you're referring to isn't your tires spinning, my guess is that it's probably your belts slipping (which they shouldn't be doing).
1998 BMW 328is
1966 Pontiac GTO
Old 07-09-2011, 06:27 PM
Poorboysracing's Avatar
Poorboysracing Poorboysracing is offline
I <3 Underpowered BMW's
Send a message via AIM to Poorboysracing
Mein Auto: '00 BMW 528i '68 BMW 1600
Vanos?
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
Old 07-09-2011, 06:30 PM
oh ok so i shouldn't be worried about it then? Yeah my dad tried to convince me it was my tires spinning lol
Old 07-09-2011, 06:35 PM
Dino1394's Avatar
Mein Auto: 04 330xi
Belts slipping =not good
ZeGerman's Avatar
Warm Leatherette
Originally Posted by Poorboysracing View Post
Vanos?
Shouldn't be. VANOS is chain driven, so there won't be any screeching going on. My vote is either for tires losing traction or belts slipping a little bit when a super high RPM. Is it coming from under the hood or the rear of the car?
1998 BMW 328is
1966 Pontiac GTO
Old 07-09-2011, 06:37 PM
mid to front area of the car its hard to tell
Old 07-09-2011, 06:39 PM
ZeGerman's Avatar
Warm Leatherette
Will it make the noise if you redline it when in neutral (not moving)?
1998 BMW 328is
1966 Pontiac GTO
Old 07-09-2011, 06:47 PM
no its when the car shifts into the next gear
Old 07-09-2011, 06:55 PM
ZeGerman's Avatar
Warm Leatherette
Probably the tires then, and definitely not the flex disc.
1998 BMW 328is
1966 Pontiac GTO
Old 07-09-2011, 07:00 PM
well thats relieving
thanks a lot ZeGerman your always there to answer all my crazy questions lol
Old 07-09-2011, 07:14 PM
crisscross's Avatar
crisscross crisscross is online now
Just living MY dream
Mein Auto: 1995 M3 Boston Green
Manual right? If so its probably the belt, from 6500rpm droping to 5000 rpm with the rpms climbing will shock the belts and cause a slight squeel. I highly doubt its the tires chiping (my ///m doesn't do that past second), and they definately wouldn't do that at redline.
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3 2000 TiAg 4.4l X5
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 07-09-2011, 07:22 PM
No its unfortunately an auto
Old 07-09-2011, 07:28 PM
My friends e46 325ci makes a screetching/ whistling sound when hes at WOT because his vanos is shot, not aruing your point just justifying my statement
Old 07-10-2011, 12:40 PM
Dino1394's Avatar
Mein Auto: 04 330xi
rtabs
but....
i google'd what symptoms would also come with bad rtabs...but i DO have those?
i sat here and thought to myself wait one of the symptoms is the car pulling to one side when brake or accelerating, and my car is doing that and after more researching i labeled myself as a idiot for a second
might go with the same one Karl has on his coupe
thanks Moeman (Lou?)
But now i hear a noise coming from the rear drivers side only when im using the brakes
any ideas?
Old 09-04-2011, 10:48 AM
1nsane 1nsane is offline
Registered Cruiser
Mein Auto: e36 320i AC Schnitzer
The only noise that comes from the back of my car is from my new 1000watts JBL woofer
http://img405.imageshack.us/img405/669/forumsign.jpg
E36 320i AC Schnitzer pack
cruizin' in style
:3
