Old 02-26-2003, 07:16 PM
Ron Stygar's Avatar
19,585 Miles
Upper strut nut tools
To tighten or loosen the upper strut nut you have to hold the inner shaft while turning the nut.
The BMW nut is 21 mm with the inner shaft being an internal 6 mm hex.
The Koni nut is 22 mm with the inner shaft being a 11 mm hex head.
Made up the following tools based on the tips from Neil Maller.
Old 02-26-2003, 08:29 PM
Mini-///M Mini-///M is offline
Mein Auto: '99 M coupe
Hey Ron you should try rotating the front struts... you get like 3+ degrees of negative camber for free and you can go back whenever.
Pat
Old 02-26-2003, 08:54 PM
Ron Stygar's Avatar
19,585 Miles
Pat
Today, I sold my stock upper mounts to a guy with a '95 M3 that wants to do that.
Old 03-11-2003, 08:05 PM
Ron Stygar's Avatar
19,585 Miles
Tools shown in use position
Old 03-12-2003, 12:59 PM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
Ron, any technical issues with the torque wrench reading while using the crow foot? The torque wrench reading be off a little, no?
Finally, how much? I may need to get it just to adjust my top strut/shock nut to the right torque setting, instead of as tight as possible
"Bench racing" about track times driven by professionals are like a bunch of nerds arguing which Princess Leia is hotter, the slave Leia or the no-bra jail-bait Leia. No matter how compelling your argument is, the plain and simple fact is, none of you will EVER get to hit that.
Old 03-12-2003, 08:18 PM
Ron Stygar's Avatar
19,585 Miles
Yes. See the following pics.
For my Sears Digitork 5>80 pound one the factor is .911.
For my Sears Digitork 25>150 pound one the factor is .925
Both of these are using the one inch crow foot.
So what ever you want at the crow foot, you set the wrench to .911 or .925 of the desired value depending what wrench you are using.
I used the 47 lb ft BMW value instead of the Koni recommended 59 lb ft.
47 x .911 = 42.8, 43 on the 5>80 wrench
47 x .925 = 43.5, 44 on the 25>150 wrench
Old 03-16-2003, 07:01 PM
The HACK's Avatar
Cool, you rock Ron.
Old 04-23-2005, 03:04 AM
bob lindquist's Avatar
bob lindquist bob lindquist is offline
A Clean Windshield
Mein Auto: 2000 Imola M Coupe
Been changing tires and completing some modes this week. I was able to install the Rouge RSM's, brake pads and generally cleaning up the car.
I was at one time going to autox the car but never got to that due to lack of time.
I just removed the Dinan Camber plates from the front struts. Don't need them on the street. Anyone interested in the plates let me know.
2000 Imola Red M Coupe
Dinan suspension, M rotors /Axxis pads
Eurosport Cam Kit 1, touch lane change
Zaino polish, Beach Sand
Garys mirror adapter, S54 Oil Cooler
seat tilt coupling nuts, spare tire
"life's to short to drink cheap beer"
Old 04-23-2005, 05:04 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
How much extra negative camber do they give? How much do you want for them?
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 04-25-2005, 07:12 AM
A Clean Windshield
-5/8 degree from stock
250$ new / 150$ 4U
Old 04-25-2005, 10:37 AM
Pinecone's Avatar
M Mad
If they are still available once I get home and can measure what the car has now, I will let you know.
But don't hold them for me.
Thanks.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
